Old Apr 07, 2015, 02:05 PM
Nappy Gnome is offline
Find More Posts by Nappy Gnome
Nappy Gnome's Avatar
Joined Feb 2015
Naze32 - RC Rate vs. Roll and Pitch Rate
What is the difference between RC Rate (on the screen with the RC Expo), and Roll and Pitch Rate?
Does RC Rate control roll, pitch, AND yaw rates while Roll and Pitch rate just controls the rate of the Roll and Pitch?
I'm trying to set up my FPV racer quad to do flips while in Horizon mode. I need to bump up the rates a bit. Just want to understand what the numbers I'm changing will actually do.
Any ideas?
Nappy Gnome is offline Find More Posts by Nappy Gnome
Old Apr 07, 2015, 02:30 PM
waltr is offline
Find More Posts by waltr
Team WarpSquad
United States, PA, Doylestown
Joined Jan 2014
RC rate is linear and is for sticks near the center (P&R). RC Expo puts a expo curve on the RC Rate.
P/R Rate is a 'super' expo that increases effective throw when sticks are farther from center.
Neither changes the Yaw rate. the Yaw rate does this independently.
I adjust RC rate with some expo for a nice fell and easy leveling (I only fly ACRO mode) with sticks near center. Then increase R/P rate for rolls/flips at the speed I desire.
I do have much higher rates on my LOS Acro quads than on my FPV quads.
waltr is offline Find More Posts by waltr
Old Apr 08, 2015, 01:57 PM
Joined Feb 2015
What RC rate and R/P rate do you have for your LOS quads? Mine is currently only LOS until I can afford a nice FPV setup.
Old Apr 08, 2015, 07:19 PM
waltr is offline
Team WarpSquad
Joined Jan 2014
On my Warp Quads:
Mild aerobatic for relaxed flying:
RCRate = 1.80
RC Expo = 0.40
P/R Rate = 0.3
Yaw = 0.30
Hot Aerobatic:
RCRate = 2.10
RC Expo = 0.30
P/R Rate = 0.6
Yaw = 0.45
I setup these in two Profiles so I can easily switch with a stick command.
For my FPV mini-Hs (very mild):
RCRate = 1.15
RC Expo = 0.45
P/R Rate = 0.5
Yaw = 0.25
Old Jul 01, 2015, 11:13 AM
Shufty is online now
Find More Posts by Shufty
Multirotor Bloodhound
Shufty's Avatar
Australia, WA, Perth
Joined Apr 2013
Originally Posted by waltr View Post
On my Warp Quads:
RCRate = 1.80
RC Expo = 0.40
P/R Rate = 0.3
Yaw = 0.30
Hot Aerobatic:
RCRate = 2.10
RC Expo = 0.30
P/R Rate = 0.6
Yaw = 0.45
RCRate = 1.15
RC Expo = 0.45
P/R Rate = 0.5
Yaw = 0.25
Hi Waltr,
Can I assume that RC Expo of 0.45 equals 45% ?
Shufty is online now Find More Posts by Shufty
Old Jul 01, 2015, 12:16 PM
waltr is offline
Team WarpSquad
Joined Jan 2014
Originally Posted by Shufty View Post
Hi Waltr,
If the Max Expo is 1.00 then 0.45 is 45% of the maximum Expo.
But since this creates an exponential curve that is applied to the stick movement modifying the value send to the FC's control loop what does 45% mean anyway?
I never bother trying to relate most of the FC values into anything real world. Just whether the value should be smaller or bigger.
I adjust the Rates and Expos by feel.
If too touchy near center stick then increase the RC Expo.
If the copter does not move (roll/pitch) fast enough for the stick input then I increase the RC rate.
If I put too much Yaw stick in during turns then I decrease the Yaw Rate.
For aerobatics I adjust the RC/Yaw rates and Expo for 'normal' flying/hovering. Then increase the R/P Rates to get flips and rolls as fast as I desire.
Old Jul 01, 2015, 11:33 PM
Shufty's Avatar
Joined Apr 2013
Awesome, that explains a few things, I'll give it a shot
I guess I'm just struggling trying to find a good mix between avoiding overcontrol of the quad and being able to do fast axial rolls.
Old Jul 02, 2015, 07:34 AM
waltr is offline
Team WarpSquad
Joined Jan 2014
Yep, it does take some experimentation to find the combination you like.
The higher you set RC rates the more Expo is desired to keep the sticks smooth near center.
Old Jul 02, 2015, 06:54 PM
Shufty's Avatar
Joined Apr 2013
I'm also assuming you should set expo on the radio, only on the FC?
Old Jul 02, 2015, 09:01 PM
waltr is offline
Team WarpSquad
Joined Jan 2014
Typically NO expo in the radio, only set Expo in the FC.
Old Jul 02, 2015, 09:56 PM
Shufty's Avatar
Joined Apr 2013
Awesome, thanks for the clarification!
Discussion Rolling Right vs Rolling Left Idoitall 3D Flying 19 Apr 06, 2015 12:36 PM
Help! Mission Planner RC Feel Roll/Pitch and Firmware Update girarcat Multirotor Electronics 5 Feb 12, 2015 01:04 PM
Help! Naze32 Pitch/Roll Help dancingevilgeni Multirotor Electronics 1 Dec 29, 2014 06:44 PM
Discussion Which Mode? Rate vs. Self-Leveling vs. Rate w/ Self-Leveling Pyrock Multirotor Talk 1 Dec 05, 2014 08:29 AM
