Old Apr 05, 2012, 12:16 PM
elvill is offline
Find More Posts by elvill
Eugene, Oregon
Joined Apr 2009
Thrust Vectoring Ar6400+415/5320+MCX Ultra Micro Gear
here is the setup for my Walkalong Glider Transformation - free flight to lite weight vector thrust brick conversion!
three ball joints - two connected to servos on brick one mounted on tiny brick sled - 6mm motor DD with air hogs equivalent prop! Don't need much thrust for walk along just wanted to fly it nice and slow! floaty in a small room - probably gonna use 100mah for lipo try to keep everything under 8g
No control surfaces just thrust vector for a try...
of coarse will remove ball connectors and attach to brick via zbends
elvill is offline Find More Posts by elvill
Old Apr 05, 2012, 01:08 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
gonna pick these up from lhs this afternoon - mcx pushrods set for $5 should work perfect
EDit: These were too big, mcx parts for 8.5 VTDD
thinking I won't need sled - just a dab of hot glue behind brick to mount single ball joint to wing - pushrods to the other two and we're perfect! Concern ~ will the servos on the brick be messed up/effected by the thrust from the motor it will be a direct link after all... oh never mind Im sure the servos could handle 12g thrust
Old Apr 05, 2012, 03:43 PM
CorvetteC5 is offline
Find More Posts by CorvetteC5
CorvetteC5's Avatar
Kokomo, Indiana
Joined Jun 2008
Neat idea! I always like watching the powered kites using this approach and having one small enough for the house would be cool. I would think the load on the servos will be less about motor thrust and more about rotational inertia of the armature. Either way keep a loop in the pushrods and the servos could be fine.
Looking forward to reading of your progress.
CorvetteC5 is offline Find More Posts by CorvetteC5
Old Apr 05, 2012, 04:46 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
Originally Posted by CorvetteC5 View Post
...would think the load on the servos will be less about motor thrust and more about rotational inertia of the armature.
yes - rotational inertia of armature, should be alright not a lot of mass with tiny prop - clean up slop - like the design of the windrider walkalong glider seems to be perfect for lite weight vector, it was either a cheap dollar store kite or walkalong glider heck still may do a tiny vector thrust kite with other bricks
Old Apr 05, 2012, 10:22 PM
elvill is offline
Eugene, Oregon
Joined Apr 2009
vector thrust ArBrick Mod
little bit of inertia but not bad at all - walkalong will love it!
Thrust Vectoring Ar6400 (0 min 20 sec)
6mm DD ITC Pusher
Old Apr 05, 2012, 11:06 PM
Charos is offline
Find More Posts by Charos
Sydney, Australia
Joined Aug 2008
AWSOME work elvill - you are quite the Tinkerer!
I'm also mucking around in the micro glider category - always interesting to see what your up too.
Charos is offline Find More Posts by Charos
Old Apr 05, 2012, 11:58 PM
Faethor is offline
Find More Posts by Faethor
Minneapolis, Minnesota
Joined Jul 2007
Neat! Looking forward to seeing how this functions in flight!
Faethor is offline Find More Posts by Faethor
Old Apr 06, 2012, 12:04 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
much improved
shanks man, much appreciated
viewed from several different angles I simply was not happy with accuracy! made a pushrod 'guide' to conteract inertia near the antenna - much more pleased with precision
Improved Thrust Vector Ar6400 (0 min 37 sec)
... imagining other tiny airframes could benefit from vector thrust - be easy to do 8.5mm motor VTDD...
Old Apr 06, 2012, 12:10 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
setup weighs 9.8grams total with 70mah - it'll have to do, shooting for 8
Old Apr 06, 2012, 12:14 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
Very impressive!
I'm really looking forward to seeing this in flight.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Apr 06, 2012, 12:22 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
yeah me too - havent done anything that actually moves the motor before. constraints right now is low thrust, I assume aerobatics are out if using 6mm motor even for the lightest of foams...
why I chose a walkalong glider as the platform - needs very little air and floats very well, directional air is what its all about! unfortunately @10grams it looks like Im going to have to scale up a larger walkalong glider than the netbought windrider - I want lofty super floaty flight and right now its a little heavy for windrider
Old Apr 06, 2012, 12:36 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
You Know You're Lazy...
when you take the walk out of a "Walkalong Glider"
Okay lets see now ~ What is the wingspan of a walkalong gilder that needs about 10grams ballast? time to break out the abacus...
Old Apr 06, 2012, 01:49 AM
indoor_fr is offline
Find More Posts by indoor_fr
indoor_fr's Avatar
Paris (France)
Joined Jan 2006
Hi,
I have a thrust vectoring project in mind, and i'm interested by your solution. Could you please provide a link to the plastic parts you are using, please? I don't understand what it is...
Thanks.
indoor_fr is offline Find More Posts by indoor_fr
Old Apr 06, 2012, 06:46 AM
Ming is offline
Find More Posts by Ming
Ming's Avatar
Hong Kong
Joined Jun 2002
Show us the video.
Ming Lou
Ming is offline Find More Posts by Ming
Site Sponsor
Old Apr 06, 2012, 09:06 AM
elvill is offline
Eugene, Oregon
Joined Apr 2009
Originally Posted by Ming View Post
Show us the video.
Ming Lou
Quick and to the point I love it - Ming, I order 3 of your gliders - can't wait till they arrive! Do you have any idea what the walkalongs plastic 'cg' pieces weigh? sure it less than 10 grams...
Discussion blitzrcworks 5 channel f16 with thrust vectoring ramboner Foamy EDFs 9 Aug 06, 2012 11:19 AM
Discussion Cyclic vs. Thrust vectoring? GreenAce92_v2 VTOLs 29 Mar 09, 2012 12:58 PM
Help! 5Ch BlitzRCWorks F-16 Pro 3D Thrust Vectoring 64mm EDF justincredibleg Electric Ducted Fan Jet Talk 4 Mar 02, 2012 11:28 PM
Sold Twin 70mm SU-47 w/360 Degree Thrust Vectoring Orion Pax Aircraft - Electric - Jets (FS/W) 4 Feb 26, 2012 11:40 AM
Cool BD-10 Parkjet - 6mm Depron with simple thrust vectoring eliworm Pusher Prop Jet Models 26 Feb 18, 2012 02:56 PM
