Old Mar 18, 2013, 02:59 PM
flyboy1001e's Avatar
Nelson B.C. Canada
Joined Feb 2003
Help!
Lm317 formula?
Hi! Guys
Could somene tell me the formula for calculating the R4 current resistor in this circuit. I can't see how the values given were figured out. I would like to build a 2s 240ma version, but would like the formula for other values.
Thanks Mike
https://sites.google.com/site/donuts...-the-schematic
flyboy1001e is offline Find More Posts by flyboy1001e
Old Mar 18, 2013, 03:24 PM
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Try a Google Search on 'LM317 Datasheet' you will likely find the voltage formula on the first page.
R4 then acts to limit the charge current which can be no more than the voltage output of the regulator - the battery voltage divided by the resistor.
So if Vregulator = 4.2v, Vbat is 3V, and R is 1.2R, the current would be (4.2-3)/1.2 = 1A.
srnet is offline Find More Posts by srnet
Old Mar 18, 2013, 06:40 PM
Nelson B.C. Canada
Joined Feb 2003
Hi srnet
I have the data sheet, and your example work fine for:
If you try it on the other examples it does not or I have something wrong.
eg
Vregulator = 4.2v, Vbat is 3V, and R is 1.8R, the current would be (4.2-3)/1.8 = .666666A ---should be 1.5A
eg
Vregulator = 8.4v, Vbat is 3V, and R is 4.7R, the current would be (8.4-3)/4.7 = 1.1489A ---should be .550A
If I work it backward (.550A x 4.7R)-8.4V = 5.815V Vbat
Obviously Vbat must change. BTW: Vbat does mean Voltage Battery right?
Did you arrive at Vbat is 3V by working it backward?
Thanks for the help, hope there is a formula for this. Will keep trying.
Old Mar 18, 2013, 07:09 PM
Staffs, UK
Joined Nov 2003
The reason you're having trouble understanding the values in that link you posted is because they're wrong. In particular 1S 1.8R is wrong as you can see if you look at the other values. If 1.2R = 1A and 2.2R = 0.55A then there's no way 1.8R is going to be 1.5A.
OTOH 0.8R would be about right.
BTW VBat = 3V is based on what it says in the text "...battery voltage is lowest. (that is 3V min for a lipo)". I wouldn't let my lipos get below about 3.6V but then I wouldn't use such a crude circuit to charge lipos either, not when there are plenty of better ones about.
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 18, 2013, 07:19 PM
Stuart
srnet's Avatar
UK, Cardiff
Joined Dec 2008
Indeed, there are plenty of ready made and cheap Lipo chargers that will look after your Lipos a lot better and are a lot safer to use.
The 'simple circuit' has no low voltage protection, it can be hazardous to attempt to charge a Lipo that has fallen below 2.5v or so, which is why most proper chargers will prevent you doing this.
Old Mar 18, 2013, 07:20 PM
Reduce the drama...
rick.benjamin's Avatar
USA, OR, Damascus
Joined Apr 2004
Here is a thread with lots of questions answered
http://www.rcgroups.com/forums/showthread.php?t=130567
Here is Scott Henion's chargers. I especially like #3
http://www.shdesigns.org/lionchg.html
rick.benjamin is offline Find More Posts by rick.benjamin
Old Mar 18, 2013, 10:10 PM
Nelson B.C. Canada
Joined Feb 2003
slipstick (Steve)
I guess I didn't think that through to clearly of course your right. I usually stop discharging at 3.7v, 3.8v.
srnet (Stuart) Yes it has no low voltage protection, kind of like the earlier lipo chargers.
rick.benjamin (Rick I hope)
The charger I actually built was electron_head's from your first link.
Scott Henion's chargers are nice too.
To all
How this started out, I have a young guy coming over to look at my plane and stuff. His mom says he's really into planes.
So I thought I'd fix him up with something to start out.
A long time ago I bought a few wally world flying wings for gifts and occasions like this.
Thought I better check it out make sure it works the battery was a nimh 4.8v 110mah If I had those cells
I would have soldered up a couple more packs, but I didn't.
I built a 2s 240mah lipo pack with 5v regulator, same weight as old pack and fits. Now he'll need a small lipo charger
I was going to build the one I asked about in the thread.
(good thing I was having trouble with the charge rate) and didn't build it.
electron_heads does work fine for this job
Thanks to all; knowing you will make a young guy happy
Sold proboat formula fastech miclacom Boats (FS/W) 10 Feb 11, 2013 06:20 PM
Discussion LM317 not regulating properly offroadheli DIY Electronics 6 Oct 16, 2006 08:41 PM
LM317 constant current charger. thermite Batteries and Chargers 4 Jun 21, 2003 10:16 AM
Please help me with LM317 charger j8m8l Batteries and Chargers 8 Nov 18, 2002 12:11 PM
adding LED to LM317 charger? art4242 Parkflyers 10 Dec 21, 2001 01:26 PM
