Old May 14, 2001, 09:43 PM
hardlock's Avatar
Joined Aug 2000
CAM 6x3 folder - best mtr/pack?
I'm building a flying wing that I want to use this prop on. I love the performance of the CAM 8x4.5 folder on my MM direct with 7-8 cells at 40-45ozs.
Since the motor will be a pusher for this flying wing design, I wanted a folder for it to be used for soaring. Not too many choices it seems, so figured I'd just get the prop and work backward.
What motor w/ #cell pack would be best? Seems the more I read that a S400 is too weak and a 480 is better. 450 getting too heavy?
Want to keep the weight at around 20 ozs RTF. (no, it's not another Zagi clone!)
hardlock is offline Find More Posts by hardlock
Old May 14, 2001, 10:04 PM
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
Motocalc says the Astro 010 works well with the 6x3 folder, however you'd need to stay around 7 cells as amperage gets to be about 5 amps with 8 cells. Using the astro would signifigantly lessen your overall weight.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old May 14, 2001, 10:19 PM
hardlock's Avatar
Joined Aug 2000
Wanted to stay cheap if possible.
Isn't an 020 the replacment for an S400 or would the 020 be closer in performance to an 05 can?
Old May 15, 2001, 07:32 AM
Enjoy Life B4U Die!
Buzz_Man's Avatar
United States, GA, Powder Springs
Joined Dec 1999
FWIW - I've used a Robbe 6 x 3.5 folding prop with the JK Aerotech T-52 & it worked better than any other Speed 400 direct drive prop configuration.
This power/plane configuration is similar to using a Pinto engine in a Corvette. It works, but the performance isn't . . . breathtaking.
Buzz_Man is online now Find More Posts by Buzz_Man
Old May 15, 2001, 08:13 AM
Bill Glover's Avatar
United Kingdom, Bracknell
Joined Nov 2000
My standard Pico Jet flys fine at about 20 oz with a 6v S400 and 7x900 Nicd cells. Your pusher flying wing must be pretty similar so should be OK on the same setup.
The CAM 6x3 folder is fine on these motors, I had them on my Twin Star for a while (using 8x2400 cells) and duration was outstanding.
Bill Glover is offline Find More Posts by Bill Glover
Old May 15, 2001, 12:44 PM
Austin, Texas USA
Joined Mar 2001
My Graupner Terry uses a CAM 6X3 with a speed 400 motor and an RTF of 19 ounces. This is stock from the factory, and flies quite well on 6-7 cells. The Terry is very efficient, though, so on 8 cells you may get a little more oomph for a wing.
If you go with a 480, I would prop a little more, and try the 6X4 from Dymond. Everyone seems to have very good performance with this combo.
sf_247 is offline Find More Posts by sf_247
Old May 15, 2001, 11:57 PM
hardlock's Avatar
Joined Aug 2000
Running the 6x3 through Motocalc with a S400 shows fair results at least on the lower end of the airspeed range.
What's really strange is when running the stock Zagi and/or FMA Razor props (MA 5.5x4 and 4.5 I think) in the program. It shows them stalled up to near flight speed. Climb is better however.
From what I'm reading around here, the 6x3 is a little low pitched? I'd think that unless you have a real fast plane, a slower park flyer would benefit from the torque at lower speeds. Am I right here?
Old May 16, 2001, 04:54 AM
Joined Nov 2000
Yes, the CAM 6x3 (and smaller CAM 4.7x2.3) folders are really intended for slowish flying e-gliders using direct drive S400 (S280 for the smaller prop), and are fairly low-pitched.
On the Twin Star (8 cells), at full throttle they didn't give enough forward speed for comfort when flying in windy conditions. But they were almost fully unloaded in level flight so current draw was low and duration excellent. And with the spinners they looked great!
Discussion AF 010 on 3S w/Graupner CAM 6x3 folder? jrb Power Systems 7 Jan 09, 2007 01:48 PM
Can 6 or 7 AAA Nimh handle 6v 400 and 6x3 folder ? Haldor Electric Plane Talk 7 Aug 03, 2001 01:45 AM
Finally got my Jas-Cam running off one flight pack jas_Qfix Power Systems 7 Jul 23, 2001 07:25 PM
Best Battery Pack? Lochrie High Performance 6 Jun 08, 2001 09:11 AM
Whats the best battery pack for the Litestick? mrebman Parkflyers 10 May 30, 2001 12:01 PM
