Old Oct 18, 2004, 10:37 PM
viper6 is offline
Find More Posts by viper6
Ontario, Canada
Joined Nov 2003
What Plane for a Graupner 700 BB Race Motor
I obtained a Graupner 700 BB Race Motor as part of a trade and I was wondering what sort of plane this motor would be suited for. I have several light electrics and I was hoping to build something in the 3-5 lb. range. Is this motor suitable for a heavy plane?
viper6 is offline Find More Posts by viper6
Old Oct 19, 2004, 05:07 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Yes. 700's in general will do about 300W. Not sure of best pack/gears/prop for this one, but 10 cells looks a good starting point from the KV, or 3s LIPO. Gear and prop for maybe 25-30A?
On higher voltages it may do better. Suggest maybe 16-18v would be good at around 20A or so.
Something like 9x6 on 2.3:1 on 10 cells. looks in the frame. Better on bit higher gearing
Loks nice on 5s LIPO and 3.6 box and maybe 10x7/9x6 prop.
Old Oct 19, 2004, 05:13 AM
ChrisP is offline
Find More Posts by ChrisP
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
I used to fly a 2,0 kg (4 1/2 lbs) 500 sq ins electric sailplane with a Speed 700 Turbo 9.6v on 11x1700 cells direct drive with a 9.5x5 prop. So you're right on the money with your weight estimate.
If I remember correctly, the Race turns faster per volt than the Turbo, so it's probably more suited to a gearbox. I think that Graupner still stocks a gearbox for the 700 series.
ChrisP is offline Find More Posts by ChrisP
Old Oct 19, 2004, 05:16 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Thers a belt drive from graupner at the lest. and I think Tom Hunts belt drives also fit..yes - see http://www.modelairtech.com/belt.html
Nice beam mounting there as well.
Old Oct 19, 2004, 07:21 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I recently got a Graupner 700 with gearbox (gears, not belt) from Gliders (UK). It powers my Flair Magnatilla (about 5.5 lbs) on 12 x GP3300 drawing about 35A max. on a 14x7 prop.
abenn is online now Find More Posts by abenn
Old Oct 20, 2004, 03:38 AM
ChrisP is offline
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
Yes, according to the published test results I have, 35A seems to be the appropriate current for operating a Speed 700.
I was always impressed by how smoothly this motor runs. However with the availabilty of outrunners with less than half the weight that can swing large props at the same power level, I've sadly relegated my Speed 700 to the spares box.
Old Oct 20, 2004, 06:32 AM
abenn is online now
Joined Jul 2004
All in good time, ChrisP! That was my first e-conversion, and I didn't want to splash out on an outrunner before I was convinced that e-power is the way to go. Now I am convinced, and I'm putting an outrunner into my second conversion.
Old Oct 20, 2004, 07:33 AM
viper6 is offline
Ontario, Canada
Joined Nov 2003
Thanks for the suggestions!
Old Oct 20, 2004, 07:48 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Gimme a lerge ferrite lump and LIPOSagainst a more expensive brishless on nickels anyday.
ESPECIALLY for WWI short nosed types.
Old Oct 20, 2004, 01:26 PM
Norman Greene is offline
Find More Posts by Norman Greene
Dublin, Ireland
Joined Mar 2002
You have a point there.
In a .25 size fighter where a Speed 600 with gears will do, but is a little slow, the direct drive Speed 700 really shines. Power is more readily available when you ask for it. And the fighter type model asks for that type of flying.
You can pull high amps and really move, 9 x 6 is middle ground, 9 x 8 sings.
Bad news is the amps .. duration with the lighter geared S600 is 50% extra over S700.
For rearward CG problems, that S700 really fixes things ....
Norman in Dublin
www.greenhobbymodel.com
Norman Greene is offline Find More Posts by Norman Greene
What Plane ??? for Astro 020 motor FiremanJoe 3D Flying 0 May 26, 2004 06:50 PM
What plane for old Zagi motor/batteries? ANYTHING? Something? :) Tram Foamies (Kits) 27 Apr 03, 2003 06:55 PM
FS - WoMeTec Mini 480 DF & Graupner 480 BB Race motor (both NIB) joegib Aircraft - Electric - Airplanes (FS/W) 6 Sep 28, 2002 08:56 AM
Gear/prop combo for speed 480 BB Race motor Kjelli Foamies (Kits) 17 Sep 20, 2001 08:37 AM
Help! How do I retime my 6327 Graupner Speed 480 race motor for a gearbox. Joe Elston Electric Plane Talk 6 Apr 20, 2001 11:56 AM
