Old Jan 03, 2012, 04:52 PM
TexasAggie is offline
Find More Posts by TexasAggie
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
Well, here's #2 for 1280 MHz. How's it look? I ended up getting the lobes to be positioned such that I didn't need the hooks to solder the middle.
Edit: I used 107 degrees for the lobe angle. The overall length of each lobe was 245mm and I bent at 60mm from each end.
TexasAggie is offline Find More Posts by TexasAggie
Old Jan 03, 2012, 05:10 PM
markus123456 is offline
Find More Posts by markus123456
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
Looks great. If you were precise with the measures, I'm sure it will perform nicely.
Markus
markus123456 is offline Find More Posts by markus123456
Old Jan 03, 2012, 05:17 PM
IFLYOS is offline
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
Originally Posted by Nobert View Post
TA
Here in Tucson the public services all use the 1280 band. They have a lot more power and can interfere with FPV setups.
Hope this helps.
Neal
Neal, I am sorry, but this isn't possible. In the US, Amateur radio operators have exclusive use of 1240 Mhz to 1300 Mhz.
Now, it is possible there is a repeater in the 1.2Ghz band for Amateur use*, and that is causing the interference you refer to, but again, 1240-1300Mhz is allocated by the FCC for exclusive Amateur use. We do share some of our allocations with other groups, but not this one.
see http://www.ntia.doc.gov/files/ntia/p...3-allochrt.pdf for the breakdown of allocations in the US
Tim
AG4RZ
I just looked, and there is an Amateur repeater located at 9200 ft atop Mt Lemmon neat Tucson, Arizona - This is a D-Star machine. It is on 1298.25...
IFLYOS is offline Find More Posts by IFLYOS
Old Jan 04, 2012, 08:09 AM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Darn good if you ask me. Now fly it
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 04, 2012, 09:04 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
-Alex
Thanks. First I have to hot glue it a bit and then make another cloverleaf since I stepped on my best one yesterday.
Old Jan 09, 2012, 07:37 AM
chemnut842 is offline
Find More Posts by chemnut842
United States, MD, North East
Joined Apr 2011
Ok so I built the SPW for the first time and it looks alright but performs awful. I recorded a LOS flight and upon reviewing the vid, there is no way anybody could fly fpv with this.
There are slight problems with my antenna. After reading I think the problem is my feed gap. I measured mine to be 9.5mm and I did not incorporate any hooks into the center joint.
Both Tx and Rx antennas are RHCP (RHCP = tractor prop, LHCP = pusher prop?) and the Tx antenna is a CL. I am on 1280 MHz.
should I bend hooks to be ~10mm or should I just shorten the feed gap or both?
I have a 5-turn helical that I just set flat on the ground and that works fine for flying around LOS or ~ 300-700 feet without pointing it - I have not flown far yet but at least I know my other components are working.
chemnut842 is offline Find More Posts by chemnut842
Old Jan 09, 2012, 10:19 AM
asaloca is offline
Find More Posts by asaloca
asaloca's Avatar
Delray Beach
Joined Aug 2004
Hi.
Congrats for IbCrazy ant his valious contribuiton here and for the amazing jeweller work some of you are sowing here for us !!
Can somebody tell me a supplier ...Home Depot or were you guys in states are buying the " Copper coated steel wire " ....serched the net and noyhing ..
Tks
FRED
asaloca is offline Find More Posts by asaloca
Old Jan 09, 2012, 10:31 AM
Devonboy is offline
Find More Posts by Devonboy
SW England
Joined Aug 2009
2 kinds of plated wire:
Gold plated 'memory wire' - found in ladies DIY jewelery stores.
Copper plated 'MIG welding wire' - found in lots of places that sell welding equipment.
HTH
Nigel.
Devonboy is offline Find More Posts by Devonboy
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
I got a 2lb spool of welding wire at Ace. They also had it at Lowe's.
Old Jan 09, 2012, 10:51 AM
Chairwolf is offline
Find More Posts by Chairwolf
I think it'll work this time!!
Chairwolf's Avatar
399 feet above Roanoke, VA
Joined Jan 2007
Originally Posted by asaloca View Post
Hi.
Tks
FRED
Harbor Freight has it for cheap, too. And Home Depot.
Chairwolf is offline Find More Posts by Chairwolf
Old Jan 09, 2012, 12:39 PM
Joined Apr 2011
I found it at radio shack marketed as antenna ground wire. It is copper clad steel wire and had a cost of about $1/foot or something like that.
Old Jan 09, 2012, 01:36 PM
Chairwolf's Avatar
Joined Jan 2007
$1 A FOOT??? You can get 10 miles of it for $11.47 at Home Depot, or $8.50 at Harbor Freight!
Old Jan 10, 2012, 03:03 PM
Zen09 is online now
Find More Posts by Zen09
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
A pusher prop behaves the same as a tractor one.
RHCP is the conventional clockwise screw thread type.
Zen09 is online now Find More Posts by Zen09
Old Jan 11, 2012, 02:53 PM
k0mputer is offline
Find More Posts by k0mputer
Joined Jan 2011
I have 5.8 system on order and came across this:
http://www.readymaderc.com/store/ind...roducts_id=596
Do I need 2 antennas, one for Tx, one for Rx or just for Tx is fine? Thanks in advance for your help.
That will do 1000+ feet with ease.
-Alex
k0mputer is offline Find More Posts by k0mputer
Old Jan 11, 2012, 03:25 PM
Registered FPVer :)
Joined Aug 2006
You need a pair. A cloverleaf on the transmitter and skew planar wheel on the receiver usually works best.
Markus
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 53 Feb 21, 2015 07:02 PM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 06:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 09:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 04:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 05:00 PM
