Old Jun 29, 2011, 07:00 AM
xandrios is offline
Find More Posts by xandrios
Steven
xandrios's Avatar
United States, CT, East Hartford
Joined May 2010
Hey jstern429,
it looks like you found the right pin.
Pin D1 is the voltage control pin.
Use one of the 5v pins for final voltage adjustment. 5v pin to resistor to Pin D1.
The 12v out was just for testing.
This will change the value of the resistor but should run cooler.
This also helps in voltage regulation
xandrios is offline Find More Posts by xandrios
Old Jun 29, 2011, 08:21 AM
merzie is offline
Find More Posts by merzie
Joined Jul 2009
Are there voltage control pins on the Compaq/HP ESP114?
merzie is offline Find More Posts by merzie
Old Jun 29, 2011, 10:41 AM
jstern429 is offline
Find More Posts by jstern429
United States, CA, Livermore
Joined Dec 2009
Cool, thanks for the help. Jeff
jstern429 is offline Find More Posts by jstern429
Old Jun 29, 2011, 03:54 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey merzie,
try post #599 to find the voltage control pin(if there is one) on the ESP114 PS.
Pin C5 might be a possible candidate.
Hope this helps.
Old Jun 29, 2011, 06:42 PM
merzie is offline
Joined Jul 2009
Thank u. It seems to be referring to another power supply...
Old Jun 30, 2011, 12:31 AM
fly_right is offline
Find More Posts by fly_right
fly_right's Avatar
USA, NC, Stanley
Joined Sep 2008
I have 3 Dell EP071298 with internal fan. Rated at 320 watts. If these are worth converting would someone be interested in offering assistance so I can convert one for me and a friend of mine? I'd be glad to send them the last power supply in exchange for their help.
I also have 2 DPS-300HB rated at 289Watts max. No internal fans. Any help with those would be appreciated as well.
Lee
fly_right is offline Find More Posts by fly_right
Old Jun 30, 2011, 01:11 PM
merzie is offline
Joined Jul 2009
since it's lower power it sounds like a normal atx psu...
just touch green wire to ground with a load connected to the 12V line and see if it works. some require loads on all lines
Old Jun 30, 2011, 04:20 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
No, they are hot swap server supplies. Needs the control pin treatment.
jj604 is online now Find More Posts by jj604
Old Jun 30, 2011, 10:01 PM
fly_right's Avatar
USA, NC, Stanley
Joined Sep 2008
So, they're not very desirable? They only deliver 40Amps, I guess?
jj, what is the, (pause, play scary music) "control pin treatment"? Mwahaha
Old Jul 01, 2011, 12:31 AM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Basically what this thread is all about. By connecting the pins that stick out the back in the correct way you can fool these supplies into thinking they are sitting in their server and should be supplying power.
This thread has accumulated a lot of info from folks who by trial and error or because they are smart have figured out which pins need to be connected together to make the power supply turn on safely. They won't work without some sort of control pin connections because they think they have been unplugged from the chassis or something is wrong.
Old Jul 01, 2011, 12:27 PM
xandrios is offline
Steven
xandrios's Avatar
Joined May 2010
Hey fly_right,
try post 541 and 542 for that DPS-300HB. It might help.
Old Jul 01, 2011, 08:22 PM
merzie is offline
Joined Jul 2009
Could I have luck trying the method in 599 to find voltage control pins? Is it just a matter of grounding each pin with a resistor, one by one, until I see a significant change in the voltage?
Old Jul 01, 2011, 08:57 PM
fly_right's Avatar
USA, NC, Stanley
Joined Sep 2008
Thank you for your help xandrios.
That turned out to be the Green and White wire on the DB15. I put a 1k resistor inline and a multimeter on the +12 Yellow and GND Black. I didn't get a voltage reading but I did hear a soft click in the PS. The green LED didn't illuminate. And all the magic smoke stayed inside. :-)
If you aren't too busy, I'd be glad to try your next suggestion.
BTW, assuming you get this rascal running, can I just tie the Yellow and +5 Red together for +17 volts. Wouldn't that also give me about 77Amps?
-Lee
Old Jul 01, 2011, 11:02 PM
jj604 is online now
ancora imparo
jj604's Avatar
Joined Jul 2005
Lee don't do that!
If you tie the +12 and +5V together the supply is trying to drive 12V into the 5V supply. The only way to add 12V to 5V is with two supplies and isolating them so that either their supply grounds are not connected or their output grounds are not connected.
-Lee
Old Jul 02, 2011, 06:47 AM
fly_right's Avatar
USA, NC, Stanley
Joined Sep 2008
Well, that shows my inexperience, doesn't it? LOL Thanks for helping me avoid lots of sparks. Is there a way to get higher voltage besides turning the POTS that was mentioned earlier?
Thank you, jj for helping me avoid a sparkling display at my workbench. :-)
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 08:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 12:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 04:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 02:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 02, 2002 11:31 PM
