Old Jan 09, 2013, 11:06 AM
WonderKing is offline
Find More Posts by WonderKing
WonderKing's Avatar
Indonesia, Jakarta
Joined Sep 2012
how actually do i set the right gain for gimbal
hi guys, i've been tweaking my naza for the gimbal compensation control. i'm bit confused where is the right gain for my gimbal. well my gimbal always overcorrecting on some high gain. but when i decrease it. the gimbal delay a bit. is there something wrong with my gain? or it's time to get some decent gimbal controller
WonderKing is offline Find More Posts by WonderKing
Old Jan 09, 2013, 12:08 PM
pug398 is offline
Find More Posts by pug398
VA
Joined Nov 2009
It is so relaxing to keep tweaking the settings trying to find the perfect one..ok so I am lying about that part but it is still interesting . One thing other than changing the fc is to put a programmable bec on the servos. Set the highest safe voltage the servos will handle and then turn up the gain until it just overcompensates and then start dropping the bec voltage to slow the servo down. I was able to find a close match doing that with a gc that has limited programming options.
pug398 is offline Find More Posts by pug398
Old Jan 09, 2013, 12:14 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
Hawaii
Joined Feb 2003
It is quite difficult to adjust the gimbal movement with only one gain. You need a gimbal controller that give you the flexibility to adjust the servo speed, acceleration and travel range.
If you only have one gain adjust the gimbal to lag slightly and live with it.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Jan 09, 2013, 07:16 PM
Sniperp is offline
Find More Posts by Sniperp
FPV addict
Joined Mar 2011
Or switch out to a dedicated gimbal controller. Picking up a cheep multiwii based controller works awesome. I have a naza on a 800mm hex with a gaui crane 2 gimbal. Couldn't get it to run how I wanted no matter how much tuning I did, so I put on a quadrino basic, a board I had lying around, and use that as a gimbal controller. 15min later I now have an awesome gimbal controller. Very stable, fast, and still have tilt control.
Sniperp is offline Find More Posts by Sniperp
Question How do I stop my Yak 54 from rolling to the right when I do a loop? trevorcgross Beginner Training Area (Fuel) 16 Sep 17, 2012 01:37 AM
Discussion What does the gain actually do? Webheadfred Hoverfly Technologies 9 Dec 15, 2011 11:35 AM
Discussion what does the 'gain' on the 4in1 actually do comanche100 Coaxial Helicopters 7 Nov 16, 2008 12:58 PM
Discussion where do you have your gain setting for the BCPP at with g90 epoweredrc Micro Helis 8 Aug 31, 2007 12:00 PM
How do you set right trim switch for launch? John255 Hand Launch 2 Sep 13, 2005 06:08 PM
