Old Jan 05, 2003, 10:02 PM
Kevin Hung
Guest
n/a Posts
JR-3810 and GY-601 Gyro
Hi,
1. Does anyone can give me some default setup of gy-601 with
jr-3810 ? And which channel should I use with gain switch in jr-3810 ?
2. Is it normal when I switch in AVCS mode, and I roll the rudder
stick from jr-3810 to the most right , then I release the stick, but
the servo won't come back to the middle point(in the ground) ?
Old Jan 06, 2003, 06:02 AM
Philip Martin
Guest
n/a Posts
Re: JR-3810 and GY-601 Gyro
"Kevin Hung" <rdcenter@ms25.hinet.net> wrote in message
news:d4e920bf.0301051831.2c3c8539@posting.google.c om...
> Hi,
Cant help you with 1), but as for 2).
Yes that is normal. What's happening is that you've put in a rudder command
but as the heli hasn't moved the gyro is still trying to correct for the
input you made. It does work in the air though.
Phil Martin.
Old Jan 07, 2003, 12:42 AM
Kevin Hung
Guest
n/a Posts
"Beav" <beavis.original@ntloxoworld.com> wrote in message news:<xdlS9.486913$cF5.76148@news.easynews.com>...
> > Hi,
> That's exactly what happens (and SHOULD happen) with the gyro in AVCS mode.
> Beav
> Please note my E-mail address is "beavis dot original at ntlworld dot com"
> (with the obvious changes)
> Beavisland now lives at
> www.beavisoriginal.co.uk
Thanks for your reply, and I have two questions.
1. I have set all mix and trim about rudder to zero, and when I
roll the rudder stick from radio in AVCS mode , I found the gy-601
amplifier display from "A" to a square sign(it means neutral point
error) while rolling the rudder stick (levae heli in the ground ) ,
and it return to "A" when I stop rolling the rudder stick.
2. I can not find any way to change the gain from radio 3810. Is
it only can be changed from gy-601 ?
Old Jan 07, 2003, 04:02 PM
Beav
Guest
n/a Posts
news:d4e920bf.0301062136.43d975c4@posting.google.c om...
> > > Hi,
mode.
> > Beav
com"
My experience with the 601 amounts to around 10 minutes Kevin, so I can't
help you with the display problem, but for SURE you can change the gain from
the Tx. I don't know HOW, but I'd be happy to bet money on it. Even the 401
has that facility and it's a much less expensive piece of gear.
Beav
Old Jan 08, 2003, 04:22 AM
Andy Ling
Guest
n/a Posts
Hi Beav
Hows things going ?
You can control the gyro gain on the 601 from the transmitter. I am
currently using a 3810 to control the gain.
Kevin if you need help hooking it up please email and I send you the
details (its not very hard)
Andy
"Beav" <beavis.original@ntloxoworld.com> wrote in message news:<E7HS9.2295466$6N5.298006@post-03.news.easynews.com>...
> > > > Hi,
> mode.
> > > Beav
> com"
> Beav
Old Jan 08, 2003, 05:52 PM
Kevin Hung
Guest
n/a Posts
djandyling@hotmail.com (Andy Ling) wrote in message news:<5c6b85d5.0301080111.10d7d36c@posting.google. com>...
> Hi Beav
> Hows things going ?
> Andy
Hi,Andy
My email address is rdcenter@ms25.hinet.net. Please email me the
detail. Thanks for your help.
For Sale WTT gy 240 gyro for a JR PCM Rx TonyTypeS Aircraft - General - Radio Equipment (FS/W) 0 Jan 22, 2006 12:00 AM
Sold GY 601 Gyro Paul Susbauer Aircraft - General - Radio Equipment (FS/W) 0 Aug 10, 2005 10:48 PM
jr plug to futaba plug gyro problems fourstarforty Electric Heli Talk 13 Oct 15, 2001 03:12 AM
GY 240 Gyro dangrade Electric Heli Talk 3 Jul 02, 2001 08:46 AM
GY 240 gyro dangrade Electric Heli Talk 1 Jun 21, 2001 08:48 AM
