Old Oct 04, 2014, 09:45 PM
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Steady beeping means no signal to the esc. Take the prop off. Unplug everything. replug.
Look close at the polarity of the plugs.
Put the throttle all the way up. Plug in the plane. Wait till the beeping stops, close the
throttle. Check all controls. Rebind.
On the motor stopping issue, does the motor spin free?
Kimber is offline Find More Posts by Kimber
Old Oct 05, 2014, 11:16 AM
Canada, NL, Clarenville
Joined Aug 2014
Still having issues
Hi Kimber
Thank-you for your assistance. I disconnected everything as shown in the somewhat blurry pic(servos from Rx, Rx from ESC, ESC from battery and ESC from motor) as you suggested, reconnected everything and followed your instructions. Now the ESC is rapidly beeping and I still have no response from the motor. I have included a video of the process(If it uploads) so you can experience my issue more fully.
Is there a chance the ESC is blown? Everything, including the motor, was working perfectly prior to trying to reset the motor brake.
Any more ideas? I don't have an extra ESC to test it with other than one already in a plane. I guess my next step could be to install the motor in another plane to eliminate the motor as an issue.
Sensei Beeps (1 min 48 sec)
Thanks Again,
Carl
NL466RCFlyer is offline Find More Posts by NL466RCFlyer
Old Oct 05, 2014, 12:03 PM
SUCK LESS
FR4-Pilot's Avatar
United States, IL, Lombard
Joined May 2009
It's possible that combining re-programing the ESC and re-binding the receiver in the same step is causing problems. Meaning, only do one, unplug the battery from the plane, then do the other.
FR4-Pilot is online now Find More Posts by FR4-Pilot
Old Oct 05, 2014, 12:40 PM
SUCK LESS
FR4-Pilot's Avatar
Joined May 2009
Sorry - watched your video again and fired up my plane - you must be using a different ESC as it's startup beeps are different than the stock one. The stock ESC doesn't make those 3 initial beeps (low-med-hi) when you attach the battery ...
Old Oct 05, 2014, 03:42 PM
Joined Aug 2014
Good News! I got the throttle working again and the motor brake is off!
You asked about the motor running free. Compared to another outrunner motor I have here I would have to say no. It does turn when I twist the shaft but it does so in very discrete increments (even when unplugged) which I assume has to do with the field magnets. It spins but stops almost immediately if I give it a twist with my fingers. The other motor I have spins very smoothly and continues to turn when I give it a spin.
While on the topic of the motor. I noticed that mine seems to be angled slightly to the right is this normal? Or did I do some motor mount damage when I nose dived on the maiden?Will it be a huge deal or will some extra trim take care of it?
Carl
Old Oct 05, 2014, 08:32 PM
Hobby King Hater
Kimber's Avatar
USA
Joined Mar 2005
Slightly to the right and slightly down.
I was just asking about the motor to make sure it was free, it sounds like it is ok. Some have more magnet drag than others.
Old Oct 16, 2014, 10:30 PM
SUCK LESS
FR4-Pilot's Avatar
Joined May 2009
If anyone's interested, a comparison between the Sensei and Apprentice:
http://www.rcgroups.com/forums/showp...37&postcount=1
Old Nov 07, 2014, 04:55 AM
Darien, Illinois
Joined May 2004
It will be fine, just won't fly quite as long, assuming it's also a 3S (3-cell) battery.
FRENCHSTAN is offline Find More Posts by FRENCHSTAN
Old Yesterday, 10:59 PM
I use EXPO and Senior Rates
Rightfly's Avatar
United States, MI, Custer
Joined Jan 2010
Looking for parts.
Greetings to all you Sensei flyers. Seems as though this thread has been very quiet so hope some are still here. My flying field is too white and the white is also too deep so am waiting for spring.
I am thinking of building another Sensei from some spare parts I have accumulated but am short the wing joiner assembly. Do any of you have one in your parts bin?
Give me a PM if you have one you would like to sell.
Roger
Rightfly is offline Find More Posts by Rightfly
Alert Flyzone Sensei wmcneal Foamies (Kits) 7 Sep 30, 2013 05:00 PM
