Old Jun 23, 2005, 11:19 AM
down_shift's Avatar
United States, VA, Leesburg
Joined Feb 2003
Making a 2/3AAA end-to-end receiver pack
I just finished making a 4 cell end-to-end pack of GP370 (2/3AAA cells). After removing the heat shrink, burnishing the ends, CA'ing back on the donut insulator, and tinning the ends, I used a 40watt hammer head iron to connect the cells. The iron was on the cells for less than 1/2 second and the cells were mated almost instantly after the iron was removed. The four cells appear to have a great bond between them (can not break them apart w/ low force).
A few questions. Any danger of damaging these little cells by over heating w/ the above technique? Also, the first charge of this pack took in over 900mah!?! The delta V cutoff was set at 0.05mV. Is this the correct setting or should it be lower?
down_shift is offline Find More Posts by down_shift
Old Jun 23, 2005, 12:46 PM
meteor's Avatar
Ontario, Canada
Joined Nov 2002
What charge rate were you using?
Unless you were using a very low charge rate, and the cell was just charging in a slow/trickle mode where the cell just bleeds off power with gentle warming, there's something wrong with 900mAh going in!!
I alway use 0.02V for Ni-Mh packs, and re-peak if the cell is not slightly warm. (temp is the most basic, yet most reliable, way to tell if a cell is charged!)
Soldering heat shouldn't be a problem, as I have many 650mAh 2/3AA packs soldered end-to-end which I have flown dozens of times in my MiG-15. (they're a bit bigger, but not much...)
Yikes
meteor is offline Find More Posts by meteor
Old Jun 24, 2005, 04:21 PM
Watts the Point
netmechanic's Avatar
KY,USA
Joined Jul 2004
I use the same GP cells for my EDF's. I ake all the packs as I buy the cells loose from a local bettery place. Haven't had any problems with them to date.
netmechanic is offline Find More Posts by netmechanic
Old Jun 24, 2005, 04:45 PM
down_shift's Avatar
Joined Feb 2003
Update - changed the delta V cutoff to 0.03mV (the lowest you can go w/ the Triton) and the pack will not indicate that it is full (charger stays on until reaching 500mah, the hard limit I set). Discharge can pull out over 300mah from the pack. Weird that the pack keeps on taking a charge.
FS: 4CH Receiver, 2 Servos, 7.2v Battery Pack tdavis Aircraft - Electric - Airplanes (FS/W) 3 Mar 28, 2004 09:52 PM
FS: 4CH Receiver, 2 Servos, 7.2v Battery Pack tdavis Aircraft - Electric - Helis (FS/W) 2 Mar 28, 2004 09:09 PM
Fiber Card Stock, at end of battery pack aireze Batteries and Chargers 3 Dec 23, 2002 01:20 PM
end to end battery pack jig photos flyerman Batteries and Chargers 17 Oct 12, 2002 02:08 PM
Disassembling an end soldered pack? SchiessCo Power Systems 7 Feb 24, 2002 10:50 PM
