Old Sep 11, 2013, 10:54 AM
bwill6 is offline
Find More Posts by bwill6
United States, CA, Tehachapi
Joined Jun 2011
Yup. Mine are 12mm servos and the topdrive is buried nicely
bwill6 is offline Find More Posts by bwill6
Old Sep 11, 2013, 11:55 AM
jbarnhardt is offline
Find More Posts by jbarnhardt
jbarnhardt's Avatar
United States, WA, Seattle
Joined May 2011
Originally Posted by JimZinVT View Post
Ordering from CST, The price of CF fabric doesn't really improve until you get to the 5.7 oz weight. Too heavy for a tip patch? ACP seems to charge double what everyone else is asking and no one else even sells the lightweight fabrics we want. So CST looks like the only one-stop source here in the US?
Jim and/or any others who are working on bagging your first wing - I agree with Brandon that a glass doubler is likely to suffice. Having said that, I have plenty of lightweight (~2oz) carbon off-cuts and would be happy to send you enough to do a top and bottom surface tip doubler if you send me a stamped, self-addressed envelope. PM me for address info.
-John
jbarnhardt is offline Find More Posts by jbarnhardt
Latest blog entry: Latest creation...
Old Sep 11, 2013, 04:19 PM
JimZinVT is online now
Find More Posts by JimZinVT
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
Is the purpose of the tip patch to tie the blade to the spar system? To beef up the tip against bending or twisting forces from an imperfect launch? Both? Just trying to understand the mechanics.
Is the tip patch typically just on the blade side, or on both tips to try and keep the weight balanced?
JimZinVT is online now Find More Posts by JimZinVT
Old Sep 11, 2013, 06:24 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
What is usually meant by the term "pre-facing" of aileron cut outs?
Is it just some extra sking reo in the form of carbon tow or uni-carbon?
Or is the actuall drag spar face and control surface LE "faced" with something prior to bagging?
Jim.Thompson is offline Find More Posts by Jim.Thompson
Old Sep 11, 2013, 07:31 PM
GaryO is offline
Find More Posts by GaryO
United States, AZ, Arizona City
Joined Sep 2001
Rather than describe the pre-facing in detail, do a search on Google that starts out with "RC Groups ... and you will finds several really good descriptions of the process.
Basically, it entails joining the top and bottom skind of the wing and flaps with fg to stiffen the flaps and prevent delams of the hinge area.
Gary
GaryO is offline Find More Posts by GaryO
Old Sep 11, 2013, 07:51 PM
bwill6 is offline
Joined Jun 2011
You nailed it. The purpose is to provide a load path from the blade to the spar, strengthen the tip against strong bending/twisting, and to increase durability. I like to make tip doublers on both sides for durability. Haven't built one without tip patches on the non-throwing side so I can't tell you how much of a difference it makes in balance.
Old Sep 11, 2013, 09:31 PM
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
As I understand it, you're wrapping the trailing edge of the wing and the leading edge of the aileron with light fiberglass before bagging. 3M77ed on as you would a leading edge strip. Makes for a stiffer aileron and helps prevent flutter. But one of the benefits Bwill6 mentioned for this thicker HM51 airfoil is no need to face....the thickness makes a stiffer structure.
Old Sep 11, 2013, 09:57 PM
Joined Aug 2008
Pre-facing explained.
Originally Posted by GaryO View Post
.........................., do a search on Google that starts out with "RC Groups ... and .................................................. ............
Gary
Found this excellent drawing and description of the process courtesy Dr. Mark Drela.
http://www.charlesriverrc.org/articl...DFs/hinges.pdf
Thanks.
Old Sep 11, 2013, 10:02 PM
GaryO is offline
Joined Sep 2001
Good that you found Mark's posts.
Also look for a series of posts by Gerald )GT) and Phil Barnes, maybe in the original Zone thread on an alternate way to do it. I find it much easier to do.
Gary
Old Sep 11, 2013, 10:03 PM
Joined Aug 2008
.................. But one of the benefits Bwill6 mentioned for this thicker HM51 airfoil is no need to face....the thickness makes a stiffer structure.
I don't quite "get" this rationale.
I'll be pre-facing anyway I think. I tend to like to do anything and everything I can on the bench to avoid later possibility of progressive failure on the flying field etc.
Besides, after just finding another elegant build technique, I can't put off trying it out!
I'm starting to get excited about building a DLG. I'm packing the car now for a week long slopefest! Will be starting the build when I return.
Old Sep 11, 2013, 10:05 PM
Joined Aug 2008
Gary
I found the ones by Phil (I think) and have book marked them for reading them when I return.
Good stuff! Isn't the internet fantastic?
Old Sep 11, 2013, 10:45 PM
Wazmo is offline
Find More Posts by Wazmo
Duane
Wazmo's Avatar
No. VA
Joined Nov 2004
Another advantage of pre-facing, besides increased stiffness, is that the skins adhere much better at the hinge line and are less likely to peel or delaminate.
Wazmo is offline Find More Posts by Wazmo
Old Sep 11, 2013, 10:57 PM
Joined Aug 2008
For sure. All the sloper wings that I've built are faced, both vac bagged and moulded. However, they were done with "Q" cells/epoxy splooge on the bagged ones, and glass socking over drinking straws for the moulded ones.
But that is drifting off topic a bit..............
Old Sep 11, 2013, 11:15 PM
bwill6 is offline
Joined Jun 2011
Stiffness (both bending and torsional) is nonlinearly proportional to thickness of the wing. ie: as thickness goes up, stiffness goes way up. Flutter is caused by ailerons with poor torsional stiffness. Facing the ailerons closes the "torsional tube" that is the aileron, boosting stiffness by a ton. Thinner wings require it. This wing has thick enough ailerons that they are stiff enough to not flutter even without facing as long as you use a 40+ psi foam like Hiload 40 or 60. Like Wazmo said, another advantage of pre-facing is that it prevents delamination at the hinge line.
Old Sep 11, 2013, 11:48 PM
Joined Aug 2008
Originally Posted by bwill6 View Post
.............. another advantage of pre-facing is that it prevents delamination at the hinge line.
Its this advantage that is foremost in my mind and will motivate me to face mine.
Idea New wing flap design - The FaTedev multi-flap stonerscolony Sailplane Talk 0 May 08, 2013 12:55 PM
Video My NEw FlYIng wiNG DEsign FLiGHT essadiq Flying Wings 1 Apr 29, 2013 11:29 AM
Discussion Will my new wing design FLY or DIE? Opinions and Advice for noobs. Nucc10 Flying Wings 5 Jan 31, 2013 01:57 AM
Discussion check out my new high wing design derpron Foamies (Scratchbuilt) 8 Jan 18, 2013 04:55 AM
Discussion Easy Glider Wing Design? ForeverFlying Sailplane Talk 18 Dec 01, 2010 02:59 AM
