Old Oct 23, 2012, 08:16 AM
molond is offline
Find More Posts by molond
molond's Avatar
Australia, SA, Adelaide
Joined Oct 2011
Question
Whats a good, CHEAP, wing core to fibre-glass?
I've been looking into making a fibre-glass flying wing but all the purpose designed wing cores seem expensive.
So I have been looking at off the shelf alternatives such as the Turnigy Tek-Sumo / Bonsai or the Red Eagles Fly-Wings-1
I have bought all these wing in the past and the Tek-Sumo and Bonsai are great wings but their top speeds were limited due to the rough skin. I just couldn't get the Fly-Wings-1 in the air (made it way too heavy, first kit built I did).
What I want to to know if these will act as good cores or you could also suggest some other core that will be good for a beginner (hopefully under $50 shipped to Australia). Also if I'm looking at this the wrong way just tell me, I won't be that humiliated.
Thanks anyway,
Darcy
molond is offline Find More Posts by molond
Old Oct 23, 2012, 06:09 PM
chanyote66 is offline
Find More Posts by chanyote66
Mobius Cables... I got em'
chanyote66's Avatar
United States, TN, Oak Ridge
Joined Dec 2011
If you have the patience, Hotwiring foam cores is easy... I would offer to send you some cores, but shipping alone will be way up there...
I built my Hotwire from a video on youtube, and get the foam from a local hardware store. I use EPS since I skin it any ways... I probably spent $30-$40 on the hotwire, and can cut wings for less than $10 each. I get my Airfoils and sweep from production planes to keep the performance in check. If you want to get fancy, for $100-$150 more you can build a homemade 2d cnc and connect your hotwire to it for precise foam cores...
But basically... Cut your own and save $$$
chanyote66 is offline Find More Posts by chanyote66
Old Oct 23, 2012, 10:07 PM
molond is offline
molond's Avatar
Joined Oct 2011
Thanks, if I can find some good foam in Australia I would hot wire but the only eps foam I found was 250x250x25mm, nothing big enough unless I glue together a couple of pieces.
Just for reference, what foils/sweep do you use? Do you have one that is suitable for a glider/warmliner?
Darcy
Old Oct 23, 2012, 10:20 PM
chanyote66's Avatar
Joined Dec 2011
I have been working on a variety of foils and most semi-symmetrical airfoils work well for RC, I usually try to stay around 25deg to 30deg sweep.
25mm would work but limits your size, if you stack two sheets together, hot wire them, then glue them you can encase spars inside the foam rather than cutting external spar channels.
Im focusing more on the MH45 airfoil with a root chord of 355mm wing span of 1320mm thickness of 45-55mm and a tip chord of about half the root chord.
This has been a very stable and scaleable design for both speed and slow flight. (I havent glassed one but im guessing that will increase speed quite a bit.)
Old Oct 24, 2012, 12:30 AM
molond is offline
molond's Avatar
Joined Oct 2011
Thanks, that from what I have seen looks an excellent foil for a flying wing. When I cut it, does it have to be two guides on either end of the wing or could I attach one end of the hot wire to a point so the outer tip is smaller that the root?
Darcy
Old Oct 24, 2012, 09:42 AM
chanyote66's Avatar
Joined Dec 2011
I use a single guide and bolt the wire to the table. Then I find the angles I want "how much taper" and move the foam farther or closer to the pivot point for more/less taper. you can use two guides but you would need someone to operate the other end...
Old Oct 24, 2012, 10:55 AM
PHMX is offline
Find More Posts by PHMX
Never trust laughing dolphins
Joined Feb 2011
Correct indeed , symmetrical airfoils generally don't work well anyway. The right balance between the top airfoil and lower wing area is what creates lift.
PHMX is offline Find More Posts by PHMX
Old Oct 24, 2012, 11:11 AM
chanyote66's Avatar
Joined Dec 2011
The balance between the two is critical though with flying wings, too far from symmetrical and it will have problems with speed, and the closer to symmetrical you get, the faster they have to be to create lift.
Old Oct 26, 2012, 08:30 AM
molond is offline
molond's Avatar
Joined Oct 2011
Thanks, I though the pivot point method would be the best, well at least the easiest!
Darcy
Old Oct 26, 2012, 09:42 AM
molond is offline
molond's Avatar
Joined Oct 2011
I found a cheap website but...
