Old Nov 30, 2012, 01:12 PM
Emress
sirbow2's Avatar
United States, SD, Rapid City
Joined Nov 2011
aww crap if you use dt700s, the 12in are more efficient than 11in, but only by .2% so wont make much of a difference. with 12in props very max is 2616g, (half of max thrust) and 1135g for 11in.
really sorry bout that. use 12in if you can, but you may have to use 11in for frame restictions
sirbow2 is offline Find More Posts by sirbow2
Old Nov 30, 2012, 02:33 PM
Stop me before I build again!
United States, NY, Albany
Joined Sep 2012
I am in the process of rewinding some motors and looking at the diagrams and reading the theory.
Currently the motors were wound Delta with 14 turns, but Star/Y should give me much more torque with only 8 turns. Is there some downside to star/wye/y windings or do manufacturers just presume people want RPM's in out runners?
brontide is offline Find More Posts by brontide
Old Nov 30, 2012, 06:05 PM
Emress
sirbow2's Avatar
Joined Nov 2011
so STAR = more torque (1.7 x delta), but less speed, more efficient, more sensitive to timing
Delta = 1.7 x more speed than star, more speed than star, smaller prop, less sensitive,
i think Y/WYE/Star would be the best for a MW as it is more efficient and the sensitivity doesn't seem to be much of an issue. marketing has a bit to do with it
those are the main points. i didnt see much else.
Old Nov 30, 2012, 06:26 PM
Joined Sep 2012
More torque and more amps, and this project is just not setup for that so... Delta it is. I already have one phase done, not as insane as it appeared at first.
Old Nov 30, 2012, 06:31 PM
India, West Bengal, Kolkata
Joined Apr 2012
Thank you so much but now I am confused As this is my first time building a quad from scratch, it may end up being a little overweight. What would be the best choice of motor, esc and battery that can pull max weight for under $120. I will make the frame from wood/aluminium. It will carry a small board camera and a two axis gimbal.
Trishit is offline Find More Posts by Trishit
Old Nov 30, 2012, 06:38 PM
Emress
sirbow2's Avatar
Joined Nov 2011
the dt700 with 12in will be fine. will your frame fit 12in props? should be 8+in fgrom side of center plate to motor center for 12in props.
Old Nov 30, 2012, 06:42 PM
Joined Sep 2012
Dt700 is a workhorse. Even on mine with 10x4.5 props and a 1300 AUW it hauls when I WOT.
Old Nov 30, 2012, 07:28 PM
Joined Apr 2012
Since I am making the frame myself, I can make it as large as necessary, but would this not alter the way it handles wind?
Old Nov 30, 2012, 07:29 PM
Emress
sirbow2's Avatar
Joined Nov 2011
yes. bigger props + bigger frame = less wind tolerance, but bigger props + lower kv + higher voltage = more efficient and add ESCs with BLHeli/Simonk firmware and it will hep with wind (better response rate)
Old Dec 04, 2012, 01:16 PM
Joined Mar 2009
Originally Posted by sirbow2 View Post
yeah, dont buy any of those id get those for a second quad, someone who can fly w/o crashing. not worth crashing and spending lots of $$$ to replace expensive motors. grab some dt750/700, 20-22ls or some Turnigy D2836/9 950KV/Turnigy D2836/8 1100KV
Awesome. Thanks for the help. I went with the D2836/8 1100kv from HK and SimonK House ESC-20AMP-NFET from witespy. Can't wait to get this built.
Spacenutz is offline Find More Posts by Spacenutz
Idea Dumb Questions Thread (Ask your questions here) PilotKeeg FPV Talk 3 May 27, 2011 04:28 PM
Discussion Ask Your Questions Here! qacermacer Beginner Training Area (Aircraft-Electric) 4 Feb 14, 2011 04:13 PM
Discussion Full Size Car Troubles, ask your questions here. foamnpacktape Life, The Universe, and Politics 29 Jun 23, 2008 12:43 PM
Data Beginner's Questions - Are you new to rc planes? Before asking a question, CLICK HERE BD Flyer Beginner Training Area (Aircraft-Electric) 76 May 21, 2008 12:49 AM
