Old Oct 21, 2009, 05:53 PM
nooobolocity is offline
Find More Posts by nooobolocity
the speed of gravity.
U.K.
Joined Jul 2009
Brushless RPM Sensor-Cable length?
Hi, I'm doing an "electric tail" conversion on a Maxi-Joker 2 and I'm going to use two rpm sensors. I've no problem with the modification to the secondary connection.
My question is that the conversion is putting the motor out at the end of the tail boom...it's a long way from the v3 logger. I'm going to run the sensor wire to the ESC inside the tail boom out the end where the ESC is.
Is the sensor going to work with a long cable run like this?
Thanks.
nooobolocity is offline Find More Posts by nooobolocity
Old Oct 21, 2009, 08:14 PM
ragamofyn is offline
Find More Posts by ragamofyn
Victoria, Canada
Joined Feb 2009
Jumping in ahead of Bill...
I'd recommend keeping the "live" connections between the brushless motor and sensor short and extending the "data" cable between the sensor and eLogger. i.e. place the sensor with the motor (and run the interface cable all the way back to the eLogger), rather than keeping the sensor with the eLogger and extending the "To Motor 1" and "To Motor 2" wires.
My logic here is that the motor-to-sensor connection is far more sensitive to stray EMI noise (that would show up as erroneous spikes or dips in your recorded RPM data) than the sensor-to-eLogger connection, which I bet is probably pretty robust and resistant to interference.
ragamofyn is offline Find More Posts by ragamofyn
Old Oct 22, 2009, 06:48 AM
U.K.
Joined Jul 2009
adding chokes?
Thanks for your reply.
Since these are naturally sensitive to emi I question why we do not put chokes on them? I mean, it can't hurt to have them.
Old Oct 22, 2009, 07:14 AM
flarssen is offline
Find More Posts by flarssen
Son, Norway
Joined Sep 2004
I would choke the signal itself (kind of emi).
(Which leads me to think that it might be better to cut the wire instead of coiling it up as I do now ).
Fred
flarssen is offline Find More Posts by flarssen
Old Oct 22, 2009, 02:34 PM
Victoria, Canada
Joined Feb 2009
excellent question about the chokes: I guess some testing is in order. good luck! :-)
Old Oct 22, 2009, 02:38 PM
U.K.
Joined Jul 2009
Fred
Where do you find the information that it would choke the signal? I would not even worry about this as the advantage of stopping noise is the greater benefit.
If you use a round circle choke, the each time you pass the wire around the choke and through the hole your doubling the effect of it's power. So it is a good way to shorten a long wire.
Discussion Brushless RPM Sensor/Tach from Eagle Tree Systems, LLC billpa Eagle Tree Systems 57 Apr 24, 2009 10:19 AM
Sold Eagle Tree eLogger V3 + Brushless RPM sensor oh_my_god Aircraft - General - Miscellaneous (FS/W) 4 Jun 05, 2008 09:31 PM
Question Brushless RPM Sensor Accuracy SpeedVision Eagle Tree Systems 13 May 06, 2008 07:04 PM
Discussion Brushless RPM Sensor FAQ billpa Eagle Tree Systems 0 Mar 05, 2008 08:47 PM
Discussion Brushless RPM Sensor/Tach from Eagle Tree Systems, LLC billpa Product Announcements 13 Dec 28, 2006 03:50 PM
