Old Aug 22, 2013, 03:20 AM
F.Omenal is offline
Find More Posts by F.Omenal
F.Omenal's Avatar
Somewhere in France
Joined Oct 2008
De rien,
At this time, i have only 2 protocoles (DSM2, Nine Eagle) on it, for many raison,
- i have only DSM2 and Nine rx. so for testing it better.
- Arduino is only 8bits, and for some protocole, some hard calcul is need.
- At 16mhz for the best speed, it very very sort in time to send all the frame to the tx modul, and use also the ppm in.
- i am working on the MicrORC (a small TX for my kid and me).
in some week, i will probably fuse the 2. (micro TX and multiprotocol)
But if somebody can make more with it, why not.
actuelly i test it with a new version for having more CPU time. and why not test Walkera or frsky .
(i am not sur for frsky, because the tx modul is a cyrf for dsm2 and nine, but CC2500 for frsky..
F.Omenal is offline Find More Posts by F.Omenal
Old Aug 24, 2013, 05:24 AM
mono is offline
Find More Posts by mono
mono's Avatar
Joined Aug 2008
tres bien
(learned French in high school for 4 years, not used since then, long time ago).
thanks for the reply to my questions.
Very nice! hope you have opportunity to post info on your progress.
It won't be me due to zero programming skill, maybe someone will see the potential in a multi protocol device of this type.
actuelly i test it with a new version for having more CPU time. and why not test Walkera or frsky..... but CC2500 for frsky.
yes, another one to solder in, take up more space. I'm not sure how much frsky coding has been done in deviation at this time. But if you got Walkera/Devo working as well, that would be great achievement in itself, the first as far as I know.
Alernative to cc2500/frsky is a7105/flysky/hubsan, very popular.
But as you said, without other rx's can not test.
regards.
mono is offline Find More Posts by mono
Old Aug 24, 2013, 12:17 PM
F.Omenal is offline
F.Omenal's Avatar
Somewhere in France
Joined Oct 2008
thanck
if you want to see my MicrORC sofware you can go here:
MicrORCv10 (13 min 17 sec)
Old Aug 26, 2013, 11:10 PM
mono is offline
mono's Avatar
Joined Aug 2008
merci
vous êtes programmeur très qualifié
Using old nine eagles tx case for microrc?
the menu system you have is quite detailed, from what I could recognise in the video it covers everything very well. good work.
Old Aug 27, 2013, 01:47 AM
F.Omenal is offline
F.Omenal's Avatar
Somewhere in France
Joined Oct 2008
Originally Posted by mono View Post
merci
merci beaucoup.
but i am just a week-end hobbist programmer.
yes, i thinking about using the case tx from nine eagle. but i have a 3d printer, and i thinking about making a case too.
Old Aug 27, 2013, 03:53 AM
mono is offline
mono's Avatar
Joined Aug 2008
aah... a 3D printer, I was wondering how you made the neat case for the module, whether you had cnc/milling machine. Module case looked good enough to be off the shelf commercial product.
When I have completed the things I am working on now (flysky/hubsan modules), I would like to see if I can make your module, as an interest project. As I have radios with those protocols, it is not a necessity for me, but would like to do it anyway.
As you have kindly provided the source code, perhaps an opportunity to start learning some arduino programming. Never too late in life to try learning new things.
Old May 09, 2014, 07:32 AM
F.Omenal is offline
F.Omenal's Avatar
Somewhere in France
Joined Oct 2008
Hi mono,
if you see this post, go to see my small TX project. it is down now . http://www.rcgroups.com/forums/showthread.php?t=2116280
some update may be need but i use it with my planes.
i will recode this project to have more possibilities,
Old Sep 07, 2014, 10:05 PM
John michel is online now
Find More Posts by John michel
Joined Jun 2013
hello F. O
this topic need to keep post
currently ,almost all protocol seem clearly . You can update new version by atmega644 ? It is full function ,pin ......
John michel is online now Find More Posts by John michel
Old Sep 08, 2014, 02:02 AM
F.Omenal is offline
F.Omenal's Avatar
Somewhere in France
Joined Oct 2008
hello John,
nice to see you again.
i have a lot of work on another project for now, but i make some little work on this project to.
I test more fuctionnality on my TX on see if i have trouble with my protocol.
For now, all work perfect, but, i need more test.
Thx
Old Sep 08, 2014, 03:48 AM
Joined Jun 2013
that sound good .
thanks
Old Oct 27, 2014, 01:38 PM
nikki5 is offline
Find More Posts by nikki5
Joined Sep 2014
i need my taranis to bind to walkera/devo....Can your project solve that?
nikki5 is offline Find More Posts by nikki5
Old Oct 28, 2014, 12:37 PM
F.Omenal is offline
F.Omenal's Avatar
Somewhere in France
Joined Oct 2008
sorry but not yet.
Help! 3 Channel Arduino DSM2 Surface Transmitter Project Nactan DIY Electronics 11 Jun 05, 2013 12:10 PM
Discussion Arduino project -> Multiscope F.Omenal DIY Electronics 10 Apr 26, 2013 01:51 PM
Discussion Arduino project to build autopilot controlled RC plane! Ecibob Electric Plane Talk 2 Apr 25, 2011 10:17 AM
Discussion Arduino open source autopilot project TheRCEdge Aerial Photography 3 Jan 28, 2011 02:01 PM
