Old Aug 22, 2014, 12:00 AM
Smasher of foam
FunkeyMonk's Avatar
United States, OH, Stow
Joined Sep 2012
How does an ESC make my motor beep?
I've been spending my week swapping motors and ESCs around, and for the first time after two years of flying, I just discovered that ESCs don't beep, the motors beep!
And I just read the instruction sheet that came with a turnigy plush ESC and it even writes out the melodies in numbered solfege!
So, anyway, how are the ESCs making the motors sing? Do they work somehow like regular speakers? (e.g., a magnet vibrates a membrane) If they do, then maybe there's a possibility to make motor/speakers.... For some reason.
FunkeyMonk is offline Find More Posts by FunkeyMonk
Old Aug 22, 2014, 12:02 AM
Smasher of foam
FunkeyMonk's Avatar
Joined Sep 2012
(If you don't know what "numbered solfege" is, it just means replacing the old "do, re, mi, fa, sol, la, ti" with "1234567.")
Old Aug 22, 2014, 12:46 AM
homo ludens modellisticus
Ron van Sommeren's Avatar
The Netherlands, GE, Nijmegen
Joined Feb 2001
Motor acts as a poor loudspeaker. Current in a magnetic field creates a force, something moves/oscillates (wire/coils?, drum?, stator?)
Vriendelijke groeten Ron
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Aug 22, 2014, 01:30 AM
Australia, VIC, Melbourne
Joined Feb 2010
if you rapidly switch power from one phase of the motor to another the rotor of the motor will vibrate, the frequency of switching controls the pitch produced.
Not very efficient or high quality sound production, but it does work.
desertstalker is offline Find More Posts by desertstalker
Old Aug 22, 2014, 01:24 PM
United States, WA, Woodinville
Joined May 2014
Ampère’s law dictates that any time you have a coil of wire in proximity to a magnet, you can apply a voltage and it will move, or move it and it will develop a voltage. If you connect one phase of a motor up to a regular audio amplifier it will behave as a (rather poor) speaker that can play music. Note that if you actually try this, you'll want to use an amp you don't particularly care about since the impedance will probably not be all that close to the 8 Ohms most amps expect.
James_S is offline Find More Posts by James_S
Old Aug 22, 2014, 06:32 PM
Condescending Pedant
Joined Aug 2013
Ampere's Law? I am thinking Faraday's Law but all those early electricians were geniuses and we owe them a great big THANK YOU
Okay, I just did a little research and both Ampere and Faraday have laws about magnetic fields and conductors and their interactions so it is likely a combination of both. The part I don't understand is how all those electrons have time to study all those laws, and still keep the lights on.
Mike Dubovsky is online now Find More Posts by Mike Dubovsky
Old Aug 22, 2014, 08:17 PM
Joined May 2014
No you're absolutely right, I got the two crossed in my head. It is indeed Faraday's law, though both cover the relation between electricity and magnetism.
Old Aug 22, 2014, 10:17 PM
You can call me Pat
United States, FL, Tampa
Joined Dec 2013
what an excellent question posed here...
i often wondered this myself. for some reason I thought the motor had some kind of device built in that made the noise.
pdooley is offline Find More Posts by pdooley
Old Aug 23, 2014, 04:55 AM
Joined Jul 2014
Whys it vibrate because of electricity? Is it to the same frequency as the controller switches? And what about if the controller just sends elec to one phase what happens?
On another note, I dropped my exposed motor stator on its head on the concrete! It was in its swaddling and someone wanted to see and this and that and I'm feeling maybe it was me and I was negligent. What are my chances of it having irreparable damage and when will I find out?! Maybe after it's all said and done I'll never know if it's head fall caused damage and I'll just think that's my motor. I want the best for my motor though. I want it to have a long life and be the best motor it can be. What's a responsible motor owner supposed to do?
Hummina is offline Find More Posts by Hummina
Old Aug 23, 2014, 05:02 AM
Joined Feb 2010
A bare stator? Only damage to worry about is physical, if it looks OK it will run OK too.
Old Aug 23, 2014, 09:48 AM
Joined Feb 2001
Originally Posted by pdooley View Post
... i often wondered this myself. for some reason I thought the motor had some kind of device built in that made the noise.
Nothing to hide
More drawings and pictures
www.aerodesign.de/peter/2001/LRK350/index_eng.html
Old Aug 23, 2014, 06:46 PM
Wake up, feel pulse, be happy!
C₄H₁₀'s Avatar
United States, AK, Fairbanks
Joined Aug 2009
A brushless motor and an audio speaker share a whole bunch of DNA. Many moons ago, I was able to get a parkflyer motor to play actual music by connecting two of its leads to the headphone output of my iPod. It was extremely faint, but songs were recognizable. I'm sure a more powerful speaker output would increase the volume to listen-able levels.
Brushless motors by themselves aren't great at making noise, but our big, light foam and wood airframes work great for amplifying sound. Personally, I'm still waiting for an ESC that allows users to assign their own sound clips for various functions
C₄H₁₀ is offline Find More Posts by C₄H₁₀
Old Aug 23, 2014, 08:55 PM
Joined May 2014
Crank one of those miniature music box mechanisms in free air and you can barely hear it. Screw it to a block of wood and you can listen to it across the room. If you attach a brushless, or brushed for that matter motor to a suitable resonator and connect it to an audio amplifier, you can get reasonably decent sounding music out of it. A speaker is nothing more than a coil of wire mounted to a movable cone in proximity to a magnet. You can build a perfectly reasonable sounding speaker from scratch quite easily.
Anyway back to the speed controllers that play tones, they just switch the transistors driving two of the windings at the frequency of the tones you hear. The motor vibrates at that frequency and you hear the sound.
Old Aug 23, 2014, 09:20 PM
supreme being of leisure
ZAGNUT's Avatar
Tel Aviv, Israel
Joined Jul 2004
Floppy Music | Eurythmics - Sweet Dreams (12 Drives) (3 min 11 sec)
the stepper motors used on smaller CNC machines are also getting in on the act.
ZAGNUT is offline Find More Posts by ZAGNUT
Old Aug 27, 2014, 03:00 PM
Jack
jackerbes's Avatar
USA, ME, Ellsworth
Joined May 2008
There is a little guy in the with a horn . They wake him up and give him electric shocks.
Actually it has to do with rapidly changing or pulsating the current and/or polarities on the windings. It is sort of amazing. though, it turns the motor into a speaker of sorts. What you hear can vary in pitch and volume from motor to motor and with the voltage your using.
Jack
jackerbes is offline Find More Posts by jackerbes
Question How do ESCs make the motor beep? marhar Power Systems 13 Nov 12, 2014 07:19 AM
Discussion How does the ESC make the motor BEEP? rcmaverick Electric Plane Talk 30 Oct 09, 2013 02:35 AM
Discussion motor or esc cutting out on my V-Tail, makes high low beeps. resago Scratchbuilt Multirotors 2 Jul 29, 2013 02:37 PM
Discussion my trxxas rustler does not revese only sometimes and makes a loud beeping sound xl.5 Electric Power Cars 2 Oct 11, 2011 07:01 AM
How to make a motor beep? jswayze DIY Electronics 16 Nov 08, 2004 06:01 AM
