Old Mar 01, 2004, 06:27 PM
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
Retiming an electric motor?
I made a delta wing with a pusher setup. I reversed the wires so it would run correct, however someone told me that a motor was set us to run counter clockwise in timing and brush wear. How do you correct this? I can't seem to find the right size reversed props so how do you retime a 400 stock motor?
quailbird is offline Find More Posts by quailbird
Old Mar 02, 2004, 02:11 AM
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Greetings,
To advance the motor, rotate the back plate in the oppisite direction of desired rotation. hope this helps.
Jared
jcstalls is online now Find More Posts by jcstalls
Old Mar 02, 2004, 03:59 AM
N. Staffs, UK
Joined Jan 1997
A new Speed 400 is neutral timed. It will run equally well in either direction. If one has been running for a while in one direction the brushes "bed in" and it won't like being made to run the other way, even if you do retime it. The simple solution is to get a new motor.
You can get a little extra power by changing the timing for the direction of rotation but IMO it's a lot of fuss for very little gain.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Mar 02, 2004, 08:39 AM
quailbird's Avatar
Joined Nov 2003
Thanks guys! You stay with this sport or hobby and you begin to learn, here a little, there a little or.......until your money is all gone. LOL
Old Mar 02, 2004, 11:03 AM
jcstalls's Avatar
Joined May 2002
You are quite welcome.
I have learned so much from others on this board, and continue to do so.
Steve has some great points. Especially if your motor has been run a while.
Some of us fly sp400 LMR compition and every little bit extra helps. Water breakin and retiming does help. For my fun planes that run these little can motors though, I usually just leave them box stock.
Jared
Old Mar 02, 2004, 11:45 AM
quailbird's Avatar
Joined Nov 2003
Thanks!
breaking in an electric motor robster94gt Scale Boats 2 Nov 07, 2003 03:46 PM
How to identify an electric motor? Ward Power Systems 3 Apr 07, 2003 08:20 AM
Information needed for adding an electric motor to my plane Biggles604 Sailplane Talk 1 Oct 24, 2002 03:39 PM
