Old Nov 01, 2006, 08:41 PM
PLMS is offline
Find More Posts by PLMS
Martin - AKA mr.sneezy
PLMS's Avatar
Joined May 2004
Question
PCM 1024 decoder chip out there yet ?
Hi Guys,
Been quite some time since I posted on this forum.
I've been reading the info on other sites about the decoding effort done on the Futaba PCM1024 format. It seems to be more or less complete.
Has anyone done or begun a DIY PIC project (or with other micro) based on this info to make a hybrid PCM receiver out of a cheap common variety receiver (eg GWS etc) and a PIC ?
If so I would be a happy to help with the hardware build and test side of it. I have a bunch of cheapy PPM receivers that could be hacked to add a decoder on the output of the data slicer circuit.
Martin
PLMS is offline Find More Posts by PLMS
Old Nov 02, 2006, 03:27 AM
Ema is offline
Ema
Find More Posts by Ema
Ema
Joined Nov 2004
Two italian guys (Alessio and Andrea) made a Joystick interface that is able to decode the Futaba PCM 1024 signal.
At this link you can find all documentation (also with sources) about the project:
http://alessioandrea.altervista.org/rcjoyng2.html
Hope this help
Bye
Emanuele
Ema is offline Find More Posts by Ema
Old Nov 02, 2006, 09:02 AM
FredericG is offline
Find More Posts by FredericG
FredericG's Avatar
Belgium, Aalst
Joined Dec 2002
A few years ago I assisted in reverse engineering the PCM protocol. References can be found on my website (http://www.rc-flight.be/electronics.html)
I did it because I had lots of plans, making a PCM receiver form analog ones was one of them. However, I simply do not have the time to do it alone
If you start a project, I would be happy to assist
Frederic
FredericG is offline Find More Posts by FredericG
Old Nov 02, 2006, 04:56 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
Frederic
Hi Frederic, I can do some PIC programming myself but I'm not good enough to write code to interpret the PCM frame. I have been using PicBasicPro for all my PIC projects to date. I think if someone wrote an assembly routine to decode the frame and store the channel variables in RAM registers, I could do the rest in basic (PBP is very good and not slow if done well).
The first step in my mind is to pick a suitable micro. My first thought is the PIC16F628
http://ww1.microchip.com/downloads/e...Doc/40044E.pdf
It's 18 pin so we should be able to get 8 or 10 channels out. It can be run at up to 20Mhz. It's cheap and readily available from most electronic hobbiest suppliers. It also has analogue comparators so could monitor the battery voltage as well and sound an alarm for low battery.
Old Nov 03, 2006, 01:28 AM
JimDrew is online now
Find More Posts by JimDrew
Xtreme Power Systems
Lake Havasu, AZ
Joined Jun 2005
A little word of caution... if you expect a good servo output pulse, DON'T use any micro's built-in oscillator. Use an external crystal. I fought this with our XtremeLink and just gave in and used a 16Mhz external oscillator. This gives us +/-10ns stability on the servo pulse.
JimDrew is online now Find More Posts by JimDrew
Old Nov 03, 2006, 06:14 AM
FredericG's Avatar
Belgium, Aalst
Joined Dec 2002
Spectrum
I do not want to be a killjoy, but lately I am starting to wonder if investing in PCM is still that interesting. There have been many discussions about PCM vs PPM. There are people who believe in PCM, there are people who feel that PCM is worse than PPM. I do not want to open this discussion agian. I have always liked PCM, but now I am wondering if the spectrum technology is perhaps the way to go. I honestly donít know, I know very little about this yet.
There is a very hard real-time requirement of reading the input signal and, more important, generating the signals for the servoís. Several people have started threads about this before, and I believe it us more difficult that one might think. I would think that writing this in assembly could be advisable, while the PCM decoding would be written in a more high level language, especially for a proof-of-concept.
Frederic
Old Aug 22, 2008, 11:16 PM
j_sadi is offline
Find More Posts by j_sadi
Joined Aug 2008
pcm 1024 encoding with AVR ATmega16
Originally Posted by PLMS
Hi Guys,
Martin
hello martin
i write a program for atmega 16 (AVR Micro) that read pcm1024 from trainer cord of 9cap(a R/C model of futaba) and send amount of servos to rs232 serial port.
that amount is between 0 to 1023 .
if you want schematic and c program of this please email me
j_sadi63@yahoo.com
j_sadi is offline Find More Posts by j_sadi
Old Aug 25, 2008, 05:56 PM
PLMS is offline
PLMS's Avatar
Joined May 2004
Originally Posted by j_sadi
hello martin
j_sadi63@yahoo.com
Yes, I'll email you.
Martin
Discussion electrifly EDF any out there yet? spudandretti Electric Ducted Fan Jet Talk 12 Jul 15, 2006 07:42 PM
Brits - How many Ezone'ing English Gentlemen and Ladies are there out there dave_lilley Electric Plane Talk 119 Jan 23, 2005 11:30 AM
any promising NiMH out there for 100+ amps yet? tic Batteries and Chargers 18 Jan 04, 2003 05:21 PM
Any folks out there flying the Sig Rascal? atsiang Electric Plane Talk 9 Apr 27, 2001 12:51 AM
