Old Mar 15, 2012, 11:50 AM
Joined Mar 2005
Build Log
Ask 21
I`m in search for X Y coordinates for the RG 15A 2,5/13% airfoil.
Anyone out there with a link?
Gudmund is offline Find More Posts by Gudmund
Old Mar 15, 2012, 04:32 PM
Seadog's Avatar
Canada, ON, Toronto
Joined Jan 2004
Here you go...the .dat file from Selig
Dave Smith
Hmmm, just realized that of course a .dat file is not "X-Y" in the usual sense, but you can use this with Compufoil or Profili (free) to generate what you need.
Seadog is offline Find More Posts by Seadog
Old Mar 15, 2012, 04:58 PM
Joined Mar 2005
I`ll see what I can do with it, thanks alot :-)
Old Mar 15, 2012, 04:59 PM
Joined Mar 2005
Exactly what I had in mind.. :-) Those are the coordinates yep.
Old Mar 18, 2012, 12:42 PM
Joined Mar 2005
Well, I`m in the early stages of making the ASK 21 in half scale of the original..
I have just began making templates of the airfoils and have already measured out all the 42 sections for the fuselage.
In this moment I am making the outlines for the wings and will continue to do the same for the fuselage, seen from the side and from above.
Those will be handy then it comes to make the correct dimensions before conturing the fuselage. I know it`s alot of work..
Old Mar 18, 2012, 05:43 PM
Joined Mar 2005
Outlines of the fuselage is finished. A cd for comparison.
Root chord is 740 mm
Fuselage 4170 mm
Height of fuselage at cockpit 530 mm
Width 360 mm
Wingspan 8,5 M
Quite abit work done today.
Old Mar 18, 2012, 06:02 PM
Play Nice, Have fun
Davis California
Joined Apr 2006
Good lord son
Gudmund, now I know were all the trees are going
Debs planting new ones
WhoDaMan is offline Find More Posts by WhoDaMan
Old Mar 18, 2012, 06:50 PM
Joined Mar 2005
Must be someone else Dave.. Not enough balsa to be mentioned in this one..
Old Mar 20, 2012, 09:26 AM
Joined Mar 2005
The right place at the right time..
This car contains 200 kg of carbonfibre and 70 kg glass-cloth.
12K carbon means 12 km of fibre for each gram, incredible but true.
This means the load here reaches 24000000 km in one string, technically
All the templates for wing-cutting is ready, just not found the correct thickness and density yet. But soon.
Old Mar 20, 2012, 10:30 AM
Joined Mar 2005
Up-scaling this much is a challenge, so accuracy and patience is a must.
But becomes quite easy as soon as the code is cracked, getting in the flow so to say.
The essence is the calculated constant that remains the same in every dot placed at the paper. Those marks makes the outlines to the curves for the finished plans.
Old Mar 21, 2012, 03:38 AM
TEAM OZSKUNKWORX
r/c junkie's Avatar
KORUMBURRA IN THE BOONDOCS
Joined Jan 2006
Watching your build with much intrest.Good luck and great choise of model.
Shane
r/c junkie is offline Find More Posts by r/c junkie
Old Mar 21, 2012, 04:20 PM
Joined Mar 2005
It will take some time, but I`ll get there..
Old Mar 21, 2012, 09:21 PM
United States, CO, Delta
Joined Aug 2011
Wow!! Awesome Project. I like it. Paul
dufek paul is offline Find More Posts by dufek paul
Old Mar 22, 2012, 10:54 AM
Fly it like you STOL it!
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
if you ever make plans send me a digital set! (will have to keep a ship that big secret from the mom! )
Subbed up BIG!!! time!
Keenan smith is offline Find More Posts by Keenan smith
Old Mar 22, 2012, 03:07 PM
Joined Mar 2005
I got the original drawings from Schleicher. Maybe it was because I explained the project, don`t know..
But can`t forward them anyway, as this was strictly for personal use on this project, and those are not digital as you can see.
So it`s not a "freeware", respecting their property..
Anyway, going from "software to hardware" now. The part I really look forward to.
This part of the hobby is at least half of it, for me.
Styrofoam going manually, starting tomorrow.
Discussion ASK 21 Jet glider snauwaertj Jet Turbines 18 Mar 01, 2013 04:13 PM
