Old Sep 13, 2014, 03:16 PM
maxopie is offline
Find More Posts by maxopie
Joined Sep 2014
My FPV Quad Parts and Help
I have gathered a list of all of my quad parts. It would really help me out if someone could look over the parts list to make sure this is EVERYTHING I will need in the correct quantity. If anyone has any experience with any of these parts, or any recommendations that would be great (I am trying to stay under 700)(I also already have a go pro and monitor)Thanks!
Parts List:http://i.imgur.com/P24JJZs.png
Ecalc Page:http://i.imgur.com/Cxkn4gQ.png
A couple of other questions: - Do I need only one UBEC for my OSD, Flight controller, and Gimbal? Do I need 3?
Is my transmitter good enough (seems too cheap?)
Do I need the spacers (or in that size)
Will the flight controller tell the motors to spin opposite directions or do I need to buy two of each like props.
Links to all parts: http://www.hobbyking.com/hobbyking/s...pter_KIT_.html
http://www.hobbyking.com/hobbyking/s...r_Mode_1_.html
http://www.hobbyking.com/hobbyking/s...PS_Module.html
http://www.hobbyking.com/hobbyking/s...ps_module.html
http://www.hobbyking.com/hobbyking/s...arehouse_.html
http://www.hobbyking.com/hobbyking/s...ion_Board.html
http://www.hobbyking.com/hobbyking/s..._ESC_2_6S.html
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
http://www.hobbyking.com/hobbyking/s..._3S1P_25C.html none http://www.hobbyking.com/hobbyking/s...n_1_pair_.html
http://www.hobbyking.com/hobbyking/s...cer_10pc_.html
http://www.hobbyking.com/hobbyking/s...cer_10pc_.html http://www.hobbyking.com/hobbyking/s...arehouse_.html
http://www.hobbyking.com/hobbyking/s...PS_Module.html http://www.hobbyking.com/hobbyking/s...ontroller.html
http://www.hobbyking.com/hobbyking/s...tx_rx_set.html
http://www.hobbyking.com/hobbyking/s...0pcs_bag_.html
http://www.hobbyking.com/hobbyking/s...mtr_black.html
http://www.hobbyking.com/hobbyking/s...ch=bullet%20to
maxopie is offline Find More Posts by maxopie
Old Sep 15, 2014, 09:23 AM
Gijoe714 is offline
Find More Posts by Gijoe714
United States, CA, Porterville
Joined Aug 2014
I have one answer for you sorry I couldn't help with more. Yes you will need to by both clockwise and counterclockwise spinning props. Motors will spin the way they are wired. And to change the orientation of them just swap two of the three wires coming off the esc's
Gijoe714 is offline Find More Posts by Gijoe714
Old Sep 17, 2014, 04:48 PM
SirRexAlot is offline
Find More Posts by SirRexAlot
United States, WA, Vancouver
Joined Jun 2013
That radio is cheap. Get this:
http://hobbyking.com/hobbyking/store...arehouse_.html
It's only $69, has a full gui for adjusting things, it will keep you satisfied for a long while as-is, you can upgrade if you want telemetry or LRS down the line, you can even flash it with custom firmware for more flexibility. Plus the one you linked to is on backorder anyways.
You do see that your eCalc setup says you're going to have a hover time of just 5.1 minutes? My two quads do 2 times and 3 times that, and I still feel it's too short. You might want to see if you can lighten it up a bit.
SirRexAlot is offline Find More Posts by SirRexAlot
Old Sep 17, 2014, 04:57 PM
KrisRoberts1121 is offline
Find More Posts by KrisRoberts1121
Who put that tree there??
KrisRoberts1121's Avatar
United States, NY, Munnsville
Joined Sep 2014
I second the turnigy 9x. Its a great transmitter. I don't think I'll need to upgrade for a while. All the bells and whistles I need for now. I'm only going to be flying quads and wings, so this transmitter is great for my applications.
KrisRoberts1121 is offline Find More Posts by KrisRoberts1121
Discussion need help build my first quad for long range fpv adam88888 Multirotor Talk 25 Sep 02, 2014 10:22 PM
Help! help with choosing best parts for super-budget FPV quad! Power Max Scratchbuilt Multirotors 3 Aug 27, 2014 08:27 PM
Discussion help with choosing best parts for super-budget FPV quad! Power Max Multirotor Electronics 4 Aug 21, 2014 10:19 AM
Discussion My fpv quad needs help godwisper FPV Talk 1 Sep 20, 2012 02:06 PM
Help! Could use some help with my FPV/eagletree quad setup. daign FPV Talk 2 May 22, 2011 07:46 PM
