Old Sep 05, 2002, 04:06 PM
bob shamblin is offline
Find More Posts by bob shamblin
Joined Aug 2002
TM help please
I built a standard Tm kit , added 1/16 balsa on one side of the struts, and use a 1047 prop. I am using 150mah nicads. My problem seems to be not enough power to climb. I hand launch and fly about shoulder high and descend with each turn not being able to climb back up. Any suggestions.
bob shamblin is offline Find More Posts by bob shamblin
Old Sep 05, 2002, 04:13 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
Switch to a 9x7 prop. Also, you didn't mention how many cells you're flying? 6 Nicad cells will give you marginal performance. 7 cells should be fine.
Tres Wright is offline Find More Posts by Tres Wright
Old Sep 05, 2002, 04:22 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Another thing, forgive me for mentioning it but it just happened to me a couple weeks ago
Check the prop to make sure it's not backwards. The raised letters are on the front.
Like Tres said the 9x7 is the best prop.
If you're going to get more batteries check out the 370mah 7 cell packs from www.aeromicro.com They are a great compromise between weight, power and duration.
BC
Basketcase is offline Find More Posts by Basketcase
Old Sep 05, 2002, 04:35 PM
AirWarriorBelgy is offline
Find More Posts by AirWarriorBelgy
Captain Carnage says......
AirWarriorBelgy's Avatar
Seminole (St Pete.), Florida/ Seminole Crash Fest
Joined Jun 2002
what more can be said
it's your power and prop size thats ailin yur plane
Belgy
AirWarriorBelgy is offline Find More Posts by AirWarriorBelgy
Old Sep 05, 2002, 04:42 PM
Bluegoo is offline
Find More Posts by Bluegoo
Mountain View, CA.
Joined Sep 2002
Bob,
A problem I encountered when I first started was that the battery wasn't charged fully. I thought it was but it wasn't, and I would barely be able to get off the ground. Same thing happened to my buddy the other day. Make sure its charged good.
The 150 Nicads are no good. Go with the 7 cell 370 Nihms. The difference is night and day.
Bluegoo is offline Find More Posts by Bluegoo
Old Sep 05, 2002, 05:24 PM
stuart warne is offline
Find More Posts by stuart warne
Durafly Brand Manager
stuart warne's Avatar
Hong Kong, Hong Kong Island, Central And Western District
Joined May 2001
Yeh i'd agree. I fly my TM on a 7cell pack of 300 nimh's and a 9x7 prop, seem to be the perfect combination, always getting 8 min's plus and with power to spare too Here's my TM on one of those rare British day's, it was nice
stuart warne is offline Find More Posts by stuart warne
Site Sponsor
Latest blog entry: Savex Spitfire Progress
Old Sep 05, 2002, 07:08 PM
Drewmotion is offline
Find More Posts by Drewmotion
Drewmotion's Avatar
Mission Viejo, CA
Joined Jul 2001
Sounds like the prop
That's exactly the way my Moth performed when I tied a 10x4.7 prop. I had just broken my last 9x7, so I decided to give the 10x4.7 a try, very poor performance. Good Luck!
Drew
Drewmotion is offline Find More Posts by Drewmotion
Old Sep 05, 2002, 07:51 PM
Joined Aug 2002
thanks
Thanks for the help. Went to the field to try again and managed to get acouple minutes flight out of the 6cell 150s with the 1045 using alot of down trim.
I've never used nimh cells. whats the charge time? I saw a table that listed 1.2 hrs for fast charge.
Old Sep 05, 2002, 08:14 PM
Joined Jun 2002
nimh charge
i use eflight 300 mah nimh on an el cheapo eflight fast charger
and get a good full charge in 30 minutes on my supernova i get
a good charge in about 42 minutes
my durations are longer on the el cheapo...go fiugure
i get about 8 to 10 minutes with great power and another 5 to 8 minutes at cruise around at shoulder height power
all the above times are based on throttle conservation
on no wind days just cruising at 2/3 throttle i have acheived 18 to 20 minutes duration
Belgy
Old Sep 05, 2002, 09:56 PM
Blazin_Jason is offline
Find More Posts by Blazin_Jason
Blazin_Jason's Avatar
Canada, BC, Nanaimo
Joined Jul 2002
My Tiger Moth came standard with the 10x4.7 prop. It performed very well running on 6 270mAh NiCads. Now I use the EPS-100 and 7 350mAh NiCads. Sure makes this little plane more fun to fly.
Blazin_Jason is offline Find More Posts by Blazin_Jason
CG on TM? A little help, please. george l Parkflyers 7 Aug 25, 2002 10:13 AM
Putting a new reciever in TM problem...please help! cincyfler Parkflyers 5 Aug 12, 2002 07:58 PM
HELP PLEASE, TM Conversion! Magna Scale Kit/Scratch Built 28 Jul 14, 2002 09:05 PM
FMS HELP PLEASE!!!!! PunkerTFC Electric Plane Talk 6 Jul 07, 2001 04:40 PM
can anybody in Europe help please Theuns Electric Plane Talk 1 Jun 04, 2001 01:46 PM
