Old Nov 12, 2012, 12:59 PM
robertus's Avatar
Poland, Dolnoslaskie, Jelcz-Laskowice
Joined May 2012
Build Log
Su-22M4 Fitter K, with plans
Hi, everybody.
I want to build Su-22M4 in Polish Air Force colours. Su-22 is export version of Su-17.
My goal is to make swing wings.
My motivation - Su-22 from PhoenixRC sim.
Su-22 PhoenixRC (2 min 53 sec)
Plans are in post #48
robertus is offline Find More Posts by robertus
Old Nov 12, 2012, 05:51 PM
Trapped in California
foamflyer's Avatar
United States, CA, Arcadia
Joined Nov 2003
OK robertus, good luck to you, and post photos when done!
foamflyer is offline Find More Posts by foamflyer
Old Nov 13, 2012, 02:40 PM
Whatever goes up must go BOOM
joker24458's Avatar
United States, OH, Kent
Joined Mar 2012
Very fine detail in the (google sketchup?) 3D thing. Looking forward to the swing wing mechanism........
-joker
joker24458 is online now Find More Posts by joker24458
Old Nov 14, 2012, 12:09 AM
robertus's Avatar
Joined May 2012
Yes, this is google sketchup.
I wonder. Distance between the points of rotation in the wings is large, about 14inches. And, on the plane, they turn only wingtips.
Maybe instead of making mechanism as the F-14
I'll do a separate mechanisms for each wing.
Latest blog entry: Yak-17 super slow EDF
Old Nov 15, 2012, 06:48 AM
robertus's Avatar
Joined May 2012
Some progress in sketchup
I increased the wing and elevator about 10%
Top view
Old Dec 02, 2012, 02:38 PM
robertus's Avatar
Joined May 2012
Few pictures from building
Wing with kfm2 wing profile 6+3 depron (insulation) foam
Framework
And completed model.
This only a prototype. She will not fly. I did it only to examine the correctness of the design and for test gliding.
Old Dec 09, 2012, 02:00 PM
robertus's Avatar
Joined May 2012
Today I did test glide for different swing wings.
Su-22 CoG and swing wing (0 min 28 sec)
The center of gravity has shifted to about 2cm (0,8inch) to the rear for the minimum wingspan ..
Position 0 - max wingspan CG is 425mm (17in) from the back
Position 1 - min wingspan CG is 405mm (16,2in )from the back
I wonder if in the final model will have some meaning.
Maybe is sufficient a small adjustment with elevator.
Old Feb 01, 2013, 12:59 AM
robertus's Avatar
Joined May 2012
Pre-fitting equipment.
Now I build a wing.
The mechanism of the wing
Old Feb 01, 2013, 07:40 AM
IWC
Joined Feb 2003
Subscribed
IWC is offline Find More Posts by IWC
Old Feb 01, 2013, 01:29 PM
robertus's Avatar
Joined May 2012
Testing of swing wings
Su-22M4 swing wing tests (0 min 19 sec)
Old Feb 12, 2013, 12:58 AM
robertus's Avatar
Joined May 2012
Building a wings
Old Feb 18, 2013, 07:40 AM
robertus's Avatar
Joined May 2012
Some little progress with fuselage
Top
Bottom
Old Feb 19, 2013, 01:21 AM
robertus's Avatar
Joined May 2012
I want to do vertical stabiliser like in real plane, as panel.
I have seen this solution in F15 by GWS.
I use 9g servo to this.
Su-22M4 test stabilizatora (0 min 45 sec)
What do you think, is would be good? Maybe it's better to give a stronger servo?
I want to control plane only by elevons. There would not ailerons.
Old Feb 19, 2013, 03:11 AM
SONICX's Avatar
South Africa, GP, Krugersdorp
Joined Jul 2012
Very nice build.
Just love that wing setup.Want to see the end result.
Happy building.
SONICX is offline Find More Posts by SONICX
Old Mar 04, 2013, 02:05 AM
robertus's Avatar
Joined May 2012
I want to do this painting.
I finished the tail.
It stiffen 1.6 mm plywood on both sides. Servo is in block of balsa.
In centerwing section will be reviewed by the electronics.
And that's all for now
Discussion Su-17 Fitter Eddie P Pusher Prop Jet Models 48 Apr 24, 2013 12:44 AM
Build Log new jet su-7 fitter mrshea Pusher Prop Jet Models 1 Mar 13, 2011 02:55 PM
Build Log EPP SU-22 Fitter Mr. UD Pusher Prop Jet Models 3 Jun 16, 2009 08:17 PM
Su-22 Fitter drawings? Huckebein Electric Ducted Fan Jet Talk 6 Mar 21, 2005 02:09 PM
O.K. I'm Building the SU-31 Profile and need some help Cary Reeves Foamies (Kits) 2 Oct 05, 2004 10:34 AM
