Old May 28, 2002, 03:06 PM
cfossa is offline
Find More Posts by cfossa
cfossa's Avatar
Stow, MA
Joined Mar 2002
Modifying GWS Landing Gear
Hi Guys,
I ordered some 2" light weight foam wheels from Balsa Products for my GWS Zero to replace the stock spindle wheels. My new wheels arrived today. They are incredibly light, but they are too wide for the "axle" part of the stock landing gear. I considered "re-bending" the existing gear to make the axle portion longer. But, there is not a lot of prop clearance now and that may cut it too close. So it looks like I'll pick up some piano wire at the LHS and make another set of landing gear to go with my foam wheels.
I've seen a bunch of nice Zero pics here with lightweight foam wheels. Any hints or tips about what worked or didn't work modifying your Zero landing gear?
Carl
cfossa is offline Find More Posts by cfossa
Old May 28, 2002, 03:22 PM
sgil2001 is offline
Find More Posts by sgil2001
R/C Enthusiast
sgil2001's Avatar
Craley, Pennsylvania, United States
Joined May 2001
I used a small piece of aluminum tubing. It was just slightly larger than the wire landing gear, so it slid right on. I used a little probond glue to hold it to the landing gear. My wheels slid onto the tubing perfectly.
sgil2001 is offline Find More Posts by sgil2001
Old May 28, 2002, 04:58 PM
cfossa is offline
cfossa's Avatar
Stow, MA
Joined Mar 2002
Great idea! Did you buy the tubing at a hardware store or hobby shop? Also, what type of fasteners did you use as "wheel collars?"
That's what I love about ezone ... lots of great ideas!
Carl
Old May 28, 2002, 05:11 PM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Hi Carl, I've been using alum tubing with my HL Lyt wheels too. For wheel collars try an appropriate size of wire insulation or heat shrink tube. If it's not a real tight fit you can secure it with CA.
BC
Basketcase is offline Find More Posts by Basketcase
Old May 28, 2002, 05:25 PM
sgil2001 is offline
R/C Enthusiast
sgil2001's Avatar
Joined May 2001
You can get the alum. tubing at most hobby shops. I used some of the little plastic things that come with the kit to hold the wheel on. The thing that has all the plastic parts on has several sized pieces that look like the wheel collars that you're supposed to use. I just took the larger pieces and reamed them out a bit so they would fit on the tubing. If my obscure description didn't help, maybe this picture will.
Old May 28, 2002, 05:26 PM
rclark is offline
Find More Posts by rclark
A Clinger
rclark's Avatar
Butte, MT
Joined Sep 2001
I did some head scratching on that too since I had already epoxied the current mount and wire into the wing.... What I did was take a piece of wire and bend into a right angle. This wire was small enough that the original wire + the new wire still fit in the wheel hole. Then wrapped thread around the wires on the upper leg of the gear and covered with epoxy. Then slid the wheel over both wires and soldered a small washer on the end of the wire. seems to work ok...... Yep, I know a kludge; but is works ! Wheels do spin freely and ROGs just fine.
Oh to strenghen the gear I first put a shrink tube onto the main gear; I then slide an 1/8" dowel into the tube next to the wire and shrunk the tubing. I then tied (like on a fishing pole) thread around both ends of tube, wire, and dowel and covered thread with epoxy. Works great. I think the length of the dowel and tubing is about 2 to 3 inches as I still wanted some flex in gear for landing. Anyway I 'clarkatized' it.....
rclark is offline Find More Posts by rclark
Old May 28, 2002, 05:36 PM
Aspen is offline
Find More Posts by Aspen
Aspen's Avatar
Kingsport Tn.
Joined Nov 2001
I use brass tubing and solder it on. You can solder brass, but not aluminum .
Aspen is offline Find More Posts by Aspen
GWS landing gear wire wellington53 GWS (Grand Wing Servo) 5 Dec 25, 2004 11:27 PM
Question GWS Landing Gear Reinforcement Ideas Cincy E-Flyer Parkflyers 5 Jun 25, 2004 02:58 PM
GWS Landing Gear boomerace Electric Plane Talk 14 Mar 27, 2004 06:19 PM
Question Where do I find the GWS landing gear mounting hardware? mike93 Parkflyers 4 Oct 10, 2003 10:13 AM
How to reinforce your GWS landing gear mounts ddoucette Parkflyers 4 Oct 02, 2003 09:22 AM
