Old Jun 10, 2013, 12:22 AM
RWalker is offline
Find More Posts by RWalker
United States, CA, Lancaster
Joined Nov 2011
We're now ready to button up the Tx case. Reconnect the toggle switch cable and make sure it doesn't interfere with the module case. Secure the board to the chassis.
When I do this again, I'm going to put the DHT module on the other side, which is the case's left side as seen from the back when opened. There's more room there.
RWalker is offline Find More Posts by RWalker
Old Jun 10, 2013, 12:29 AM
RWalker is offline
Joined Nov 2011
We finish up by placing the antenna on top then doing a function check. Follow the FrSky binding procedures. In this case, the RX LED glows green, and all channel functions work great!
Old Jun 16, 2013, 09:40 AM
tuootal is offline
Find More Posts by tuootal
tuootal's Avatar
Earth-Europe-Finland-Espoo-Friisilš
Joined Sep 2007
Cool!
Tuomas
tuootal is offline Find More Posts by tuootal
Old Oct 25, 2013, 02:49 AM
JMP_blackfoot is offline
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
Originally Posted by maddmann View Post
I sent an email to Tony Stillman at Radio South. He said you can plug the newer 2.4ghz modules for the Futaba radios into the FG series and it will work. You can use Frsky, Corona and some others. You need the type with the screw on antennas. The module goes in upside down compared to the newer Futaba radios. I might get a module for mine from HK and bring the old FG back to life.
I just discovered this thread and completely go along with Tony Stillman on this one. No soldering whatever is involved, it works fine and the transmitter remains compatible with 72 MHz.
I have been fitting the FrSky DFT module to my Futaba Gold transmitters very simply.
It plugs in upside down as indicated, so the antenna connector needs to be moved to the other hole in the module (FrSky has conveniently provided an extra hole in the correct position).
A spacer is also required to fill the space around the smaller module and secure it mechanically. I made mine of plywood and balsa as shown in the pictures.
I'll try to post dimensions later.
Once the FrSky module is plugged in, it will be found that the meter in front of the transmitter pegs all the way to the right. This because the Futaba module drives the meter via a 4.7k resistor, while the FrSky module delivers ground on the meter output pin. There is no risk for the meter, but one can adjust the meter calibration pot inside the transmitter to compensate. Pictures show the meter calibration pot inside a 6-channel and a 7-channel transmitter. In both cases, the letter "M" shows which pot needs to be turned counter-clockwise about 1/4 turn. I adjusted for a reading of 10 with the FrSky module. When the Futaba module is fitted, the reading is 8.5.
The spacer also allows for installation of the later Futaba FM modules.
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Oct 29, 2013, 01:41 AM
Joined Jul 2003
Here are the construction details of the spacer.
For a good fit, make sure the dimensions 16 mm and 17 mm are accurate.
Start by glueing the 3/8" balsa piece to the 1/64" ply floor, then the 1/32" ply and 3/16" balsa sides.
Then glue the 38x2 mm 1/32" ply catch to the 38x18 mm 1/32" ply plate and glue to the 3/8" balsa piece inside. Finally glue the 17x14 mm 1/32" ply catch to the 3/8" balsa piece outside.
I used medium cyanoacrylate glue for the assembly.
Finish is black acrylic paint over two coats of dope.
Old Dec 28, 2013, 10:44 PM
747guy is offline
Find More Posts by 747guy
Australia, New South Wales, Sydney
Joined Oct 2008
Futaba FP-T3 Hack
Hi all, I have just successfully fitted an Orange RX Hack module to my old 3 channel transmitter. Once I located the signal output point it was pretty straightforward.Had to reverse the output of the throttle Pot and carefully set the pot position so that module would turn on. Bind / Range check LED was fitted into battery voltage indicator housing,glows green when on.http://s10.imagestime.com/out.php/i909138_image.jpg
747guy is offline Find More Posts by 747guy
Old Dec 28, 2013, 11:07 PM
coriolan is offline
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
Stewart302
Very neat conversion!
coriolan is offline Find More Posts by coriolan
Old Dec 29, 2013, 04:16 AM
ltc is offline
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
I really like the way the LED looks.
Excellent conversion.
ltc is offline Find More Posts by ltc
Old Feb 04, 2014, 08:35 PM
Bhart is offline
Find More Posts by Bhart
Joined Feb 2014
How to for converting a Futaba Gold series to 2.4ghz
Attached is a pdf of a little power point that I created to share with others that want to convert their Futaba Gold series to either a Corona or FrSky 2.4ghz system.
Bhart is offline Find More Posts by Bhart
Old Feb 04, 2014, 09:48 PM
coriolan is offline
coriolan's Avatar
Canada
Joined Sep 2006
It is odd that the older FG module beside being bigger than the newer one was also installed upside-down like the Hitec module for the Eclipse-7&Prism-7. JMP_blackfoot and Bhart solution solve that well(allowing the use of 2.4 Ghz and still keep FM functional). Didn't know about the analog meter being driven via the module in older Futaba FG!
Wanted Futaba FG Series Gold Box Radio RWalker Aircraft - General - Radio Equipment (FS/W) 5 Mar 09, 2013 05:54 PM
Wanted Futaba FG series GOLD FP-xx transmitter Boofer Aircraft - General - Radio Equipment (FS/W) 5 Oct 14, 2011 11:51 PM
Wanted Fm FUTABA FP-FG Tx (Gold Series 7/6/5 Ch) Jaanos Aircraft - General - Radio Equipment (FS/W) 5 Mar 24, 2006 11:36 AM
futaba FG gold series transmitter twohsieh Radios 3 Jan 30, 2005 06:24 PM
FS: Futaba Gold Box Transmitter FG Series smrosko Aircraft - Electric - Airplanes (FS/W) 3 Nov 11, 2003 01:42 PM
