Old May 12, 2013, 07:15 PM
I'm in Geek Mode
United States, OR, Hillsboro
Joined May 2013
Help!
Motor comes on when receiver turns off
Posted in wrong section
flying_slow is offline Find More Posts by flying_slow
Old May 12, 2013, 07:22 PM
The cycle is complete.
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
If you're turning the tx off before the aircraft, your receiver is going into failsafe mode. Rebind with throttle at zero.
And in the future, always turn the aircraft off before you turn off your radio. You're lucky the aircraft didn't take off on you.
Sabin is online now Find More Posts by Sabin
Question Whats different when the ACC is turned on? bigheaded5 Multirotor Electronics 5 Apr 30, 2013 06:38 PM
Help! motor starts when cutoff is turned off royalstar05 Power Systems 5 Mar 18, 2013 11:01 AM
Discussion HELP!! Motor comes on when trans goes off! Kholder116 Radios 3 Jun 20, 2012 06:56 AM
Master 99 turns motor on when it should be off, help... NOS Rob Power Systems 2 Nov 06, 2002 01:56 AM
Should the ESC turn off the motor when the Tx is turned off? erashby Power Systems 19 Sep 10, 2001 08:25 PM
