Old Mar 02, 2010, 09:06 PM
Sky-walker is offline
Find More Posts by Sky-walker
Sky-walker's Avatar
Joined Jun 2005
Is there a working quad with 3 gyros and 3 v-tails?
HI everyone, I have been reading a lot of forums searching for anyone that tried bulidng a quad with plain gyros and v-tails but havent seen anything.. I am asking if it will work or should I forget it? do I need a board to fly or can I go by gyros? I know that gyros arent sensors... but what would it be like.
I have only seen a diagram here on RCG but couldnt find its owner or designer
http://www.rcgroups.com/forums/attac...mentid=2305808
Kalle
Sky-walker is offline Find More Posts by Sky-walker
Old Mar 03, 2010, 06:16 AM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Post #60
http://www.rcgroups.com/forums/showt...96#post4874496
http://video.google.com/videoplay?do...76232576090493
Oldies but goodies.
SebastianJ is offline Find More Posts by SebastianJ
Old Mar 03, 2010, 06:43 AM
KayCee_V4 is offline
Find More Posts by KayCee_V4
Bricks don't glide !
KayCee_V4's Avatar
Joined Mar 2008
Simple Quad
Heres a link to one that works.
http://www.rcgroups.com/forums/showt...03#post6596903
This is an interesting Quad. Uses two v-tail mixers and EDFs.
http://www.rcgroups.com/forums/showthread.php?t=732586
KayCee_V4 is offline Find More Posts by KayCee_V4
Old Mar 03, 2010, 07:45 AM
Sky-walker's Avatar
Joined Jun 2005
thank you so much guys
Old Mar 04, 2010, 08:46 AM
Sky-walker's Avatar
Joined Jun 2005
so how are these compared to board based quads, lets just leave the highly expensive boards that has gps, etc and compare to relatively cheap boards(if there are any)?
Old Mar 13, 2010, 01:49 PM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
The gyro only based quads will fly fairly well, but unlike the better (and much more expensive) firmware based boards there is no self-leveling, not to mention altitude hold with a barometer and heading-hold with at compass, or the possibility of a GPS. There might be a possibility to add the $107 Flymentor to get some pilot self-level assist, but the FM's camera hover hold is only good to 9ft. The good news is the demonstrated tricopter and quad successes using the $13 HK401 gyros bring this entry level mixer quad affordable. A higher resolution mixer such as the Mini-mixer by Clarkst, or the Digimix II mixers might increase the overall gyro only quad's performance.
BTW Brendin aka Xarnon is the author of the gyro mixer quad diagram: http://www.rcgroups.com/forums/showt...=3#post4727117
FWIW.
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old Mar 13, 2010, 09:28 PM
outsider787 is offline
Find More Posts by outsider787
outsider787's Avatar
Canada, ON, Toronto
Joined Dec 2007
I've not seen any posts (mind you I don't follow all the threads) where tri or quads were flown using only HK401s.
Jim,
I thought the HK401s were only used for the yaw servo, and the $25 Telebees were used as the main gyros.
At least that's what you see on the first page of most build logs (that may not have been updated)
Can you post some links please?
adrian.
outsider787 is offline Find More Posts by outsider787
Old Mar 13, 2010, 11:05 PM
Sky-walker's Avatar
Joined Jun 2005
Have seen quads with GWS gyros, but dont know which ones, are GWS bettern than hk401s?
Old Mar 14, 2010, 07:54 AM
jesolins is offline
Joined Feb 2007
Adrian,
Signguy uses three of them for the CP and one for the yaw servos. He has shhown that they can be used in rate mode for large frames or digital mode for smaller than 13" frames. Only the yaw gyro is set to HH mode. Here are some pertinent posts from Signguy on using the HK401's on his tricopter builds:
http://www.rcgroups.com/forums/showt...1#post14439637
http://www.rcgroups.com/forums/showt...1#post14351398
http://www.rcgroups.com/forums/showt...1#post14318430
http://www.rcgroups.com/forums/showt...1#post14504310
http://www.rcgroups.com/forums/showt...7#post14590510
Many other users in his thread and other tricopter builds are having great success with them too.
I think one Gent was having setup issues with them...but there is always one or two of those even in the best situations
No doubt in my mind they would work well on a quad mixer setup. They should work well with Clarkst's mini-mixer too: http://www.rcgroups.com/forums/showthread.php?t=949507 and http://www.mini-mix.blogspot.com/
Cheers,
Jim
Jim,
adrian.
Old Mar 15, 2010, 07:27 AM
Canada, ON, Toronto
Joined Dec 2007
Thanks Jim
I've read through those posts you listed. I'll have to get me a few of those gyros.
Old Mar 16, 2010, 08:26 AM
Sky-walker's Avatar
Joined Jun 2005
seems tricopter is easier to build than quad, only three gyros and ccpm mixing while the quad seem to need fancy mixing, some have made it with gyros only though
For Sale 3 x custom TabooGT models (std, disser + molded tails, narrow wing + foam tails) olgol Aircraft - Sailplanes (FS/W) 6 Mar 05, 2010 07:04 PM
Discussion Are there any V-bar problems? What do the gyros actually do? LaurenceGough Electric Heli Talk 16 Oct 10, 2008 10:40 PM
Wanted 4 Brushless motors, esc,gyros and electric v tails Dirtyred Aircraft - Electric - Power Systems (FS/W) 0 Sep 18, 2007 01:24 AM
Sold I have 3 good working rate gyros for cheap. Matthew Cotten Aircraft - Electric - Helis (FS/W) 1 Dec 11, 2005 07:07 AM
Sold V-Ultra Fuses with V-tails stumper Aircraft - Sailplanes (FS/W) 4 Aug 24, 2005 12:52 PM
