Old Feb 07, 2015, 08:58 AM
Joined Nov 2013
Wiring/powering my deck lights
I'm a real "noob" when it comes to wiring/lighting and need some help. I've got a 6 volt search light, two 3-volt (each) navigation lights and a 3-volt mast light for a total of 15 volts. Not sure if I should connect them to my 12-volt power source or use a separate power source. If I can connect to my main 12 volt power, do I wire in series or parallel for brights lights?
chs51 is offline Find More Posts by chs51
Old Feb 07, 2015, 09:31 AM
Vince Hoffmann's Avatar
Hayward, CA
Joined Jan 2009
You will need to reduce the voltage from your main battery to the voltage of your lights, or use separate batteries that feed the correct voltage.
You can get a voltage regulator switch from Dimension Engineering:
https://www.dimensionengineering.com/products/de-swadj
Or you can try to find a linear voltage regulator. MACK used to make both 3 and 6 volt regulators but I cannot find them anymore.
Edit:
I found the MACK 3.3v regulator
http://www.mackproductsrc.com/L-26%20auto_control.htm
Vince Hoffmann is offline Find More Posts by Vince Hoffmann
Old Feb 07, 2015, 02:16 PM
Joined Nov 2013
Thanks a ton!
Old Feb 07, 2015, 03:32 PM
Blackpool, Lancs
Joined Feb 2006
Bright lights on a boat never look right, and can melt whatever they are housed in, assuming they last that long. The description of your lights sounds like they all need different current, so putting them in a series chain simply won't work. Just putting them in parallel on a 12 volt supply would kill them almost instantly. Depending on the current each needs, you might need several regulators.
mfr02 is offline Find More Posts by mfr02
Old Feb 07, 2015, 06:49 PM
Hayward, CA
Joined Jan 2009
Another option is to use LEDs with resistors matched to your battery voltage. There are several folks here who can help you get the right LED and resistor combo and you can run everything off your 12v main battery.
Old Feb 07, 2015, 06:53 PM
United States, NJ, Frenchtown
Joined Mar 2003
OR
Fixed I C regulators would be fine also. L M series comes to my old brain. The will run off the 12 volt battery just fine
cyclops2 is offline Find More Posts by cyclops2
Old Feb 07, 2015, 07:44 PM
Senior Moment Member
babblefish's Avatar
SF Bay Area, CA
Joined Jul 2002
I'll give another option here; use a BEC such as this one:
Available from Tower Hobbies: http://www3.towerhobbies.com/cgi-bin...?&I=LXWNS2&P=7
1) Set the BEC for 6 volts
2) Connect the BEC to your 12v power source (through a switch, if you prefer)
3) Wire your three, 3v bulbs in series which will make them behave like one 9v bulb
4) Connect your 6v search light and the three series-wired 3v bulbs in parallel to the BEC
Now your search light will get 6v (I'm assuming you'd want full brightness for that) and your navigation and mast lights will get 6v (out of the required 9v) which will cause them to glow a bit dimmer for a more realistic effect.
babblefish is online now Find More Posts by babblefish
Old Feb 08, 2015, 09:42 AM
Joined Mar 2003
You are assuming same current & type of bulbs. Might not be the same ? h
He could look to make them all 12 vdc ?
Old Feb 08, 2015, 01:56 PM
Blackpool, Lancs
Joined Feb 2006
Effectively, using a 12 to 6 volt regulator, and wiring the bulbs to fit in with 6 volts as described in #7 does exactly that. Because they are arranged into 2 groups running on the same voltage, the only ones where current becomes critical is the chain of 3 volt nav/mast lights, which probably are all the same current and can be wired in series.
Old Feb 09, 2015, 09:05 AM
Australia, WA, Perth
Joined Mar 2011
Similar to the voltage regulators already mentioned but much cheaper.
http://www.ebay.com.au/itm/190886445...84.m1497.l2649
You could use 3
1 for nav lights in parallel
1 for mast lights
1 for search light
You can then adjust each group for the brightness you require bearing in mind you don't overdrive them (too higher voltage).
I don't know the size of the boat but these are very small units.
Once you set the voltage spray them with some moisture proofing spray as should any electronic equipment in a marine environment. In a waterproof plastic box would also be good.
EDIT
One problem I did think of after I logged off last night was that to use these boards you need to be able to or have some one solder the wires to the PCB. needs a fine point soldering iron.
tugboat2011 is online now Find More Posts by tugboat2011
For Sale Upper Deck Power Deck Hockey CD Roms Year 2000 Mikemynameis Non R/C Items (FS/W) 0 Dec 07, 2013 02:12 PM
For Sale Upper Deck Power Deck Hockey CD Roms Year 2000 $75 Mikemynameis Non R/C Items (FS/W) 0 Nov 15, 2013 03:21 PM
For Sale Upper Deck Power Deck Hockey CD Roms Year 2000 Mikemynameis Non R/C Items (FS/W) 0 Nov 09, 2013 02:30 PM
Question Bow light wiring affect how to finish deck? orangepeal Scale Boats 17 Sep 18, 2013 07:26 AM
Question Is this Diagram for wiring my LED lights correct flywmoi Multirotor Electronics 5 May 23, 2013 06:03 PM
