Old Jul 16, 2012, 12:49 AM
SARCFAN is offline
Find More Posts by SARCFAN
Joined Dec 2010
Removing the switch on a brushed car esc
I see both the brushed esc's I own have got switches. None of my brushless esc's I have for boats have switches. I supose having a switch is good as there is no spark when connecting batteries.
But I want to take out the switch from the circuit and directly couple the wires. Is it a bad idea?
Also, I dont see capacitors on the brushed esc but all my brushless esc's have got a few of them installed. With no capacitors I asume I will then get no spark when connecting batteries to it?
Can I fit a capacitor to it as it don't have one? Will there be any negatives when I fit a capacitor to the esc that did not have one directly from the factory?
The esc in question is a lipo tazer 10T.
SARCFAN is offline Find More Posts by SARCFAN
Old Jul 16, 2012, 08:54 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
I wouldn't remove the switch from my own preference, but if you cut it off and splice the wires that went to it together it'll work. Alternatively, you could just always leave it on and control power by plugging in or unplugging the packs.
Comparing marine ESC's to car ESC's is comparing apples to oranges. The ESC in my 22T only has one tiny capacitor, about the same size as the one on my 35a turnigy marine ESC. The ESC in my truck is quite high end, so it's definitely not a cost thing:
http://www.amainhobbies.com/product_...-Brushless-ESC
Adding a capacitor if you don't need one won't help with anything at all, just extra effort to find them and solder them on. Why do you want to add one, are you having issues with how it's running?
wparsons is offline Find More Posts by wparsons
Old Jul 16, 2012, 10:36 AM
Creepy1 is offline
Find More Posts by Creepy1
Cotton Headed Ninny Muggins
Creepy1's Avatar
Canada, ON, Kapuskasing
Joined Mar 2012
+1
I don't do it but I know plenty who do remove the switches. No damage from doing so.
Creepy1 is offline Find More Posts by Creepy1
Old Jul 16, 2012, 11:37 AM
SARCFAN is offline
Joined Dec 2010
Absolutely no issues at all. But I want to use this esc in a boat now and thought there must be a reason why boat esc's have more/bigger caps on them than car esc's. Maybe its the constant high power drain that happens in boats? But if its agreed that its not really needed, then I'm answered thank you.
Old Jul 16, 2012, 08:48 PM
wparsons is offline
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Boats are generally much harder on power systems and tend to draw a lot more constant amps than any car/truck. There's no harm in adding caps, but unless you're drawing a lot of amps then you should be fine.
Old Jul 16, 2012, 10:50 PM
SARCFAN is offline
Joined Dec 2010
No them I'm sorted. I finished installing the motor etc on the boat. The motor is a terra claw 55T. Prop is a big 55mm one, fully submerged under the boat. This is going to be my bait boat so the prop must be under the boat. It draws less than 10 amps with a freshly charged 2S pack so its very little actually. I will then rather not add caps.
Discussion Reprogram a brushless ESC to get a brushed ESC with no delays / RC Switch kapteinkuk DIY Electronics 90 Feb 15, 2015 07:41 PM
Discussion Question about using a 10T brushed car esc in a boat, using twin 55T brushed motors SARCFAN Dock Talk 5 Jul 02, 2012 11:58 AM
Found --found/closed/thanks rcfanatic--Brushed r/c car ESC that can handle 11.1 lipo fly_right Cars - Cars and Parts (FS/W) 6 Apr 14, 2012 07:39 PM
Discussion Replacment brushed ESC for the NitroRCX drift car. B dog Electric Power Cars 5 Mar 06, 2012 08:20 PM
