Old Feb 06, 2006, 09:24 AM
Joined Aug 2004
cheap prop balancer?
anyone have any ideas about a cheap prop balancer? or making one from scratch?
sylentbob3 is offline Find More Posts by sylentbob3
Old Feb 06, 2006, 09:34 AM
Deletedfor proving Nauga wrong
Joined Mar 2005
find an appropriate diameter piece of rod for the hole in the center of the prop.
push the rod into the prop.... set on 2 water glasses wit the prop parallel to the ground.
heavy blade will drop.
The fancy ballancers are just that.... fancy.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Feb 06, 2006, 02:42 PM
Are you one of these
rcboatnut's Avatar
loveland colorado
Joined Nov 2003
I think greatplanes has a magnetic prop balancer that is great, they are probably cheap or you could take the idea and make your own.
rcboatnut is offline Find More Posts by rcboatnut
Old Feb 06, 2006, 03:15 PM
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
The "Great Planes Fingertip Prop Balancer" http://www2.towerhobbies.com/cgi-bin...?&I=LXK247&P=7 is cheap ($4.29) and works pretty well. You can do the glass bit with it, or if you want, you can make it into a magnetic balancer. The trick is to have really low friction pivot points.
I use one of the Top Flight magnetic balancers ($19.99).
- Roger
gnofliwr is offline Find More Posts by gnofliwr
Old Feb 06, 2006, 09:16 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Two magnets gooped to two long chunks of wood that are then clamped to the edge of your workbench, magnets facing each other. Place a hand held balancer, bought at the LHS for two/three dollars between the magnets with a tad of clearance and you have a balancer much superior to the commercially available variety. It'll handle props up into the 20" range which the commercial type won't because of the weight. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Feb 07, 2006, 11:23 PM
Joined Mar 2005
Depending on the strength of your magnets....
Old Feb 08, 2006, 04:16 AM
It must have a machinegun
Scaledown's Avatar
Perth, Western Australia
Joined Sep 2004
To balance a small prop, I put a couple of rare earth magnets in the jaws of a vice and used a drill bit as a shaft. I just closed the jaws until there was minimal clearance. It would work better if I had a sharper point on the shaft.
Scaledown is offline Find More Posts by Scaledown
Old Feb 08, 2006, 04:41 AM
Dublin, Ireland
Joined Mar 2002
Cradle: 4 razor blades stuck into a block of balsa to make 2 vee shaped cradles.
This is an almost friction free mount for any gimbal you care to make....
I challenge anyone to show a magnetic cradle is better.
To make the gimbal which holds the prop use a piece of spare hardwood spar material - spruce or pine, pre drilled 1mm then jammed onto a drill bit, and turned down lathe-fashion with a file or sandpapered bar into 2 cones (with a hole through)
the hole will be automatically centred true once the turning - sanding process is done.
Finally push your wood cones on a bit of piano wire, (or any pin the right diameter), and rest across the cradle.
Done
Norman Greene is offline Find More Posts by Norman Greene
Top Flight Prop Balancer--good&bad cloudhopper Electric Plane Talk 0 Dec 25, 2002 01:08 PM
Best Prop Balancer? erashby Power Systems 3 Nov 25, 2002 11:22 PM
Prop balancer suggestion ??? ARE Electric Plane Talk 6 Nov 02, 2002 11:57 AM
WTB Prop Balancer Bill Dahmen Aircraft - Electric - Airplanes (FS/W) 0 May 27, 2002 01:42 PM
How Many Newbies Own A Prop Balancer? Bleriot Parkflyers 11 Feb 01, 2002 12:40 PM
