Old Jan 29, 2013, 03:04 PM
Jon Snow is offline
Find More Posts by Jon Snow
You know nothing....
Jon Snow's Avatar
Joined Sep 2011
Question
Mixing epoxy brands.
I've been using Devcon ,mostly for tow spars.Needed more but lhs only had Zpoxy.
Normally I'd stand the nearly empty bottles to drain into the new ones.Am I safe doing this?
Stuart
Jon Snow is offline Find More Posts by Jon Snow
Old Jan 29, 2013, 04:21 PM
AUSELECTRIC is online now
Find More Posts by AUSELECTRIC
Joined Nov 2004
Different brands will likely have different chemical composition and I would not reccommend it.
Even mixing old and new resin may cause an issue with contamination as the old resin has aged
AUSELECTRIC is online now Find More Posts by AUSELECTRIC
Old Jan 29, 2013, 04:58 PM
Shedofdread is offline
Find More Posts by Shedofdread
Deniable plausibility
Shedofdread's Avatar
Derbyshire, UK
Joined Aug 2008
Stuart,
In a word 'no'. Or in a much longer phrase; 'please please please DON'T DO IT!' A/E has it right.
Hope you're well.
Shedofdread is offline Find More Posts by Shedofdread
Old Jan 29, 2013, 05:32 PM
Jon Snow is offline
Jon Snow's Avatar
Joined Sep 2011
Thanks guys.I thought I'd read it was a no no,but being a tightd old sod I thought I'd check.
I'm ok Rich,thanks for asking.I seem to get these bursts of build fever now and then,before fading back to my normal lethargic state.
How's yourself,any doings in the shed?
Stuart
Old Jan 29, 2013, 08:38 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
The Z-poxy "finishing resin" would perform better for tow spars than the Devcon.
wyowindworks is offline Find More Posts by wyowindworks
Old Jan 30, 2013, 04:56 AM
Jon Snow is offline
Jon Snow's Avatar
Joined Sep 2011
I thought about using that before I started.Should have done with hindsight.
Anyway I managed to str....etch the Devcon out,just layed the last one.Thanks for the advice.
Stuart
Motor heat and epoxy, do they mix? Kramer_87 Power Systems 4 Oct 09, 2003 03:10 PM
mixing epoxy with water citabria Foamies (Kits) 9 May 20, 2003 10:07 PM
How to strengthen the epoxy integrity??? Carbon mix/FG mix?? Magna Electric Plane Talk 5 May 20, 2003 06:46 PM
Mixing Epoxy aginzu Beginner Training Area (Aircraft-Electric) 11 Sep 18, 2001 11:56 PM
