Old Oct 08, 2012, 07:38 PM
Dude, I do fly all day long!
rcalldaylong's Avatar
San Jose, California
Joined Dec 2007
nimh charging
I bought some eneloops and they are AA 1900mah
I am using the accucell-6 to charge them and I'm charging 2 of them in a series
After using them, they are both about 1.1v each before charging. I charge up and only managed to put back about 900mah.
I'm charging them in nimh mode with a rate of .1amp (lowest rate on charger)
Since I had 2 batteries in there, I would expect at least 1500-1800mah being put back or half of each of the battery.
Question is why so little? is it because 1.1v is only about 30% drained or so?
These are new Eneloops,...used about 5 cycles now.
rcalldaylong is offline Find More Posts by rcalldaylong
Old Oct 09, 2012, 04:22 AM
Staffs, UK
Joined Nov 2003
Since you have them in series the measured current is flowing through both so 900mAh means that 900mAh has gone into EACH battery.
Oh and resting voltage is a very poor indicator of how much charge is remaining in NiMH batteries. All you know is that at 1.1V there's less than there was at 1.3V .
Steve
slipstick is online now Find More Posts by slipstick
Old Oct 09, 2012, 04:26 AM
Australia, VIC, Melbourne
Joined Feb 2010
Steve
And 0V is flat
If you want to check capacity run them down slowly, put any significant load on a NiMH cell and you wont get close to the rated capacity (pretty sure thats a 1/20C discharge rating).
desertstalker is offline Find More Posts by desertstalker
Old Oct 09, 2012, 05:59 AM
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
One of my many Sanyo Eneloop test which I have posted here on RC Groups
http://www.rcgroups.com/forums/showp...&postcount=142
Discharged at 0.25 mA (1/4 A) for 7 hours , 1,750 mAh delivered down to 9.0V or 1.125 V per cell average as this was a 8 cell Transmittery battery.
Charged at 2A (1C) and discharged at 1A down to 7.2V (0.9V avg.per cell)
http://www.rcgroups.com/forums/showp...&postcount=141
1853 mAh delivered.
As I have posted numerious times many get less than stellar performance from Ni cells due to the simple fact they do not care from them properly , much the same case as with LiPolys.
Charles
Question Nimh charging BrightCap232 Batteries and Chargers 12 Aug 02, 2012 12:07 AM
Discussion Charge interupt resume Nicads Nimh kewhite Batteries and Chargers 2 Jul 14, 2012 11:57 PM
Discussion NiMH AA's won't charge signal15 Batteries and Chargers 7 Jul 13, 2012 06:07 PM
Discussion Using a IMAX B6 lipro balanced charger to charge a nimh pack Tripsta Electric Power Cars 11 Jul 11, 2012 06:28 AM
Discussion Charging eneloop NiMH cells learn2turn Batteries and Chargers 16 Jul 03, 2012 01:05 PM
