Old Jan 30, 2012, 07:21 AM
Joined Aug 2008
Cellpro 10S dead
Hi.
I have the Cellpro 10S charger in use for many months now.. Not sure how but smoke came from the unit, dead now.
As I am along way from the repair center and the cost of shipping is too high, I took the cover off to find the 2 IC's had popped.
One IC, in side the Coil, which I can get locally. The 2nd is to the right of the display. Board Ident is U2. I can not make out the chip number or manufacturer. It ends in 00N ??
Does anyone have infomation on this IC. I have emailed tech support but no reply... :-(
Richard
Melange2008 is offline Find More Posts by Melange2008
Old Jan 30, 2012, 09:48 AM
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Originally Posted by Melange2008 View Post
Hi.
Richard
Hi,
I have not received any emails from you. The chips are as follows:
U10 - TC1427COA713
U2 - TLC272IDR
Q28 and Q29 could be damaged as well.
Also check D10 to see if blown.
Howard Matos is offline Find More Posts by Howard Matos
Old Jan 31, 2012, 03:32 AM
Joined Aug 2008
Hi Howard
Thank you for the info... I have found them locally.. will have a go
Richard.
Old Feb 03, 2012, 09:38 PM
Joined Aug 2008
Hi Howard
I have replaced U10 / U2 / Q28 and Q29.
The charger now powers up ok.. but when I set to charge I get input voltage less then 10 Volts error.
Hope you can help again.
Richard
Old Feb 08, 2012, 01:39 PM
AR-15 BRD!
Frederick, MD
Joined May 2002
Hi Howard
Richard
Hi,
Try centering the toroid, there is a diode that is located under this component and if they are shorted might cause this problem. Also, the diode may be bad which can also cause this. Look down the center of the toroid and you should be able to see the diode. I know we have made a layout change and newer chargers don't have the diode under the toroid.
Old Feb 09, 2012, 06:43 AM
Joined Aug 2008
I think I have the New version.. 1_5 as I can not see the diode.
I have just bought three more for work, but would be good to get this working.
Anymore thoughts please.
Richard
For Sale NEW FMA Cellpro 10s and new 10s battery Markw177 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 26, 2012 06:44 PM
Off Site Cellpro 10S & Accessories - ebay Three-Wire Aircraft - Electric - Batteries & Chargers (FS/W) 3 Apr 05, 2011 10:46 PM
Wanted Wanted - nice used cellpro 10s snyder_man Aircraft - Electric - Batteries & Chargers (FS/W) 1 Apr 05, 2011 04:20 PM
Wanted Cellpro 4s or 10s CP-GP/KO Balance Board jmpdgs Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 19, 2011 07:45 PM
Sold cellpro 10s lipo charger c2nv Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 13, 2011 10:39 PM