I just found this web site: Flying Foam
And they will cut EPS and EPP to your specifications and at only $11+ for two EPS halves and $14.50+ for two EPP halves.
They will ship to the US, Canada and the UK but not Australia!
Any way, I've got I friend who happens to live quite close so the can re-ship it.
If you want to know, I may be going for a EPS wing of 48" (1200mm) [before sweep], chord of 8" (200mm) and foil of S5020 for $17 plus shipping.
Darcy
Old Oct 26, 2012, 10:41 AM
chanyote66's Avatar
Joined Dec 2011
Darcy
Ya I have seen them before, and debated ordering from them, but hotwiring my own wings is down to about $5 a plane in foam... for both halves...
Root Chord of 8"? thats tiny... my 48" wing has a chord of 11" so I have room for batteries and FPV gear...
Old Oct 26, 2012, 11:01 AM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
United States, AK, Anchorage
Joined Jan 2010
You could also take a look at MWCores here: http://www.mwcores.com
He's got a bunch of different designs to choose from.
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old Oct 26, 2012, 11:32 AM
molond is offline
molond's Avatar
Joined Oct 2011
Unfortunately I don't have a hot wire setup so I'll buy the first set and make the cores next time. And yes 8" is tiny but it can go up to 12" for an extra fee. I think 36 x 6" is the largest you can go while still at the base price.
-Mike
Thanks I'll check them out and compare the pair.
Darcy
Old Oct 30, 2012, 09:55 AM
cglusky is offline
Find More Posts by cglusky
Foam Guy
Fort Collins, CO
Joined Jan 2011
Hi All. Just wanted to say that we will ship to Australia and other international destinations if able. Depending on the country there are different size limits so it's not easy to offer our Quick Order and other stuff from the site with international shipping calculated correctly.
If you need something international we are happy to discuss options. For example, we just shipped a Mother Ship to Australia and had to cut the thing into a four panel wing and pack it into two boxes to get it to ship via USPS. Just email or call and we can figure out what is doable.
Darcy,
Just shipping to Australia from the US will probably cost you at least 50 dollars. For your budget I agree with the other posters about hot wiring your own foam. If you search you will find some good info on building your own hot wire bow and templates. Obviously we prefer people order from us, but we also realize we are not in everyone's budget. Just remember if you use EPS that you have to use epoxy resin as polyester resin will attack the foam. You may be able to use water based polyurethane and a light layer of glass over one of the off the shelf kits but I have never tried it. Depends on what type of foam as to quality of adhesion etc. I have read that brown paper and light glass in layers works well too. That method has been around for years, but again, never tried it. If you are just looking to clean up the airflow on a budget you may find that New Stuff/laminating film does the trick. We have used on both EPS and EPP with great success. Makes for a clean, strong, cheap (relative) wing. Lots of options.
Thanks!
Coby
FlyingFoam
cglusky is offline Find More Posts by cglusky
Old Oct 30, 2012, 10:04 AM
molond is offline
molond's Avatar
Joined Oct 2011
Thanks!
Coby
FlyingFoam
Thanks for clearing that up, I am still thinking of what I going to get, checking my wallet and I am also going to wait until I have finished my exams.
I am probably going to get one of your epp quick cores, at most 48" by 10", how hard would it be to send that to Australia, and do you have an estimate for shipping cost?
Flying Foam has definitely just up to my #1 possible wing core shop!
Darcy
P.S. Thanks for the extra info, I'll get working on that hot wiring set during the holidays!
Discussion Fibre glass Epoxy sheet vs Carbon fibre sheet for multirotor centre plates.. joy4u Multirotor Talk 4 Aug 16, 2012 10:14 PM
Discussion What is you're cheap realible servo? Is Solar any good? (Standard size only) newrider Radios 5 May 29, 2012 03:06 PM
Question Balsa sheeting foam core wings vs just glassing. erh7771 Scratchbuilt EDFs 60 Apr 07, 2012 09:25 PM
One sets of 128" 2lb/ft3 density core wings bagged with S-glass Beauregard Aircraft - Sailplanes (FS/W) 4 Jan 03, 2005 02:10 PM
Question Whats the best way to glass foam cores? charlieuk Hand Launch 2 Oct 29, 2003 06:21 AM
