Old Nov 01, 2011, 02:30 PM
Duck! is offline
Find More Posts by Duck!
It flew...nearly!
Norway
Joined Apr 2006
Anyone know how to get this unit that will track a moving object?
Hi!
I saw this movie and was wondering if anyone knows more about the tracking unit the wakeboarder has on, allowing the camera on board a mikrocopter to follow him?
Wakeboard_2011_06.mp4 (5 min 44 sec)
Cheers,
Matthew
Duck! is offline Find More Posts by Duck!
Old Nov 01, 2011, 02:39 PM
sparklet is offline
Find More Posts by sparklet
Cumbria in the U.K
Fantastic. Took me a while to figure out why there were tall poles and wires.
Then I noticed there was no boat !
sparklet is offline Find More Posts by sparklet
Old Nov 01, 2011, 02:44 PM
Duck! is offline
It flew...nearly!
Norway
Joined Apr 2006
I didn't notice till the very end either!
Old Nov 01, 2011, 09:07 PM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
When you think about it, it's not all that tough. The military call it "convoy following" and essentially all you have to have is an autopilot or stabilization system that has an RTH (return to home) function. You just need a real time GPS reading that will constantly update/transmit the new "home" position via a radio modem. It effectively just updates the "home" position to the autopilot and it merely follows it.
Sure looks like they are comfortable flying some expensive gear over water!
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Nov 02, 2011, 07:37 AM
sweatyfingers is offline
Find More Posts by sweatyfingers
I break cameras
sweatyfingers's Avatar
Joined Sep 2004
IT's just the coolest thing, MikroKopters Followme transmitter.
search through here to find out more:
MikroKopter - FollowMe on the Wakeboard (5 min 43 sec)
http://www.mikrokopter.de/ucwiki/en/HexaKopter
sweatyfingers is offline Find More Posts by sweatyfingers
Old Nov 02, 2011, 12:03 PM
Duck! is offline
It flew...nearly!
Norway
Joined Apr 2006
Would Eagletree's Eagleeyes antenna tracker work? If the "target" wears a tx with an Eagletree OSD and gps, the eagleeye could be placed on the copter. After all, the Eagleeye doesn't know if it's on the ground or in the air, panning and tilting an antenna to follow an aircraft, or panning and tilting a camera to follow a target. Presumably it tracks the object by knowing where the gps unit is in relation to it's own geographical placement. Or have I misunderstood?
Matthew
Old Nov 02, 2011, 03:57 PM
Dogzilla is offline
Find More Posts by Dogzilla
Joined Jun 2004
Looks quite slow to respond and not very accurate. Even at quite a height it's losing him. Maybe it's how he has programmed it to give you a stabilized picture?
I've seen camera tracking before in other areas, most of the really good systems seem to process the image with software but you need to carry a computer along with you.
It won't be too long before a simple iPhone will have enough power to do it in real time so I expect someone is developing a system already!
Dogzilla is offline Find More Posts by Dogzilla
Old Nov 03, 2011, 04:15 PM
Comanche is offline
Find More Posts by Comanche
Joined Oct 2011
DubWise
there's already an android app for the MikroKopter (& some othere multicopters)
called DUBwise
some of the things u can do with it are.
  • display several Info-Pages the MikroKopter provides (high, heading, ect,)
  • view RC-Data ( channels )
  • display Power / RC-Status, initial Piloting interfaces ( ACC & Multitouch )
  • Interface for Flight-Settings
  • View all DebugValues - look at several Values the MK Provides - some are in the LCD too , but this method is faster
  • Read & Edit settings
  • draw Graphs with Nick integral / Roll integral / Nick acc / Roll acc - to check if the Sensors are working proper
  • Cockpit-Screen with Artificial Horizon
  • test each motor
  • Connection via Bluetooth and TCP/IP ( with QMK protocol )
  • Write/Read/Edit mixer-tables
  • Voice output for important values ( Voltage , Height , .. )
  • View position and orientation of Kopter on a Map
  • Draw FlightPlan and upload it to UFO ( + read / write to MK )
  • BlackBox function ( write csv )
& it Seems that using your mobiles onbored GPS & Bluetooth, You Can Tell the Kopter to Follow Your mobile
i have not tested the app myself yet
as i dont yet have a multicopter,
http://www.mikrokopter.de/ucwiki/en/...ndroid_Version
Comanche is offline Find More Posts by Comanche
Discussion Does anyone know contact details for the aero club that flys at Pitt Town NSW? kai888 Australia 2 Oct 13, 2011 08:06 AM
Discussion Anyone know about the Geet Gas Gizmo that People say Gets 100 - 500 mpg ? Chophop Life, The Universe, and Politics 22 Sep 16, 2011 04:23 PM
Discussion How will moving my motor forward for a better cg affect my plane? krexken Electric Plane Talk 17 Sep 11, 2011 09:44 AM
Question Anyone know anything on how to control a really fast car that might not be that fast? ViperGTS-R Micro Cars 3 Jan 12, 2005 02:53 PM
