Old Feb 03, 2012, 10:02 PM
samson55 is offline
Find More Posts by samson55
samson55's Avatar
United States, IL, Rockford
My 600mm micro DLG
Just finished this gal tonight (thanks to Yasu, a RCgroups member from Japan)
Wing Span = 600mm (23.6")
Length = 500+mm (5mm outer diameter CF wrapped boom)
Ar6300
Hyperion 1c
x1 Eflite long throw linear (rudder)
x1 HK standard linear (elevator)
Weigh-in and flight trials tomorrow. Should be 26-30grams.
samson55 is offline Find More Posts by samson55
Old Feb 04, 2012, 09:06 AM
Aeronut41 is offline
Find More Posts by Aeronut41
RC Guy Having Fun!
Aeronut41's Avatar
Joined Apr 2010
Looks super! Looking forward to flight reports Aero
Aeronut41 is offline Find More Posts by Aeronut41
Old Feb 04, 2012, 12:48 PM
TexasThermalKing is offline
Find More Posts by TexasThermalKing
TexasThermalKing's Avatar
Angleton, Texas
Joined Mar 2007
Very Nice!!!
"samson55"...That's a really nice sailplane. You need to post how to build it...or give us a link it. I'd love to build one.
Well done! Thanks for sharing,
John
TexasThermalKing is offline Find More Posts by TexasThermalKing
Old Feb 05, 2012, 12:12 AM
samson55 is offline
samson55's Avatar
John
Thanks! I referenced these hand drawn plans and E-mailed back and forth with the author to clear up many questions. I also studied his photos of the various versions he built over the past couple years.
For a pod I used two shells from these super glue packages:
-Sam
Old Feb 05, 2012, 02:35 PM
Angleton, Texas
Joined Mar 2007
We appreciate the notes on the build! Great idea on the pod! I see the submicro servos
you used. Nice work! My hat's off to you guys on the concept!
Thanks " samson55 " for sharing it with us.
John and the Red Tailed Hawks
Old Feb 05, 2012, 08:16 PM
JimZinVT is online now
Find More Posts by JimZinVT
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
This is just brilliant!
JimZinVT is online now Find More Posts by JimZinVT
Old Feb 07, 2012, 04:38 AM
zibobman is offline
Find More Posts by zibobman
Switzerland
Joined Feb 2004
hi,
is it possible to have 1 to 1 pdf drawings of this DLG?
thank you
Ziad
zibobman is offline Find More Posts by zibobman
Old Feb 07, 2012, 10:10 AM
samson55 is offline
samson55's Avatar
Originally Posted by zibobman View Post
hi,
thank you
Ziad
I dont have a way to do that (no cad or PDF program)
I just use the measurements and draw out the wing on a flat piece of balsa. Just find your length and centerline - measure your width at the middle, then half way down each side per the drawings, and then at the tip.
The airfoil is just a bit of talent and TLC.
I wish I could help more. But you will just have to try to do the measurements and draw straight lines.
My wing and tail surfaces are not exactly like Yasu's. I just took my time to get it close. I am going to cut another one and see how much weight I can shave off.
Old Feb 07, 2012, 03:44 PM
zibobman is offline
Switzerland
Joined Feb 2004
Ok, thanks for the info, I think I should give it a try, there is nothing to loose anyway..
For the wing it's 6mm and the tail is 2.5mm right?
What is the diameter for carbon tube, or what kind of tube u used?
Old Feb 08, 2012, 01:56 PM
samson55 is offline
samson55's Avatar
Carbon tube - I used a wrapped 5mm tube non-tapered. I may try a 4mm non-taper next, but the guys in Japan like to have a tapered tube to reduce tail weight - hence cutting and chance of needing ballast up front. Non-taper is cheaper and easy to get.
Yasu uses an Avia skinny UL tube.
Finally had a dead calm morning and had some fantastic flights. Launches were smooth and longest flight time was 55sec. Can't wait for thermal season.
Old Feb 08, 2012, 02:07 PM
zibobman is offline
Switzerland
Joined Feb 2004
Hi Sam ,
Maybe you can put some detailed pics of the new wing that u are going to make...
Nobody was filming ur flights?
Old Feb 08, 2012, 02:30 PM
samson55 is offline
samson55's Avatar
Hi Sam ,
I was on my way to work, so no filming today. I plan to get footage at in indoor sports center soon.
I will post pics, but it will be almost identical to Yasu's wing in his last 600mm blog thread. My current wing has a flat underside - which I plan to carve out on this next wing.
Old Feb 08, 2012, 10:31 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
oh man, an undercambered solid balsa wing! makes mine look like an ancient arf model! link
mine is 24 inch span so only 9.6mm longer than yours. but i am not getting anywhere near 55 second flights. maybe mid 30's, if i'm lucky. though i'm only getting 45-50 foot launch from it too.
i just got some more balsa, so i may have another go at it
derk is offline Find More Posts by derk
Old Feb 10, 2012, 11:50 PM
derk is offline
derk's Avatar
Joined Dec 2003
so, i'm making another one following Yasu's blog, but i ran into a tough call. i have 2 tubes i could use for the boom, one is larger in diameter and about 1.2 grams heavier, but i can run both push rods down it. the other one i have can fit one down it, is lighter, but also more flexible...
so do i go for more rigidity and weight with less drag, or less weight and slightly more drag?
Old Feb 11, 2012, 12:16 AM
samson55 is offline
samson55's Avatar
What are the diameters? 1.2 grams isn't bad. Historically mini DLG/HLGs like the Blue Arrow Angel had larger booms that what people would be comfortable with today. The Elf dlg has rods running on the outside, so I think the drag is minimal. I ran mine outside so I could have control of their flex. Yasu uses guitar string through a tube. The key I think is to make a really light weight wing. I even think I sprayed mine with too much lacquer. But like I said above, build everything light behind the prescribed CG so you won't need to add any nose weight. Add your wing last because the nose works on the seesaw principle - move the wing towards the tail and the nose becomes heavier. Etc.
Keep us updated with pics!
