Old Oct 08, 2012, 12:12 AM
Joined May 2012
Hangar 9 40 cub ARF with saito???
OK guys and gals I have been searching for two weeks now and cant pull the trigger on the right engine. My last plane a hangar 9 hellcat I put a magnum .91 in it and it runs great but had a few little issues with the Magnum out of the box. So I decided on a Saito this time. I have seen anything from a .52 to a .72 size in the 4 stroke. I was set on a .56 but a guy at my field has the same plane with a .70 4 stroke ASP. I'm really lost. The .56 should be fine but would really like some more input. Thanks
Fatam is offline Find More Posts by Fatam
Old Oct 11, 2012, 10:50 AM
United States, SD
Joined Aug 2010
Well I have the same plane, I bought it used and it came with a Magnum 91 in the nose. I wouldn't reccomend it unless you want to do cub 3D. How big an engine really depends on the kind of flier that you are, if all you plan to do with it is float around then the 56 would be plenty. If I had to chose I would go with the 70, just because I like the occasional loop and I like to have lots of power when I do stuff like that.
Kyler1 is offline Find More Posts by Kyler1
Old Oct 11, 2012, 05:13 PM
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
I built the great planes 40 size cub in clipped wing form and a .70 4 stroke was perfect. Flew it 1/2 to 3/4 most of the time esepcially if your pulling scale aerobatics
Thermalin is offline Find More Posts by Thermalin
Discussion Hangar 9 .40 ARF Mustang w/inverted Saito 82. Anyone with experience? caveryis Fuel Warbirds 1 Oct 05, 2010 10:35 AM
Help! Hangar 9 J3 Cub 40 and Saito DjBac Scale Fuel Planes 33 Aug 25, 2010 08:14 AM
Sold Hangar 9 Piper J-3 Cub 40 ARF with floats, servos and Evolution 46 RTF Steve H. Aircraft - Fuel - Airplanes (FS/W) 1 Apr 04, 2008 05:37 AM
Discussion Hangar 9 J3 Cub .40 ARF DrtJnky Fuel Plane Talk 6 Apr 03, 2006 09:06 PM
F/S NEW Hanger 9 J-3 CUB .40 ARF with New Saito FA-56 Golden Knight Slavetonone Aircraft - Fuel - Airplanes (FS/W) 1 Nov 04, 2003 10:26 PM
