Old Aug 03, 2004, 09:44 PM
electron liberator
jaywatay's Avatar
United States, GA, Suwanee
Joined Mar 2003
Removing Oracover covering
Does anyone know of an easy way to remove Oracover covering from a sheeted balsa wing? I am amazed how well this stuff is adhered to the wing.
Moderator, please move if this is not the correct forum.
Jason
jaywatay is offline Find More Posts by jaywatay
Old Aug 04, 2004, 01:20 AM
Joined Dec 2003
The only way I have gotten cover off is to use heat again( heat gun) to soften the glue and work small areas. If it has a balsa adhesive painted on under the cover, I have not had much luck. Rob
robert harik is offline Find More Posts by robert harik
Old Aug 04, 2004, 06:38 AM
electron liberator
jaywatay's Avatar
Joined Mar 2003
Robert, thanks for the tip I'll try that.
Discussion Oracover covering 4444 Hot Online Deals 23 Oct 13, 2006 08:50 PM
Question Removing Monokite Covering HeavyMetal82 The Builders Workshop 5 Mar 22, 2006 09:08 PM
Removing iron covering Alfred Beginner Training Area (Aircraft-Electric) 2 Oct 28, 2003 02:22 PM
