Old Jul 25, 2015, 03:30 AM
Darthwonga is offline
Find More Posts by Darthwonga
May the Farce be with you
United Kingdom, Scotland, Dundee
Joined May 2006
My Sundowner has these specs:
Scorpion HK3-4025 550kV
6S 6000mAh Turnigy nanotech
11 x 14 APC
~2.5kW
Weight 3.62kg
The peak speed I measured with my eagletree gps was 150mph. Landings are uncomfortably fast with no aids, managed to rip out the UC a couple of times when I got it wrong. I tried the drooped aileron approach, which helped a little but reduced roll response. In the end I modified the wing to have split flaps along the whole trailing edge inboard of the ailerons. Has made a huge difference, landing no longer feels like a Formula 1 pitstop! You have to remember to land with power on, like a warbird, it'll fall out the sky if you just kill the throttle on finals. I've got photos of the conversion lying around somewhere if anyone wants me to post them.
Darthwonga is offline Find More Posts by Darthwonga
Old Aug 02, 2015, 08:57 PM
ohnow is offline
Find More Posts by ohnow
United States, GA, Conyers
Joined Sep 2011
11 x 14 APC
~2.5kW
Weight 3.62kg
I know what you mean. The SD36 was hard to slow down on our paved runway and like others mentioned it will stall on the final turn. When I finally added flaperons with an elevator mix I couldn't believe how much it slowed down. I copied the settings to the larger SD50 and I hope they work.
I'd love to see some pics if it's easy for you. I think your idea is really interesting. I'm thinking of changed from Dean connectors for higher amperage but not sure if they are needed. Can you tell me the style of connector you use and your average amp draw if you know it?
Thanks for responding!
ohnow is offline Find More Posts by ohnow
Old Aug 02, 2015, 09:30 PM
ohnow is offline
Joined Sep 2011
Update from my maiden failure last Sunday. I could not control the rudder enough to compensate the pull to the left. I tried different expo settings and several taxi tests but before I could do it well enough the tail raised so I had no ground steering but the small rudder had not bit yet so it pulled left off the runway and didn't clear the last fence post. So, I have a damaged leading edge. Could have been a lot worse of a maiden flight!
Going to try a gyro for the rudder next time.
Old Aug 02, 2015, 09:37 PM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
Where were you flying?
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Latest blog entry: Giant 66% Cub
Old Aug 02, 2015, 10:45 PM
brushless55 is offline
Find More Posts by brushless55
big ignore list
brushless55's Avatar
United States, CO, Longmont
Joined Nov 2011
just wondering who has the fastest speeds with the SD50 ?
brushless55 is offline Find More Posts by brushless55
Old Yesterday, 05:44 AM
Joined May 2006
Now that you mention the rudder, I remembered that I increased the size of that too - added around half an inch onto it's width. The swing on take off is pretty bad, need to make sure you increase the throttle gradually, don't just throw it open, and use a little up elevator at the start of the roll to keep the tail wheel on the ground until it has enough speed for the rudder to work.
Here's some pictures of my wing mods. The flaps are laser cut from 1/16th ply with plenty of bracing. They can deploy to about 75-80 degrees down, but I've not had the balls to try that in flight - generally I use about 50 degrees. Needs down elevator mixed in, but it makes a huge difference to the landing approach. First time I tried them, I chopped the throttle about 5 feet off the ground, as I normally would landing the Sundowner with out flaps, and it just stopped and fell out the sky (cue another re-gluing of the undercarriage!). I have a load of photos of the modification process if you want to see them, and I can laser cut a set of parts if you're interested - send me a PM if you are.
I've also fitted a BrainCube lighting system (disclosure - I run the business, this model is a company demonstrator), really helps you see where those skinny wings are on approach. I also added black trim to the top of the wing tips for the same reason - the white just disappears against cloud.
Here's a vid taken from a camera on-board the Sundowner, pre-flaps:
Sundowner 50 - First Video
Had to rein it in a bit, there was another guy flying at the time, but there are a couple of speed runs in there.
Cheers,
Olly
Discussion Power system for Hangar 9 Sundowner 50 RB51 fan Power Systems 3 Apr 11, 2011 01:03 PM
Discussion hanger 9 sundowner 50 planefixer Fuel Plane Talk 57 Oct 26, 2010 07:59 AM
Cool Hanger 9 Sundowner 50 size cryhavoc38 Sport Planes 10 Feb 17, 2008 10:27 PM
Question Hangar 9 Sundowner 50? GJVO Fuel Plane Talk 0 Aug 23, 2007 02:38 PM
EDF 40/50 Brushless setups/results kd4gfy Electric Ducted Fan Jet Talk 0 Feb 20, 2005 03:11 PM
