Old Mar 16, 2008, 05:33 PM
Trex 450 V2, Spektrum.
airsoft1779's Avatar
USA, SC, Greenville
Joined Aug 2007
Question
Why Are HH Gyro's Always at the front or back of the Frame???
Title saids it all
Is it possible to put one near the main shaft or in the center and just turn the gain up
Is it more accurate farther away from the center?
airsoft1779 is offline Find More Posts by airsoft1779
Old Mar 16, 2008, 06:01 PM
Dodging Birdstrikes
Houston Texas
Joined Oct 2007
Hi airsoft
I am asking the same quesion over in the micro forum for a Firefox 100 that I am putting the finishing touches on, so can't help you but if I get a answer I pass it on to you.
Peace
Parrot ATC is offline Find More Posts by Parrot ATC
Old Mar 16, 2008, 06:20 PM
The Great Santini
Santini's Avatar
Madison, NJ 07940
Joined Dec 2004
I believe it just needs to be in the same plane as the tail and mainshaft, therefore, it is fine sitting up front in the nose area, or back of the main shaft. It need to be oriented correctly, so it can be flipped so the top is up or down, but not sideways or anything else. For example, in a trex, you can place it on top of where the boom is secured to the frame or flip it and place it underneath, which is preferred so it does not take a hit from a paddle in a crash; or it can be placed out front, under the batt tray. Most prefer to place it under the boom facing down so its less likely to take a hit.
Santini is offline Find More Posts by Santini
Old Mar 16, 2008, 08:10 PM
Denver, CO
Joined Dec 2005
Works great under the main shaft. I would say it works better under the shaft. Kind of hard to rate that since it is a Futaba that works good almost anywhere. This is my Piccolo. http://www.rcgroups.com/forums/attac...mentid=1215515
Roto Rob is offline Find More Posts by Roto Rob
21st Century Space Cowboy
TachyonDriver's Avatar
Chipping, Lancs, UK
Joined Oct 2006
If you really wanted to, you could stick the gyro on the side of the frame..... AS LONG AS the gyro's axis is parallel to the main shaft, you can position it anywhere around the mainshaft. I suppose the main reasons why you see the gyro mounted at the fornt or back of the mainshaft is that it would look kind of silly hanging out of the side of the heli.
Tach.
TachyonDriver is offline Find More Posts by TachyonDriver
Old Mar 16, 2008, 08:12 PM
Singapore
Joined Jan 2004
Actually the best (sensitivity) of the tail gyro should be at the same axis on the main shaft (that is below the main shaft).
The problem of putting gyro just below the main shaft are:
1. Difficult to adjust/trim it or set the Nor/Rev switch.
2. Too close to motor or ESC. Most gyro are very sensitive to EMF generated by the motor and ESC.
SH
Super_Hornet is offline Find More Posts by Super_Hornet
Old Mar 16, 2008, 08:17 PM
X-Ikarus
Reflex1's Avatar
United Kingdom, North York
Joined Feb 2003
Originally Posted by airsoft1779
Title saids it all
It does not matter were you place it , it only senses Rotation.
normally front or back , not many gyro's will fit in the centre
those that do I haven't noticed any difference in performance
Although I'd agree with SH below the main shaft will give the highest
mechanical gain.
Reflex1 is offline Find More Posts by Reflex1
Old Mar 17, 2008, 07:27 AM
Vince Herman's Avatar
United States, OH, Strongsville
Joined Nov 2000
Another vote for "Placement does not affect gyro"
You can place it anywhere, and it will still detect rotation equally well.
Orientation does matter. The axis of detection for the gyro must match the axis of rotation that you are trying to control.
Now, there ARE some placement considerations other than rotation detection.
1. vibration - you do not want to place the gyro where it will pick up excess frame vibration. The boom block is often used, as is the bottom of the main frame.
2. RF interference - you want to distribute all of your RF emitting/sensitive components as far away from each other as possible.
Vince Herman is offline Find More Posts by Vince Herman
Old Mar 17, 2008, 08:23 AM
Maryland
Joined Nov 2006
As the others have stated, it doesn't matter where it's placed. So with that said, place it where you feel it is best protected and away from electronics like your esc and motor.
Skarn
Skarn is offline Find More Posts by Skarn
Old Mar 17, 2008, 12:59 PM
electric head
khaoz's Avatar
Randburg
Joined Jul 2005
I've seen certain gyro manufacturers (CSM I think) recommend playing the gyro's as close the the pivit point as possible.
khaoz is offline Find More Posts by khaoz
Old Mar 17, 2008, 03:26 PM
USA, SC, Greenville
Joined Aug 2007
Im trying to move the gyro where my receiver went on my Falcon 3d to try and get rid of the extion of the servo wire, I was having inconsistant tail failures when I was flying and that is the only problem I could think of, but you said to try and keep it away from the motor/ESC and the ESC is right below it, I think ill try to mount it on the boom somehow.
Any other suggestions
Old Mar 17, 2008, 07:31 PM
Nova Scotia, Canada
Joined Apr 2006
You can mount the gyro anywhere on the heli so long as the sense axis is parallel to the mainshaft. The gyro sense's angular motion not linear. All parts of the heli turn about the mainshaft at the same angular velocity. It makes no difference to the gyro is on the tip of the nose or tail. However some people will caution you about putting it too close to the mainshaft bearings to avoid bearing noise affecting the gyro operation.
airsoft1779, Some ESC's will generate more noise than others. I keep my RX and gyro as far away as possible from my ESC.
Stikflyer is offline Find More Posts by Stikflyer
Old Mar 22, 2008, 07:55 PM
Tennessee
Joined Jan 2007
Thanks Stikflyer, good bit of information there. I was curious as to the possible change in sensitivity when moving the gyro closer or further away from the center of pivot. (main shaft) It makes sense that if the gyro senses only angular differences the distance from the pivot point would be irrelevant....I think.
Likestofly is offline Find More Posts by Likestofly
Old Mar 23, 2008, 09:30 PM
Genoa, Italy
Joined Sep 2007
I don't know exactly what kind of sensors are used in the HH gyros, but I remember some of them actually suffer an error from acceleration. That is, they take ("linear") acceleration for a (small) angular velocity. But I think this doesn't matter too much because they are used in a closed-loop control, so this effect reduces to a curiosity "for the interested reader". But, this is why (I think) someone suggests to put them as close to the pivot point as possible.
valerix is offline Find More Posts by valerix
Discussion Raptor 30 v2 Gyro on front or back? e_brown Fuel Heli Talk 6 Feb 07, 2008 08:15 PM
Why are FP heli's so much easier to fly? neuroblade Micro Helis 11 Sep 05, 2005 10:49 AM
Why are eBay Heli's considered cheap? aughtx Micro Helis 10 Nov 13, 2004 02:38 AM
Alfa Mig15, Elevator Servo, Front or Back? stuka Electric Ducted Fan Jet Talk 3 Aug 21, 2004 08:32 PM
why is HH gyro not compatable with the feda mixer SpaKack Micro Helis 5 Apr 07, 2003 05:16 PM
