Old Apr 13, 2013, 12:42 PM
Yak 52's Avatar
UK
Joined Jan 2009
Originally Posted by kcaldwel View Post
You just need MATLAB Component Runtime (MCR) that is free from Mathworks:
http://www.mathworks.com/products/co...mcr/index.html
Any of the lifting line or VLM codes are really pretty simple things that will not model the more complex flow on a wing, only produce linear wakes, and most do not include any facility to model low Re effects. XFLR5 attempts to do that, but...
The problem with relying on XFLR5 too much is it cannot properly rank the efficiency of planforms even at high Re. It will guide you in the wrong direction for planform shape and tip airfoils.
We really need a high order panel code to do the level of analysis many people want to do, but that requires a lot of computer power and the programs are very expensive as well. There is a free Linux code called Open Foam that can potentially do that, but the learning curve will be very steep for most of us:
http://www.openfoam.org/
Kevin
Thanks. Since reading your thread I've adjusted my approach so as to not bother modelling curved or raked wing tips too closely, just approximating the the planform so as not to add loads of chord positions.
Yak 52 is offline Find More Posts by Yak 52
Old Apr 22, 2013, 06:50 PM
Sink stinks
Montag DP's Avatar
United States, GA, Atlanta
Joined Apr 2005
Kevin
OpenFoam does panel methods? I thought it was only full CFD (full grid and Euler or Navier-Stokes solutions).
Montag DP is offline Find More Posts by Montag DP
Old Apr 28, 2013, 04:02 PM
ShoeDLG's Avatar
Germany, BW, Stuttgart
Joined Mar 2012
If anyone's interested in the Vortex Lattice program I've been using for some of the analysis I've shown in this thread (and a few others), it's available for iPad (for free) here:
https://itunes.apple.com/us/app/ivl/id635617735
You can download the manual here:
http://ivlsupport.wordpress.com
Both are still works in progress so thanks in advance for your patience. Among other things, it should be a pretty accurate tool placing CGs with complex geometries.
ShoeDLG is online now Find More Posts by ShoeDLG
Old Apr 28, 2013, 04:37 PM
Yak 52's Avatar
UK
Joined Jan 2009
Nice one! I really like the way you present results with it. Just wish I had an iPad
Old Apr 28, 2013, 09:50 PM
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
Is there a version for the iPhone? Don't need fancy UI really just need to plot the results so the screen size of the iPhone shouldn't really be a limitation.
slebetman is offline Find More Posts by slebetman
Old Apr 29, 2013, 05:48 AM
ShoeDLG's Avatar
Joined Mar 2012
No, no iPhone version. There's no technical reason there couldn't be, but "shoe-horning" the interface to fit on the iPad was challenging enough (the interface for defining the configurtion demands more real estate than the interface for displaying the results). I think an iPhone implementation would make for a truly frustrating user experience.
Old Apr 29, 2013, 10:50 AM
Sink stinks
Montag DP's Avatar
Joined Apr 2005
That's too bad. I'd like to give it a try on my iPod, but I can imagine it would probably be pretty hard to display anything meaningful on such a small screen.
Discussion Low cost power sytem for 3+m gliders kcaldwel Electric Competition Soaring-F5J/ALES/e-Soaring 68 Oct 14, 2013 07:36 AM
Discussion Optimum planforms for low Re wings - strange XFLR5 results found kcaldwel Modeling Science 34 Mar 22, 2013 01:40 PM
New Product New Sony low power GPS with SensorFusion stan11003 Multirotor Electronics 0 Mar 14, 2013 12:21 PM
Discussion looking for schulman wing planform & theory Default User Sailplane Talk 2 Feb 12, 2013 10:14 AM
Discussion TX or device that warns you before the BEC cuts you power for low voltage? cloud_9 Batteries and Chargers 16 Feb 01, 2013 07:27 PM
