Old Sep 13, 2005, 11:22 PM
Joined Apr 2005
Anyone know why prop would have a loud hum?
I got my brushless put on today. It all works fine, but when I get above 3/4 throttle the prop (on a prop saver) starts to make a humming sound. The more throttle I give the louder the hum. Any idea what would be causing this? It sounds like its going to break at WOT.
xray328 is offline Find More Posts by xray328
Old Sep 13, 2005, 11:25 PM
Joined Jan 2004
take a look at this thread
http://www.rcgroups.com/forums/showthread.php?t=414874
summary...balance your prop...oh, and make sure your (banded?) prop saver has enough, and tight enough, bands to hold the prop securely
kirkpul is offline Find More Posts by kirkpul
Old Sep 13, 2005, 11:43 PM
Senior Moment Member
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
It would be helpful to know what prop you're using.
If it's a GWS, you're probably trying to spin it too fast causing the blades to flutter, hence the humming sound. The hum is a warning that the blades are about to go ballistic. I've experienced the same thing with GWS props; kinda scary
babblefish is online now Find More Posts by babblefish
Old Sep 13, 2005, 11:47 PM
Joined Apr 2005
Yep, its a GWS prop. I hate those things. Its the only prop I could find in a 8x4.3, APC doesn't make that size. Anyone know where I can find a quality 8x4.3 or 8x4 prop?
koko76's Avatar
Joined Jul 2005
Definitely check the number of bands holding the prop on. I tried using a prop saver on my latest plane, in turns and high load situations I would hear a similar hum noise, anything above 3/4 throttle as well. I happen to have a collet type adapter with me so I switched to that, same prop. Noise went away. I concluded that the prop saver wasn't holding tight enough, so I have stopped using it on that plane. I figure if I have to band it on there super tight, what is the point, as the more rigid I hold it, the more like not having the prop saver is. YMMV.
koko76 is offline Find More Posts by koko76
Old Sep 14, 2005, 01:36 AM
Maryland, USA
Joined May 2004
Are you using the GWS SF or HD prop?
Kwok_Yu is offline Find More Posts by Kwok_Yu
Old Sep 14, 2005, 02:27 AM
Joined Apr 2005
Not sure, its grey if that helps.
Old Sep 14, 2005, 07:42 AM
Straight up is all I ask
Fairfield Ct USA
Joined Apr 2002
try the hd prop
jmolwitz is offline Find More Posts by jmolwitz
Old Sep 14, 2005, 11:01 AM
podavis's Avatar
Louisville KY
Joined Nov 2004
I've had GWS props that howled like hell's hounds on high rpm cdr motors. From the comments I overheard it certainly got people's attention. I agree with the flutter explaination. The vibration can have different shapes of bending or flexing and the stiffness of the prop saver and the connection to the propsaver can resist some of the vibration 'modes' ('modes' is the engineering term). I cinch my prop savers on tight with nuts and washers, and lash the props on with multiple wraps of a rubberband. It's defeating the purpose of the propsaver, but I can't fly a plane that can compete with the tornado sirens.
podavis is offline Find More Posts by podavis
Old Sep 14, 2005, 11:18 AM
"$$Crashable Income$$"
Tallahassee, FL
Joined Feb 2004
if your prop is humming or whistleing its bored. get it a psp or gameboy or portable dvd player to shut it up.... ;p
maux is offline Find More Posts by maux
Old Sep 14, 2005, 11:53 AM
Toronto Canada
Joined Dec 2002
Check your blade tracking.
One blade may be ahead of or behind the other. Gently bending the offending blade will help.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Sep 14, 2005, 12:02 PM
Old Tyme Electric
steve crewdog's Avatar
Joined Mar 2005
Maybe it doesn't know the lyrics?
(sorry, could not resist.)
steve crewdog is offline Find More Posts by steve crewdog
Old Sep 14, 2005, 12:13 PM
Ron H's Avatar
Bishopville S.C.
Joined May 2003
Ron H is offline Find More Posts by Ron H
Old Sep 14, 2005, 12:14 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Go with an 8x4 GWS HD, APC E or Graupner Slim or CAM. I have test run all the GWS RS props and viewing them from side-on is interesting (and scary). As they approach their limit of about 40-50,000rpm/diameter, in the larger diameter props especially, the tips bend a LONG way, and the mid-blade section flutters alarmingly - that's where your noise is coming from.
Cheers, Phil
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 14, 2005, 12:31 PM
KLH
Pack Rat
KLH's Avatar
Hayward CA / Valley Springs CA USA
Joined Jan 2001
Phil
You've got guts! I hope you had your safety glasses on or better yet a large thick piece of lexan between you and the props when you're testing them.
kern
KLH is offline Find More Posts by KLH
Does anyone know how to make a prop from yogurt cartons? mortonj69 Scratchbuilt Indoor and Micro Models 39 Dec 08, 2004 09:54 AM
I now know why I have failed to get through to Highflight gtstubbs Life, The Universe, and Politics 2 Apr 09, 2004 03:16 AM
Anyone know if Kavan have a WEB site (of their own) AuzzieRCFlyer Parkflyers 3 Mar 21, 2003 12:18 AM
Anyone know where i can purchase a pusher prop? kushal_22 Foamies (Kits) 4 May 09, 2002 01:24 AM
Anyone know if KSJ have a web site DaveRC Electric Heli Talk 1 Oct 01, 2001 06:55 AM
