n/a Posts
Re: easy battery
<Michael> wrote in message
news:bk034v4p24lp6ofl08b744n51kfucfrkno@4ax.com... > If a battery is not marked- > Can you tell a nicad from a nimh. A little tricky - you can charge it based on its being a Ni-Cd and see what you get for a discharge. For an AA size cell .580 dia X 1.9 long the maximum capacity would be around 1100 mAh - if it is a Ni-MH you would get significantly more - 1400 minium. Unless you happen to have come upon some really sick cells. > Also how can you determine if the battery pack is n, c, a, aa or what? These are physical sizes, N=.38 diameter, C (I think you mean sub-C or Cs) it is .88 , AA is .580 and A is .66 actual sizes will vary slightly depending on manufacture and oversleeve thickness. -- Red S. Red's R/C Battery Clinic http://www.rcbatteryclinic.com Check us out for "revolting" information. |
n/a Posts
Re: easy battery
Go to www.sanyobatteries.com and look in the specs there for the dimensions
on the different cells. Not sure how to tell NiCd from NiMh. Probably on the website somewhere. Rein <Michael> wrote in message news:bk034v4p24lp6ofl08b744n51kfucfrkno@4ax.com... > If a battery is not marked- > Can you tell a nicad from a nimh. > Also how can you determine if the battery pack is n, c, a, aa or what? > I need to know this stuff to charge properly > thx |
| Thread Tools | |
| Idea Cheap n Easy Battery Foam cutter | Jaguar_Jay | Foamies (Kits) | 0 | Oct 11, 2003 10:22 PM |
| Easy Battery Holder for GWS TM | Hammer Head | Parkflyers | 19 | Aug 16, 2002 06:34 PM |
