Old Mar 01, 2013, 05:28 PM
Dixie Sky Devils AMA# 1015548
tupeloflyer's Avatar
United States, MS, Tupelo
Joined Oct 2012
Has anyone tried the Sabre 44 from valuehobby?
I was browsing thru VH's ARF planes and noticed the Sabre 35 has a little bit bigger brother! the Sabre 44 profile. wondering if anyone has tried one? and what kind of setup works best? the recommended setup is never right...
tupeloflyer is offline Find More Posts by tupeloflyer
Latest blog entry: Sig New ARF 4 Star 64
Old Mar 01, 2013, 05:40 PM
I think I forgot how to fly RC
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
some nice info here towards the end
http://www.rcgroups.com/forums/showt...hlight=sabr+44
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Mar 02, 2013, 07:50 PM
ProBro Wulf
Wulf_Flieger's Avatar
Joined Oct 2006
Hey Spaz wake up!. People are asking about yer new plane here.
Wulf_Flieger is offline Find More Posts by Wulf_Flieger
Old Mar 11, 2013, 04:23 PM
Retired in NC
Rich in ILM's Avatar
USA, NC, Wilmington
Joined Sep 2010
I just finished and soloed the Sabre 44. I used a Tacon Big Foot 25 motor, 13x4 prop, 40 amp ESC and the reccomended MG sevos. I was surprised at how tail heavy it is and had to use a 4000 4s battery mounted way up front to get the CG to work out. So far so good. But it is a tail heavy config! Anybody else? I have all 3 of these profiles. 35, 44, and 47.
Rich in ILM is online now Find More Posts by Rich in ILM
Old Mar 12, 2013, 11:49 AM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
I decided to fill in the suff I didn't post before.
Here is all the specs and equipment I used:
4s 40c 4000 Chinahobbyline Battery
Tacon Power 25 870kv Motor
Dynma Detrum 40 amp ESC (Hobby Wing Pentium)
Power HD 1711MG Metal Gear Servos
13x4 APC clone prop
R610 Hobby King Orange DSM2 receiver
Bench Test:
16.6 Volts
47.6 Amps (static)
739 Watts (static)
2 lbs. 3 oz. without battery
3 lbs 3 oz. with battery
CG seems good at 4" from leading edge.
This required everything way forward. The baterry is monted vertical just behind the motor mount.
I know I am running the Tacon way over suggested wattge but I don't use full throttle a lot, the motor hasn't felt hot, and I have been using the same setup in a Stik 48 for several years. These are great $20.00 motors if you haven't tried them. They are at Hobby Partz.
Old Mar 12, 2013, 04:52 PM
smoke is my wattmeter
Longview, Tx
Joined May 2008
Wow, a one pound battery in a 3 pound plane. Hate to hear that because it looks like a nice plane. Thanks for posting your setup.
krexken is offline Find More Posts by krexken
Old Mar 16, 2013, 12:07 AM
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
Yeah maybe if somebody was smart enough to send me a link
4" sounds nose heavy? Ill have to check mine, but I've been in Dallas for work for three weeks, very busy lately..
This plane is something the factory came up with on their own, they asked me if they could do it I said sure.. They did fly it with 4s 2200's I thought.. I have not even flown mine yet
spastic is online now Find More Posts by spastic
Old Mar 16, 2013, 12:22 AM
ProBro Spaz
spastic's Avatar
Buffalo, NY
Joined Aug 2004
Btw here is how I reduced some weight in the tail, didn't use the included iron plate they included and I didn't use an of those oversize wheel collars either.. Every bit helps.. Also on the main wheels I used spacers from APC props instead of the heavy wheel collars and cut the shafts close after mounting the wheels, use lock tight on those things too
Old Mar 18, 2013, 07:42 AM
ProBro Wulf
Joined Oct 2006
Hey Spaz it's your frigging airplane you look for the thread.
And while your at it throw that stupid landing gear in the trash if you wanna save some weight.
Here's a video of my friend AD3D flying his Sabre-44 without a one pound battery.
Sabre-44 (6 min 13 sec)
I can't remember his power system but it was a "torque" motor with real bad bearings and a 4 cell pack.
Thank you Wulf. Your welcome Spaz
Old Mar 20, 2013, 06:05 PM
Team LRC
Mchone, Jake's Avatar
United States, KY, Berea
Joined Dec 2003
Alright who left the back door open
Mchone, Jake is offline Find More Posts by Mchone, Jake
Old Mar 20, 2013, 07:14 PM
ProBro Eric in Jax
p0stal's Avatar
United States, FL
Joined Mar 2006
Just started mine
Going to keep it lite and try a 500+ watts 3s setup
Motrolfly 2815-950
Motrolfly 45amp esc
HS 82's
13x6.5 xoar
Shooting for the 2.8 auw
Thanks Spaz for making this happen!
p0stal is offline Find More Posts by p0stal
Old Mar 20, 2013, 07:25 PM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
Originally Posted by p0stal View Post
Just started mine
Motrolfly 2815-950
Motrolfly 45amp esc
HS 82's
13x6.5 xoar
You are going to have to figure out how to get a bunch of weight out of the tail if you want to hit the 4" COG with your target weight. I was astounded that I had to use a 1 pound battery as far forward as I could get i. BTW it flies very balanced so the COG is fairly close as specified. IMO, this is not the first VH design that was either a blind scale up or was a quick gas conversion. That being said I have a ton of planes from VH and will continue to buy from them. But this isn't nearly as well balanced as the 35. It sure would have been better with a longer nose section.
Old Mar 20, 2013, 07:59 PM
Team LRC
Joined Dec 2003
Longer nose = less tumble. Just use 4 or 6s power.
Mine is getting a 40fp. Should be plenty of weight I'm thinking lol.
Old Mar 20, 2013, 08:14 PM
Retired in NC
USA, NC, Wilmington
Joined Sep 2010
40fp?
Old Mar 20, 2013, 09:00 PM
Team LRC
Joined Dec 2003
2 stroke. Go ahead, make fun :P
Question Has anyone tried using these monitors as a cheap start to FPV Zapphoid FPV Talk 12 Apr 21, 2013 04:11 AM
Question Just wondering if anyone has tried a J Concepts Punisher body on a 1/10 E Revo yannicksjh Off-road Cars 2 Feb 27, 2013 12:40 PM
Discussion Has anyone tried these Pyro gun and flare systems? bsbauman Giant Scale Airplanes 2 Feb 25, 2013 05:27 PM
Discussion Has anyone tried this 5" fpv recorder ecks FPV Talk 0 Feb 14, 2013 04:07 PM
Question Has anyone tried the Slash 4x4 chassis mod - Slayden - lcg JViolet10 Off-road Cars 1 Jan 21, 2013 12:41 AM
