Old Mar 14, 2012, 02:32 AM
Joined Dec 2011
mini protos carbon vs trex 450 pro v2 3gx which is best?
Hello, guys ive been hearing good things about both products but i cant semm to see a comparison between each others, i am curious which is best in:
Performance
Electronics quality
Structure kit strength
Ive been hearing alot of good things about mini protos but it wasnt the carbon kit so i couldnt get a comparison vs these newest versions, any help is appreciated as usual.
Legendary_Agent is offline Find More Posts by Legendary_Agent
Old Mar 14, 2012, 01:37 PM
Joined Apr 2008
A proper comparison required both to be on the same equipment and you are in luck that I've these birds with "almost" the same equipment.
Mini - carbon frame, 5065MG, 3500G, beastX, yge 60A esc v4, hyperion motor for 6s, edge 325mm blades.
ProV2 - carbon frame, 5065MG, 3500G, beastX, yge 60A esc v4, stock align motor on 6s, edge 325mm blades.
Performance - very close so even. The stock ProVe on 3S out performed the mini on the stock scorpion 8. However, both are pretty even on 6S.
Structure on a crash - have broken align frame. Have yet to break the mini frame. Mini is a bit more forgiving because the main bearing blocks are plastic versus metal on the ProV2.
chopper62 is offline Find More Posts by chopper62
Last edited by chopper62; Mar 14, 2012 at 03:01 PM. Reason: 3500G tail servo ... the 3400G is cyclic servo.
Old Mar 14, 2012, 02:28 PM
Joined Dec 2011
weird but did u just buy the kits and then filled up with your own setup? i think the mini comes with alot different stock setup than the align, and that is the part i am most interested too.
But your information is not useless, it is quite good so i can conclude the mini protos is more robust than the trex 450 pro v2 3gx, so for that i thank you.
I still am looking for a stock vs stock comparison btw.
Old Mar 14, 2012, 02:52 PM
Joined Apr 2008
Yes ... my LHS offers me the opportunity to purchase just the airframe.
There is no "stock vs. stock" comparison because the mini does not come with servo and fbl unit. The combo offer from MSH would be (1) frame, motor, esc and blades for $415; (2) frame, motor and blades for $329; and (3) barebones kit or frame only for $269.
The align 450 ProV2 super combo is $479 (everything except tx, rx & batt.)
Mini super combo is $415 + 120 for 3x5065MG + $79 for 3500G + $220 for rx ready beastx or $834. Of course, the 5065, 3500G, yge 60A and beastX are better than the DS410M, DS510, 35X and 3GX.
Old Mar 14, 2012, 03:17 PM
Joined Dec 2011
Wow am i getting this right 834$ for mini protos rx ready? is it really double the price?
Im sorry as u might be aware i have no experience at hellis
Old Mar 14, 2012, 07:27 PM
Joined Apr 2008
It's expensive unless: (1) you can get a discount from elektrorc or MSH direct; (2) buy a used one; or (3) use cheaper electronic.
One, with pretty good electronic, is for sale over at RR for $550 shipped.
Old Mar 15, 2012, 06:26 AM
Joined Dec 2011
Well that probably means stock by stock trex is no match for mhs otherwise it wouldnt make ALOT of sense to make the price almost double, so in other words mhs if you can afford, i guess my question was a bit silly indeed as i tought they were both comparable in price range.
Thanks for your help mate ^^
Old Mar 15, 2012, 10:23 PM
Joined Mar 2012
Oh,my god,You heli and the parts is too expensive,Believe or not,most of the parts such as ESC,servo,motor are made in China get across OEM,They were affixed to the local brand.
If you want to buy heli and parts,you can cantact with me.you will be surpriced when you see the heli and parts quality and their price.
hnzyxy2007 is offline Find More Posts by hnzyxy2007
Reply With Quote  (Disabled)
Discussion Mini CP vs mCPx v2 vs Solo Pro 100 vs Genius CP Marioinc Micro Helis 96 Mar 28, 2013 01:54 PM
Sold Align 450 Pro V2 3GX hi2nr Aircraft - Electric - Helis (FS/W) 0 Mar 09, 2012 02:24 PM
Sold BNIB Trex 450 EFL Pro V2 3gx Super combo- $500 tdaf22 Aircraft - Electric - Helis (FS/W) 6 Nov 15, 2011 10:14 AM
Help! Co-pilot 2 connect to 3GX compact sattelite receivers TRex 450 Pro V2 Ossibong 3D Electric Heli Flying 0 Oct 30, 2011 05:54 AM
For Sale 2 Trex 450 pro v2 3gx Part Out nyesteban Aircraft - Electric - Helis (FS/W) 4 Sep 21, 2011 03:43 PM
