Old Feb 26, 2012, 08:35 PM
Pyrofan's Avatar
United States, GA, Perry
Joined Jul 2011
Parkzone T28 upgrade. Need HELP!
Ok so i want to get a unlimited vertical on my parkzone(pz) T28. what is the best setup on a budget and least amount of modifications required ? I run a 3s 2200mah 20c battery. All help is appreciated.
Pyrofan is offline Find More Posts by Pyrofan
Old Feb 26, 2012, 10:09 PM
Snappy Title On Backorder....
tsymonds's Avatar
United States, TX, Killeen
Joined Jun 2011
Eflite Power 25 1250kv motor, 10x10 prop and a 60amp esc. Gonna want to tape the underside of the wing and stab to beef it up.
tsymonds is offline Find More Posts by tsymonds
Old Feb 27, 2012, 07:03 AM
Pyrofan's Avatar
Joined Jul 2011
I want a cheap set up. $60 for the motor is to much.
Old Feb 27, 2012, 07:23 AM
Low'n Slow is safest, right?
KaiWE's Avatar
Norge, Østfold, Fredrikstad
Joined Jun 2011
The Turnigy G25 is only 25$ at hobbyking, and have quite similar performance data. no 1250kv available though, but I would have gone for lower kv and a bigger prop...
KaiWE is offline Find More Posts by KaiWE
Old Feb 27, 2012, 07:30 AM
Pyrofan's Avatar
Joined Jul 2011
Do you know of a similar motor in the US. I dont like waiting a month
Old Feb 27, 2012, 08:22 AM
United States, OH, Tipp City
Joined Oct 2011
There's a Power Up 25 (actually 2) at Heads Up RC in Florida: http://www.headsuprc.com/servlet/the...5-Speed/Detail
I suppose now you are going to say you don't like Florida...
aero550 is offline Find More Posts by aero550
Old Feb 27, 2012, 04:21 PM
Pyrofan's Avatar
Joined Jul 2011
Thanks! Thats a pretty good price. Do you have it in your T28?
Old Feb 27, 2012, 04:31 PM
Joined Apr 2008
Strengthening the wing .... don't ask me why!
chopper62 is offline Find More Posts by chopper62
Old Feb 27, 2012, 04:57 PM
whiirrrrrr
srt8madness's Avatar
United States, TX, Houston
Joined Nov 2011
the 25 series or equivalent will draw too much amperage for a 2200 20c battery. The batteries the op listed are only good for 44amps. I would suggest the power 10 or equivalent. Check out heads up rc, they are in flordia, $2 shipping. You can go with the power up 480 plus, or one of their emax motors.
But basically, you have to pay to play. You want the power, you have to pay for it.
srt8madness is offline Find More Posts by srt8madness
Old Feb 27, 2012, 05:27 PM
Pyrofan's Avatar
Joined Jul 2011
What size prop with the 480+ motor? Is it in your T28?
Old Feb 27, 2012, 06:06 PM
tsymonds's Avatar
Joined Jun 2011
A 480 will not give you unlimited vertical. It already comes with a 960kv 480 stock so adding a few KV makes little difference. I've flown it stock, with a Park 480, Power 10, Power 15 and 1250kv Power 25. The 15 is a good match with a 9x9 and the 25 with 10x10 is an over the top setup. Tickled the radar gun at 87 and heads upstairs with a quickness. Carbon tape tip to tip on the stab and a couple strips of packing tape on the wing or it'll be a one pull show.
Old Feb 27, 2012, 06:55 PM
Marietta GA.
Joined Jan 2011
Turnigy 3536-1100..they sell the mount on Ebay..it moves along pretty good, but will cut into your flight times.
mazjag is offline Find More Posts by mazjag
Old Feb 27, 2012, 07:08 PM
whiirrrrrr
Joined Nov 2011
a parkzone 480 is different from the eflite 480, which is different(and less powerful) than the power up 480. The power up 480 is just under the eflight power 15, at half the price. Again, he is going for cheap, and wants a setup that his batteries will handle, which is 44 amp constant.
Old Feb 27, 2012, 07:25 PM
Pyrofan's Avatar
Joined Jul 2011
are there any on http://www.hobbypartz.com/ that would work?
Old Feb 27, 2012, 10:54 PM
Joined Oct 2011
No actually. I was kind of surprised that a 25 was recommended so early. I have a G10 from HK on it's way across the ocean for mine. I would think a 25 would be too much, if that's possible, especially considering all the other upgrading you'd have to do to accomodate it - ESC, Batt, and structural. The 10 is plug and play from what I understand, with the slight possibility of maybe needing a bigger ESC, depending on what prop you want to use.
You asked about hobbypartz...take a look at their Tacon Big Foot line of motors. They run along the same lines as the E-flites, Turnigy's, and Power Up's as far as having the 10, 25, 46, 60 size motors. Only problem with Hobbypartz is that they always seem to be out of stock.
Also, Stevens Aeromodel carries a line of motors up through the 25 size that look suspiciously like rebadged Turnigy's. Not that that is a bad thing, I have a couple of Turnigy's that perform very well. http://www.stevensaero.com/SA-Sport-p-1-c-317.html
Discussion Parkzone t28 vs. Airfield 1400mm t28 LIZZAY Electric Warbirds 11 Jan 01, 2012 10:55 PM
Wanted need t28 parkzone airframe or parts. DumthumbsFRANKIE Aircraft - Electric - Airplanes (FS/W) 5 Oct 28, 2011 10:26 PM
Sold Parkzone Corsair / T28 Brushless Upgrade mjbennett9 Aircraft - Electric - Power Systems (FS/W) 3 Apr 01, 2011 08:34 AM
Wanted Need Used Parkzone T28 wing brianfp_400 Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2008 11:44 AM
Discussion ParkZone T28 Motor & ESC Upgrade brianfp_400 Parkflyers 12 May 09, 2008 04:14 PM
