Old Dec 02, 2012, 06:07 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Originally Posted by aeroseb View Post
what does exactly mean ''brown-out''... ? a kind of crash/failure?
I am using that term to mean that power going into the receiver failed. There isn't any difference between that and a "complete" power loss.
jasmine2501 is offline Find More Posts by jasmine2501
Old Dec 02, 2012, 06:30 PM
aeroseb is offline
Find More Posts by aeroseb
fly to the moon :)
aeroseb's Avatar
Canada, QC, Terrebonne
Joined Apr 2009
ok thank you, i learn with your comments. That's also the first time i heard this term
aeroseb is offline Find More Posts by aeroseb
Old Dec 02, 2012, 06:44 PM
danger_mouse is offline
Find More Posts by danger_mouse
danger_mouse's Avatar
Australia, QLD, Gatton
Joined Jan 2007
I kind of doubt it was a receiver brownout. Frsky aren't really known for it, unlike spektrum. In the video the copter is cruising along at a constant rate... No sudden throttle punches or anything to create a low voltage spike. No apparent voltage sag, just appears to be a total power loss. If it had of been an RF issue the aircraft should have twitched or entered failsafe mode.
I'd be checking the power connectors for intermittent connection and going through all the solder connections and checking for dry joints.
danger_mouse is offline Find More Posts by danger_mouse
Old Dec 02, 2012, 06:48 PM
Rocket Programmer
Joined Jul 2007
It's ok... and I didn't mean to make a big deal out of it, was just saying it's something you should check, and since it's easy to check, you could eliminate that issue before concentrating on things that may be impossible to explain, such as radio interference. Also... you turn off the FPV equipment and fly the quad all over hill and dale in that same area and you pretty much eliminate environmental interference as a factor. Eliminating problems one by one is the way to figure these things out.
Old Dec 02, 2012, 07:19 PM
blade strike is offline
Find More Posts by blade strike
DJI SUPPORT / TESTING
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Originally Posted by jasmine2501 View Post
You've dropped below the level at which things can operate - doesn't really matter if it's "complete" or not. And, have you ever given your opinion without being a dick about it? There's a million ways you could help here without being a total ass, so just stop it, please. Where were you when the original question was asked if you're such an expert on everything, huh? Why did you only show up when you saw a chance to insult me?
Not insulting anyone just pointing out that you often post about things you have no idea about Wouldn't be a big deal but you continue to want this poor guy to chase down a ghost
Facts are facts.. Simple as that
blade strike is offline Find More Posts by blade strike
Site Sponsor
Old Dec 02, 2012, 07:26 PM
Joined Jan 2006
100% agree
Site Sponsor
Old Dec 02, 2012, 10:00 PM
aeroseb is offline
fly to the moon :)
aeroseb's Avatar
Joined Apr 2009
it makes sense, thanks to all, that guides me pretty much in the right way to investigate more!
cheers
Old Dec 03, 2012, 08:18 PM
aeroseb is offline
fly to the moon :)
aeroseb's Avatar
Joined Apr 2009
update, i'm gonna redo all joints, i'm afraid about dry joints and dont want to take a chance and crash again.
Old Dec 05, 2012, 08:23 PM
aeroseb is offline
fly to the moon :)
aeroseb's Avatar
Joined Apr 2009
Hello everyone, i unbuilt my quad. First of all, some bullet connectors from motor had bad joints...(didn't help my cause). Then, i opended my ''spider'' power system and what i saw was very surprising to me. A little white powder coated the main joints. It's like a calcification or mineral process...don't know but from what i saw it has the potential to reduce significally power through the wires, Here's what i read :
'' The residue is most likely lightly corrosive. The white residue is most likely unencapsulated metal salts.
The potential for electro-migration is increased when flux (no-clean or otherwise) is allowed to stay on the assembly. It only takes three key ingredients to grow dendrites (metal crystals) on a board. These three ingredients are voltage, conductive / corrosive material (flux) and moisture (humidity). The flux residue forms a conductive path connecting an anode to a cathode. The results are either electrical leakage (a temporary problem) or dendrite growth (a permanent problem).''
Use of lead-free alloys have increased visible residues on circuit assemblies. The increased heat associated with lead-free alloys causes the no-clean flux to polymerize before it has a chance to fully encapsulate the newly created oxidized material created during the reflow process. Increasingly, assemblers are removing no-clean flux residues as part of their normal assembly process.
Discussion What could be cause of this crash? makind Beginner Training Area (Aircraft-Electric) 53 Jan 02, 2013 11:28 AM
Discussion Any ideas on what this problem is.... steveap1 Beginner Training Area (Heli-Electric) 16 Jul 19, 2012 01:52 PM
Discussion Any ideas what this is? uncledale Sailplane Talk 11 May 27, 2012 06:42 AM
Question Any ideas as to what caused this? lyonsks Beginner Training Area (Aircraft-Electric) 10 Nov 13, 2006 06:29 PM
Any Idea what caused this? sarge Parkflyers 6 Dec 20, 2003 04:44 PM
