Old Mar 22, 2012, 04:12 PM
eschult is offline
Find More Posts by eschult
FLYINGJUNKY
eschult's Avatar
USA, FL, Jacksonville
Joined Mar 2008
Question
lipo running in series
When running two 3 cell lipos together as a six cell how important is it to use the same exact c rating. Example. Running 2 3 cell 5000 mah together. Can one be a 20c rating and the other be a 30??????
eschult is offline Find More Posts by eschult
Old Mar 22, 2012, 04:23 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
They need to be as exact as possible. Same capacity ,same C rate,same past useage history,same cell IRs.
Even with new LiPolys with cells of same batch it is common for a 4S to be harder to balance than a 2 or 3S. Each added cell makes the tast more difficult.
You could charge them in parallel tohelp with the balancing and may get by with discharging in series if you use only 60% or so of their capacity. Do a short flight and check eack battery seperately to see how close te cell voltage are and how many mAh it takes to recharge each one.
I would not do it my self,to much bother as inexpensive as LiPolys are these days.
Charles
Old Mar 23, 2012, 03:17 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Packs run in series are only as good as the weakest pack (or cell). The amps running through each pack will be identical when they're in series, so if you do run them that way, it's important to ensure that you're only running them at whatever amps the weakest pack is good for.
It's advisable to match them as close as possible though.
abenn is online now Find More Posts by abenn
Question How to wire the setup to run 2 packs in series stekeye Power Systems 9 Mar 22, 2012 01:13 PM
Discussion Lipo in series scottieusa Batteries and Chargers 3 Mar 03, 2012 04:20 AM
Discussion can i charge different mah 1 cell lipos in series? Dr.JJ Batteries and Chargers 5 Feb 25, 2012 07:10 PM
Help! Quanum and running batteries in series MiG-3 Reno Rocket Batteries and Chargers 17 Nov 26, 2011 09:03 PM
Discussion Power Gurus: Can a brushless ESC and motor be run in series? Eddie P Electric Motor Design and Construction 8 Sep 14, 2011 06:28 PM
