Old May 14, 2014, 02:47 PM
United States, NC, Old Fort
Joined Dec 2013
FS T6 with hk450
Just finished my first build the hk450 ccpm,it went smoothly thanks to mikeys build on You tube. Parts used were the 2218 motor w/12 pinon,tg9e servos,turnigy 40 amp esc w/ card, hk401b, and the turnigy 2200 mah. I have used the fs t6 flysky that l use on my v911. have several other birds the first a s107 the wife got for me a cb 180d and a 180z also a mjx f645. I enjoy the v911 the most mainly due to flyn indoors.l have ordered copterx metal head/tail upgrades along with digital sevros. The issue l have is that l am not sure l have the tx setup right cannt find info on the settings for this this bird so if anyone is using this setup l would be very thankful if they could post all their settings.
johnnytyler is offline Find More Posts by johnnytyler
Old May 15, 2014, 09:20 AM
United States, NY
Joined Dec 2013
In the helicopter type select 135 degree swash type. Then reverse servos as needed to make the swash move correctly.
Mad Russian is offline Find More Posts by Mad Russian
Old May 15, 2014, 03:04 PM
Joined Dec 2013
Thanks Mad, the swash is set on 120 everything appears to respond correctly to stick inputs. the area in question is the mix.I have the setup as listed below.
mix #1
mix is off
master ch 2
slave ch 2
pos. mix 100%
neg. mix 100%
offset 0%
mix #2
mix is off
master ch4
slave ch4
pos. mix 100%
neg. mix 100%
offset 0%
mix #3
mix is off
master ch1
slave ch1
pos mix 100%
neg mix 100%
offset 0%
the gyro appears to be working correctly and all pitch curves are set.
Old May 16, 2014, 11:38 AM
AMA# 548800
jombo's Avatar
United States, CT, Trumbull
Joined Dec 2007
Your correct , 120 for swash .
As for setting it up go to heli freaks and sign up there . Then after you sign up check out finless bob set ups for the align 450 or heli 101 . That should explain a lot .
Good luck
jombo is offline Find More Posts by jombo
Old May 16, 2014, 08:34 PM
Joined Dec 2013
Thanks Jombo all the info l need is there.
Help! Need Help with KK2 Self Level Aux Switch With Flysky FS-T6 ecpilot Multirotor Electronics 6 May 31, 2014 10:28 PM
Discussion RC Helicopter with FlySky FS-T6 hgedikli Electric Heli Talk 1 Dec 29, 2013 03:49 AM
Discussion 15% OFF FlySky FS-T6 2.4ghz Digital 6CH Transmitter and Receiver Ends 11/16/13 hobbypartz Hot Online Deals 0 Nov 14, 2013 06:07 PM
Discussion FlySky FS-T6 reciver compatibility new user Radios 0 Oct 27, 2013 02:07 PM
