Old Oct 11, 2014, 06:04 PM
irun4fundotca is offline
Find More Posts by irun4fundotca
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
they look like 2mm screws
hard to find at most hardware stores in this area
I get mine on ebay and they are still scarce
even worse when a small motor mount uses them and you drop one
irun4fundotca is offline Find More Posts by irun4fundotca
Old Oct 11, 2014, 06:27 PM
mikenmel08 is offline
Find More Posts by mikenmel08
I'd Rather Be Flying
mikenmel08's Avatar
United States, NC, Franklin
Joined Sep 2013
I actually have 2mm and they were too big..... Found some assorted ones that can hold it till the glue sets
mikenmel08 is offline Find More Posts by mikenmel08
Latest blog entry: New Machine in my arsenal
Old Oct 11, 2014, 09:55 PM
balesse is offline
Find More Posts by balesse
USA, WA, Seattle
Joined Oct 2005
What is the strength like on those thin walled parts like the spinner? I've been struggling with thin wall parts (less than 5 perimeters) where the layers will separate when I squeeze them. Maybe I'm expecting too much...
balesse is offline Find More Posts by balesse
Old Oct 11, 2014, 10:05 PM
Flying Wood For Fun
Joined Jan 2012
sounds like maybe you need to do a bed calibration for nozzle clearance
when I had mine to high the layers weren't blending (Fusing) together enough
the first layer should slightly appear flat topped on the first pass
Old Oct 12, 2014, 12:36 AM
saramos is offline
Find More Posts by saramos
Joined Feb 2007
Originally Posted by samc99us View Post
We have one and a Makerbot Replicator Dual. The Lulzbot is garbage IMO compared to the Replicator. The build plate is warped so badly that the max allowable adjustment can't compensate. Yes, we've printed the test prints and they came out OK. For ABS printing, you are joking if you aren't operating in an enclosed build chamber for larger prints. This is a problem for the Makerbot as well, so we generally print in PLA on that (Mkaerbot PLA is good up to 108degrees continuous duty operation). Further, the claims of the Lulzbots ability to print materials besides PLA and ABS are sort of a joke, at least if you order T-Glas and PC from the lulzbot site you need to bake the filament to remove water, otherwise you can't get a continuous extrusion of filament.
I also have experience with the Makerbot 2X, at least right now it blows the Lulzbot out of the water and is superior to the Replicator Dual for ABS prints. I'm not a huge fan of Makerbots practices or customer support, so we are looking at the Ultimaker 2 for a second printer to supplement. Any thoughts on that are appreciated.
Which model of the Lulzbot do you have?
Scott
saramos is offline Find More Posts by saramos
Old Oct 12, 2014, 12:49 AM
KC_703 is offline
Find More Posts by KC_703
United States, VA
Joined Sep 2013
That's happened to me on vertical walls. Went back to adjust the design so the thickness was a multiple of my nozzle.
KC_703 is offline Find More Posts by KC_703
Old Oct 12, 2014, 01:39 AM
Tartago is offline
Find More Posts by Tartago
Back to EDF
Tartago's Avatar
Joined Apr 2006
Nice mike!
What gear you plan to use on it?
Tartago is offline Find More Posts by Tartago
Old Oct 14, 2014, 06:37 PM
rcmaniac098202 is offline
Find More Posts by rcmaniac098202
United States, CA, Fremont
Joined May 2012
It's been quite some time since I posted the last picture of my Printrbot Simple - almost 6 months.
It's a different beast now. Here's what's different:
- 6in^3 (with possibly more Z height, but limited by wiring) build volume
- 6x6in heated bed
- E3D V5 w/ v6 heater block - can reach 300c+ temperatures just fine.
- Bowden assembly to reduce weight on moving parts.
- Metal Z coupling
- Fully belt driven
Original link: http://imgur.com/zlEXprN
rcmaniac098202 is offline Find More Posts by rcmaniac098202
Old Oct 24, 2014, 08:41 AM
helifrek is offline
Find More Posts by helifrek
UH-60 Blackhawk Mechanic
helifrek's Avatar
United States, TN, Clarksville
Joined Feb 2004
We did it guys! we have our own 3D printing forum! thanks for everyones support making this possible!
http://www.rcgroups.com/3d-printing-922/
helifrek is offline Find More Posts by helifrek
Latest blog entry: 3D Printing services!
Sold RepRap 3D Printer terriwang Non R/C Items (FS/W) 7 Dec 14, 2012 07:05 PM
Discussion 3D Printer and Roland Engraver for model use - Peter Rake plans BennyLaird Scale Kit/Scratch Built 4 Sep 13, 2012 09:24 AM
Discussion 3D printer drpro Multirotor Talk 2 Jul 15, 2012 03:17 PM
