Old Jun 09, 2002, 11:15 PM
7up
,ɯǝ ʇoƃ ɐʎ ɟı ,ɯǝ ǝʞoɯs
7up's Avatar
USA, KY, West Liberty
Joined Jun 2001
Simulator with Wingo/Soarstar
Is there any simulators or add-ons to any simulators that emulate the Soarstar/Wingo?????
7up is offline Find More Posts by 7up
Old Jun 09, 2002, 11:45 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
There is a Wingo for FMS. Flies a bit slow, but is fun.
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Chemically Corrected
Grapeape's Avatar
San Diego, Ca
Joined Apr 2001
Go to http://n.ethz.ch/student/mmoeller/fms/index_e.html
and dl FMS it is free and pretty good. Then go to
http://www.aeromodelisme.org/simulat...s/?page=avions
and dl the Wingo model. The model page is in french, but you will see the pic of the Wingo and click on it to dl.
Grapeape is offline Find More Posts by Grapeape
Old Jun 10, 2002, 12:11 AM
Grapeape's Avatar
San Diego, Ca
Joined Apr 2001
The Wingo addon will not loop. Open the wingo.par file in the FMS/models directory with wordpad or whatever and change the beginning of the second line from 2.5 to at least 3.0. This is the speed setting and at 3.0 it will loop after a bit of a dive. You can make it ballistic if you want to but 3.0 looks to be about right for realism, although I have never flown a Wingo.
Old Jun 10, 2002, 10:52 AM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Thanks for the wingo.par tip. I found that 4.0 was a good value to emulate the speed and climb of a SoarStar.
What do I edit in the .par to put the Rudder onto my Tx's aileron stick? I do not want to do it in the Joystick mapping/cal setup area since that will change all my other models. Any help would be appreciated.
Old Jun 10, 2002, 07:28 PM
7up
7up's Avatar
Joined Jun 2001
Thanks for all the help, I have FMS but I didn't know that add-on planes were available......... TNX Again....
Old Jun 11, 2002, 06:25 AM
(aka Cliff Lawson)
Wright Flyer's Avatar
United Kingdom, Essex
Joined Oct 2001
The 5th line down in a .PAR file is the amount of deflection for the ailerons. If you set this to 0 and the two values above (line 3 = rudder and line 4 = elevator) are non 0 then you should find you have rudder-only control.
Cliff
Wright Flyer is offline Find More Posts by Wright Flyer
Old Jun 11, 2002, 03:58 PM
Dayton, OH
Joined Apr 2002
Cockpit Master Backyard Edition
Cockpit Master Backyard Edition has the Soarstar.
http://www.cockpitmaster.com/
If you buy the tx cable, you can hook many radios to it, though it only supports Win 98 or lower and uses the parallel port.
It runs about $50 all told, but I recommend it.
Both I and my daughter taught ourselves to fly (a Merlin) using the various models in CM BE.
I know a lot of people are dedicated to FMS since its free, but CM is a pretty good value compared to other computer games.
GB
Ghostbear is offline Find More Posts by Ghostbear
Old Jun 11, 2002, 04:23 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
I reviewed the table descriptions to the PAR file. It looks like I will NOT be able to move the Rudder stick over to my Aileron stick by hacking the model characteristic parameter file. Using the joystick interface utility is the only solution that I can see.
For PAR file details, please see: http://kimagure-hikoki.hoops.ne.jp/p..._par-file.html
Wingo/Soarstar with EPS Foam! MrBond Foamies (Kits) 4 Feb 11, 2003 10:37 AM
Wingo/Soarstar with Ailerons?...YES! Quacker Foamies (Kits) 17 Feb 08, 2003 09:18 PM
Wingo/SoarStar with Maxcell AAA cells = Thermal ! joemi Parkflyers 5 May 25, 2002 04:37 PM
wingo/soarstar flight speed cheapflyr Foamies (Kits) 1 Jun 13, 2001 10:57 PM
Wingo / Soarstar power pack JensJakob Electric Plane Talk 1 Jun 09, 2001 06:35 PM
